Sonoff WIFI smart switch - uses ESP8266
Fri Aug 30, 2019 12:22 pm
Re: Sonoff WIFI smart switch - uses ESP8266
zoff wrote:
I installed Karl's arduino plug-in, what do I do next? .
What's that plugin for?
zoff wrote:
Sorry to be such a noob at this but I would appreciate any advice.
What do you want to actually do?
If you want to control the Sonoff with Tasmota firmware using MQTT, you need to set up an MQTT Broker, the MQTT Connector plugin, and the MQTT Shims plugin.
Start here: https://github.com/FlyingDiver/Indigo-M ... uick-Start
Fri Aug 30, 2019 5:36 pm
mundmc offline
zoff wrote:
Okay, I think I flashed the Sonoff 4ch Pro using NodeMCU-PyFlasher-4.0 on mac via USB-serial adaptor and the Sonoff-Tasmota v6.6.0 firmware. The software says "Firmware successfully flashed." So it must be true :? I installed Karl's arduino plug-in, what do I do next?
@zoff- I like the cut of your jib. You got moxy. Seriously, I appreciate you taking the deep dive, and I’m learning from your questions. :)
Sat Aug 31, 2019 2:24 am
zoff offline
Control the Sonofff 4CH from Indigo.
