OLED keypad control
Fri Apr 20, 2018 10:23 am
Vangelis offline
OLED keypad control
Came across the following :
https://www.infinitton.com and
https://www.elgato.com/en/gaming/stream-deck
and it got me thinking. Maybe I could use these as a wall or bedside keypad controller. You can upload graphics to the buttons and they can issue a URL call (restful API) to control events in indigo. I know it’s a usb device but depending on positioning and distance from control MAC it would work. You could even run a USB wireless hub for larger distances.
Not got all the info on them yet but your could have separate images based on device status. One of them even has some audio feedback capability.
Could even use it as an alarm keypad and have the numbers randomise their position to stop shoulder surfing!
Any gamers had experience if this hardware?
Vangelis
Fri Apr 20, 2018 10:51 am
Colorado4Wheeler offline
Re: OLED keypad control
Those are pretty slick! Of course there are other factors to consider aside from the elevated cost of the device plus a Wifi USB hub and that is how programmable it is to dim or brighten those buttons at bed time. I have a KeyPadLinc next to my bed and for $69 it's easy to justify that because it's fully controllable from Indigo. I do like how those are programmable, so much so I may order one just for my regular computing needs!
Fri Apr 20, 2018 10:58 am
Vangelis offline
Agree, maybe you could push a global black .gif at bedtime, then push the button .gifs on motion (with timeout) etc
Looks like you can do some cool graphic effects, but as you say the price is a little high
Vangelis
Mon May 07, 2018 3:33 pm
mat offline
Ok missed this, just what I'm looking for, for media control..... :shock:
Ships to the UK too.
Has anyone purchased and tinkered yet? May well have to play with the one :D
Late 2018 mini 10.14
Mon May 07, 2018 3:50 pm
mat offline
Damn, doesn't look like its wifi - not sure that works while sitting watching a film as my mini is about 30m away - USB only!
Tue May 08, 2018 7:30 am
Vangelis offline
You can get wireless USB hubs that may work for your requirement?
eg https://www.amazon.co.uk/IOGear-Wireles ... B0026M9Y2K
Vangelis
Tue Aug 27, 2019 10:30 am
Korey offline
FYI: as of Aug 27/2019 Stream Deck mini is 50% off at Best Buy
Korey
Tue Aug 27, 2019 5:42 pm
mclass offline
.... or maybe an adaptation of Karl’s excellent Arduino plugin using the usb port of a small Arduino like NodeMCU?
Note also that there’s “Stream Deck Mobile” iOS app!!
mclass
Tue Sep 03, 2019 2:13 pm
colinpartridge offline
its certainly do-able as demonstrated by this product [url]http://labs.frostbox.net/products/macro-stream-sd/][/url]which uses custom code on a Raspberry Pi as a bridge to a digital audio console.
Colin
