Meross wall plug
Tue Dec 11, 2018 2:00 am
MarcoGT offline
Meross wall plug
Hi all,
just found this ones:
https://www.amazon.de/Intelligente-Stec ... HADGTMEGB3
There is also a Python librery to control it:
https://github.com/albertogeniola/MerossIot
Maybe over Christmas I will have time to play with them.
Let's see.
Tue Jun 11, 2019 3:49 pm
siclark offline
Re: Meross wall plug
Hi. Did you ever get these working? I'm interested but not sure how responsive they will be? Looks to me a login to the cloud server every time you send a command. Might be slow?
Sun Feb 28, 2021 12:38 pm
mattyf offline
I would love it if someone could help me get this library installed. It's just slightly beyond my scope of understanding.
Sun Feb 28, 2021 2:42 pm
Installing the library on it's own isn't going to help you. You would also need to write code (ie a plugin) that would make that library available to Indigo. Complicating it even further is that the library is Python3 only, which cannot be accessed directly from an Indigo plugin. I have a method for using Python3 libraries in some of my plugins now, but it's pretty involved to use.
Wed Mar 03, 2021 1:25 pm
mattyf offline
But could I write a python script that just ran as a script inside Indigo?
Wed Mar 03, 2021 1:27 pm
It would have to be an external script, since internal scripts can only be Python2. But yes, you could do that.
Wed Mar 03, 2021 1:28 pm
That assumes you have Python3 installed on your computer, which is only Catalina or later, but default.
