Thanks for the answer.
But as far as I understood, roaming will also work between to LITE (not ZHO)
kw123 wrote:seamless roaming only works between ap-pro and ap-pro when you set it up correctly in the controller.
ps my setup (controller, USG-router, 24 port switch, 3 AP-PRO) has been working flawlessly for several weeks
by Ubiquiti Employee UBNT-Brandon
on 06-09-2016 09:07 AM
Options
So yes we have prototypes of 802.11rkv in the Beta forum and will be focusing back on them soon.
Zero-handoff does not really make sense for 802.11ac radios, as it's a same-channel architecture. So to have adequate roaming in your network design with it - you necessary reduce the CINR such that 802.11ac rates are not achieved.
So the focus will be on 802.11rkv.
For those who'd like to use zero-handoff still, I'd recommend going with our standard generation-one (non-AC) line up, given that using zero-handoff on the -AC gear would make it perform identically to the less-expensive 11n gear.
So I'd recommend using UAP, UAP-LR, UAP-Pro, UAP-Outdoor, etc.
I'll mark this as idea as not accepted.
Sorry to be the bearer of bad news.
Best Regards,
Brandon
kw123 wrote:When you set it up in the controller with the ap-pro I can select zero xxx *)handover
And in the log you can see that it actually does it- you see and "sign off" and "sign in" on the 2 involved ap-pros with the time stamp
*) I am out of town. I don't recall the exact phrase.
lalisingh wrote:I use the Netspot app to survey http://www.netspotapp.com/features.html
I then either move to reduce the radio strengh of the AP so that signal overlap between two AP's is about -80db
14:57:23 AP++++ -192.168.1.5 Jul 19 14:57:22 5-gameRoom user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath0: 54:9f:13:3f:95:25 / 1
14:57:23 AP++++ -192.168.1.5 Jul 19 14:57:22 5-gameRoom daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 IEEE 802.11: sta_stats
14:57:23 AP++++ -192.168.1.5 Jul 19 14:57:22 5-gameRoom daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 IEEE 802.11: disassociated
14:57:23 AP++++ -192.168.1.5 Jul 19 14:57:22 5-gameRoom daemon.notice hostapd: AP-STA-DISCONNECTED 54:9f:13:3f:95:25
14:57:26 AP++++ -192.168.1.5 Jul 19 14:57:25 5-gameRoom user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath0: 54:9f:13:3f:95:25 / 1
14:57:26 AP---- -192.168.1.5 Jul 19 14:57:25 5-gameRoom user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath0: 54:9f:13:3f:95:25 / 1
14:57:26 AP++++ -192.168.1.5 Jul 19 14:57:25 5-gameRoom daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 IEEE 802.11: associated
14:57:26 AP++++ -192.168.1.5 Jul 19 14:57:25 5-gameRoom daemon.notice hostapd: AP-STA-CONNECTED 54:9f:13:3f:95:25
14:57:26 AP++++ -192.168.1.5 Jul 19 14:57:25 5-gameRoom daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 RADIUS: starting accounting session 00000015-00000213
14:57:26 AP++++ -192.168.1.5 Jul 19 14:57:25 5-gameRoom daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 WPA: pairwise key handshake completed (RSN)
14:57:55 AP++++ -192.168.1.4 Jul 19 14:57:54 4-kons user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath0: 54:9f:13:3f:95:25 / 2
14:57:55 AP---- -192.168.1.4 Jul 19 14:57:54 4-kons user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath0: 54:9f:13:3f:95:25 / 2
14:57:55 AP++++ -192.168.1.4 Jul 19 14:57:54 4-kons daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 IEEE 802.11: associated
14:57:55 AP++++ -192.168.1.4 Jul 19 14:57:54 4-kons daemon.notice hostapd: AP-STA-CONNECTED 54:9f:13:3f:95:25
14:57:55 AP++++ -192.168.1.4 Jul 19 14:57:54 4-kons daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 RADIUS: starting accounting session 00000014-000002ED
14:57:55 AP++++ -192.168.1.4 Jul 19 14:57:54 4-kons daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 WPA: pairwise key handshake completed (RSN)
14:58:11 AP++++ -192.168.1.5 Jul 19 14:58:10 5-gameRoom daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 IEEE 802.11: sta_stats
14:58:11 AP++++ -192.168.1.5 Jul 19 14:58:10 5-gameRoom user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath0: 54:9f:13:3f:95:25 / 1
14:58:11 AP++++ -192.168.1.5 Jul 19 14:58:10 5-gameRoom daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 IEEE 802.11: disassociated
14:58:11 AP++++ -192.168.1.5 Jul 19 14:58:10 5-gameRoom daemon.notice hostapd: AP-STA-DISCONNECTED 54:9f:13:3f:95:25
14:58:11 AP++++ -192.168.1.5 Jul 19 14:58:10 5-gameRoom daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 IEEE 802.11: associated
14:58:11 AP++++ -192.168.1.5 Jul 19 14:58:10 5-gameRoom user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath0: 54:9f:13:3f:95:25 / 1
14:58:11 AP---- -192.168.1.5 Jul 19 14:58:10 5-gameRoom user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath0: 54:9f:13:3f:95:25 / 1
14:58:11 AP++++ -192.168.1.5 Jul 19 14:58:10 5-gameRoom daemon.notice hostapd: AP-STA-CONNECTED 54:9f:13:3f:95:25
14:58:11 AP++++ -192.168.1.5 Jul 19 14:58:10 5-gameRoom daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 RADIUS: starting accounting session 00000015-00000214
14:58:11 AP++++ -192.168.1.5 Jul 19 14:58:10 5-gameRoom daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 WPA: pairwise key handshake completed (RSN)
15:03:30 AP++++ -192.168.1.4 Jul 19 15:03:29 4-kons daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 IEEE 802.11: sta_stats
15:03:30 AP++++ -192.168.1.4 Jul 19 15:03:29 4-kons daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 IEEE 802.11: disassociated
15:03:30 AP++++ -192.168.1.4 Jul 19 15:03:29 4-kons user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath0: 54:9f:13:3f:95:25 / 2
15:03:30 AP++++ -192.168.1.4 Jul 19 15:03:29 4-kons daemon.notice hostapd: AP-STA-DISCONNECTED 54:9f:13:3f:95:25
15:03:30 AP++++ -192.168.1.4 Jul 19 15:03:29 4-kons daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 IEEE 802.11: associated
15:03:30 AP++++ -192.168.1.4 Jul 19 15:03:29 4-kons user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath0: 54:9f:13:3f:95:25 / 2
15:03:30 AP---- -192.168.1.4 Jul 19 15:03:29 4-kons user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath0: 54:9f:13:3f:95:25 / 2
15:03:30 AP++++ -192.168.1.4 Jul 19 15:03:29 4-kons daemon.notice hostapd: AP-STA-CONNECTED 54:9f:13:3f:95:25
15:03:30 AP++++ -192.168.1.4 Jul 19 15:03:29 4-kons daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 RADIUS: starting accounting session 00000014-000002EE
15:03:30 AP++++ -192.168.1.4 Jul 19 15:03:29 4-kons daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 WPA: pairwise key handshake completed (RSN)
15:03:46 AP++++ -192.168.1.5 Jul 19 15:03:45 5-gameRoom user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath0: 54:9f:13:3f:95:25 / 1
15:03:46 AP++++ -192.168.1.5 Jul 19 15:03:45 5-gameRoom daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 IEEE 802.11: sta_stats
15:03:46 AP++++ -192.168.1.5 Jul 19 15:03:45 5-gameRoom daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 IEEE 802.11: disassociated
15:03:46 AP++++ -192.168.1.5 Jul 19 15:03:45 5-gameRoom daemon.notice hostapd: AP-STA-DISCONNECTED 54:9f:13:3f:95:25
15:03:46 AP++++ -192.168.1.5 Jul 19 15:03:45 5-gameRoom user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath0: 54:9f:13:3f:95:25 / 1
15:03:46 AP---- -192.168.1.5 Jul 19 15:03:45 5-gameRoom user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath0: 54:9f:13:3f:95:25 / 1
15:03:46 AP++++ -192.168.1.5 Jul 19 15:03:45 5-gameRoom daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 IEEE 802.11: associated
15:03:46 AP++++ -192.168.1.5 Jul 19 15:03:45 5-gameRoom daemon.notice hostapd: AP-STA-CONNECTED 54:9f:13:3f:95:25
15:03:46 AP++++ -192.168.1.5 Jul 19 15:03:45 5-gameRoom daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 RADIUS: starting accounting session 00000015-00000215
15:03:46 AP++++ -192.168.1.5 Jul 19 15:03:45 5-gameRoom daemon.info hostapd: ath0: STA 54:9f:13:3f:95:25 WPA: pairwise key handshake completed (RSN)
Jul 19 16:21:31 Garage user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath2: 5c:ad:cf:1a:39:2e / 3
Jul 19 16:21:31 Garage daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
Jul 19 16:21:31 Garage daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000D-00000033
Jul 19 16:21:31 Garage daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
Jul 19 16:21:49 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath1: 5c:ad:cf:1a:39:2e / 0
Jul 19 16:21:49 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
Jul 19 16:21:49 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
Date Time Seconds WAP Message
19-Jul 16:20:00 0:00:00 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath2: 5c:ad:cf:1a:39:2e / 1
19-Jul 16:20:00 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
19-Jul 16:20:00 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000E-0000008F
19-Jul 16:20:00 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
19-Jul 16:20:19 0:00:19 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath2: 5c:ad:cf:1a:39:2e / 0
19-Jul 16:20:19 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
19-Jul 16:20:19 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
19-Jul 16:20:19 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath2: 5c:ad:cf:1a:39:2e / 1
19-Jul 16:20:19 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
19-Jul 16:20:19 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000E-00000091
19-Jul 16:20:19 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
19-Jul 16:21:09 0:00:50 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath1: 5c:ad:cf:1a:39:2e / 0
19-Jul 16:21:09 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
19-Jul 16:21:09 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
19-Jul 16:21:09 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
19-Jul 16:21:09 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath1: 5c:ad:cf:1a:39:2e / 2
19-Jul 16:21:09 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000D-00000075
19-Jul 16:21:09 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
19-Jul 16:21:31 0:00:22 Garage user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath2: 5c:ad:cf:1a:39:2e / 3
19-Jul 16:21:31 Garage daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
19-Jul 16:21:31 Garage daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000D-00000033
19-Jul 16:21:31 Garage daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
19-Jul 16:21:49 0:00:18 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath1: 5c:ad:cf:1a:39:2e / 0
19-Jul 16:21:49 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
19-Jul 16:21:49 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
19-Jul 16:21:49 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath1: 5c:ad:cf:1a:39:2e / 2
19-Jul 16:21:49 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
19-Jul 16:21:49 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000D-00000076
19-Jul 16:21:49 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
19-Jul 16:25:54 0:04:05 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath2: 5c:ad:cf:1a:39:2e / 0
19-Jul 16:25:54 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
19-Jul 16:25:54 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
19-Jul 16:26:46 0:00:52 Garage user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath2: 5c:ad:cf:1a:39:2e / 0
19-Jul 16:26:46 Garage daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
19-Jul 16:26:46 Garage daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
19-Jul 18:37:46 2:11:00 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath1: 5c:ad:cf:1a:39:2e / 0
19-Jul 18:37:46 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
19-Jul 18:37:46 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
19-Jul 19:45:52 1:08:06 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath1: 5c:ad:cf:1a:39:2e / 2
19-Jul 19:45:52 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
19-Jul 19:45:52 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000D-00000078
19-Jul 19:45:52 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
19-Jul 19:55:32 0:09:40 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath1: 5c:ad:cf:1a:39:2e / 0
19-Jul 19:55:32 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
19-Jul 19:55:32 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
19-Jul 19:55:32 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
19-Jul 19:55:32 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath1: 5c:ad:cf:1a:39:2e / 2
19-Jul 19:55:32 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000D-00000079
19-Jul 19:55:32 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
19-Jul 20:07:24 0:11:52 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
19-Jul 20:07:24 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
19-Jul 20:07:24 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath1: 5c:ad:cf:1a:39:2e / 0
19-Jul 20:08:40 0:01:16 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath1: 5c:ad:cf:1a:39:2e / 2
19-Jul 20:08:40 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
19-Jul 20:08:40 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000D-0000007A
19-Jul 20:08:40 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
19-Jul 20:10:43 0:02:03 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath1: 5c:ad:cf:1a:39:2e / 0
19-Jul 20:10:43 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
19-Jul 20:10:43 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
19-Jul 20:10:43 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath1: 5c:ad:cf:1a:39:2e / 2
19-Jul 20:10:43 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
19-Jul 20:10:43 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000D-0000007B
19-Jul 20:10:43 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
19-Jul 20:14:53 0:04:10 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath2: 5c:ad:cf:1a:39:2e / 2
19-Jul 20:14:53 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
19-Jul 20:14:53 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000E-00000093
19-Jul 20:14:53 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
19-Jul 20:16:40 0:01:47 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath1: 5c:ad:cf:1a:39:2e / 0
19-Jul 20:16:40 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
19-Jul 20:16:40 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
19-Jul 21:08:14 0:51:34 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath1: 5c:ad:cf:1a:39:2e / 3
19-Jul 21:08:14 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
19-Jul 21:08:14 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000D-0000007D
19-Jul 21:08:14 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
19-Jul 21:13:11 0:04:57 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath2: 5c:ad:cf:1a:39:2e / 0
19-Jul 21:13:11 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
19-Jul 21:13:11 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
19-Jul 21:13:35 0:00:24 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath1: 5c:ad:cf:1a:39:2e / 0
19-Jul 21:13:35 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
19-Jul 21:13:35 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
19-Jul 23:41:26 2:27:51 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath2: 5c:ad:cf:1a:39:2e / 2
19-Jul 23:41:26 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
19-Jul 23:41:26 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000E-00000095
19-Jul 23:41:26 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
19-Jul 23:44:24 0:02:58 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath2: 5c:ad:cf:1a:39:2e / 0
19-Jul 23:44:24 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
19-Jul 23:44:24 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
19-Jul 23:44:24 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath2: 5c:ad:cf:1a:39:2e / 2
19-Jul 23:44:24 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
19-Jul 23:44:24 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000E-00000096
19-Jul 23:44:24 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
19-Jul 23:44:27 0:00:03 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath0: 5c:ad:cf:1a:39:2e / 3
19-Jul 23:44:27 PoolEntrance daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
19-Jul 23:44:27 PoolEntrance daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000F-000000F6
19-Jul 23:44:27 PoolEntrance daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
19-Jul 23:49:24 0:04:57 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath2: 5c:ad:cf:1a:39:2e / 0
19-Jul 23:49:24 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
19-Jul 23:49:24 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
19-Jul 23:50:35 0:01:11 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
19-Jul 23:50:35 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath2: 5c:ad:cf:1a:39:2e / 2
19-Jul 23:50:35 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000E-00000097
19-Jul 23:50:35 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
19-Jul 23:55:26 0:04:51 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath0: 5c:ad:cf:1a:39:2e / 0
19-Jul 23:55:26 PoolEntrance daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
19-Jul 23:55:26 PoolEntrance daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
20-Jul 6:27:32 6:27:32 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath0: 5c:ad:cf:1a:39:2e / 3
20-Jul 6:27:32 PoolEntrance daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
20-Jul 6:27:32 PoolEntrance daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000F-000000F7
20-Jul 6:27:32 PoolEntrance daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
20-Jul 6:27:48 0:00:16 Garage user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath0: 5c:ad:cf:1a:39:2e / 1
20-Jul 6:27:48 Garage daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
20-Jul 6:27:48 Garage daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000F-00000280
20-Jul 6:27:48 Garage daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
20-Jul 6:29:49 0:02:01 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath2: 5c:ad:cf:1a:39:2e / 0
20-Jul 6:29:49 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
20-Jul 6:29:49 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
20-Jul 6:29:49 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath2: 5c:ad:cf:1a:39:2e / 2
20-Jul 6:29:49 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
20-Jul 6:29:49 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000E-00000098
20-Jul 6:29:49 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
20-Jul 6:30:11 0:00:22 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath0: 5c:ad:cf:1a:39:2e / 0
20-Jul 6:30:11 PoolEntrance daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
20-Jul 6:30:11 PoolEntrance daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
20-Jul 6:30:11 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath0: 5c:ad:cf:1a:39:2e / 3
20-Jul 6:30:11 PoolEntrance daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
20-Jul 6:30:11 PoolEntrance daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000F-000000FA
20-Jul 6:30:11 PoolEntrance daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
20-Jul 6:34:58 0:04:47 Garage user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath0: 5c:ad:cf:1a:39:2e / 0
20-Jul 6:34:58 Garage daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
20-Jul 6:34:58 Garage daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
20-Jul 6:35:09 0:00:11 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath2: 5c:ad:cf:1a:39:2e / 0
20-Jul 6:35:09 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
20-Jul 6:35:09 PoolEntrance daemon.info hostapd: ath2: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
20-Jul 6:36:26 0:01:17 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath1: 5c:ad:cf:1a:39:2e / 4
20-Jul 6:36:26 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
20-Jul 6:36:26 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000D-00000080
20-Jul 6:36:26 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
20-Jul 7:03:50 0:27:24 PoolEntrance user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath0: 5c:ad:cf:1a:39:2e / 0
20-Jul 7:03:50 PoolEntrance daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
20-Jul 7:03:50 PoolEntrance daemon.info hostapd: ath0: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
20-Jul 7:10:52 0:07:02 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath1: 5c:ad:cf:1a:39:2e / 0
20-Jul 7:10:52 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
20-Jul 7:10:52 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
20-Jul 7:53:50 0:42:58 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: associated
20-Jul 7:53:50 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_JOIN ath1: 5c:ad:cf:1a:39:2e / 4
20-Jul 7:53:50 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e RADIUS: starting accounting session 0000000D-00000081
20-Jul 7:53:50 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e WPA: pairwise key handshake completed (RSN)
20-Jul 7:58:59 0:05:09 LeesasOffice user.info syslog: wevent.ubnt_custom_event(): EVENT_STA_LEAVE ath1: 5c:ad:cf:1a:39:2e / 0
20-Jul 7:58:59 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: sta_stats
20-Jul 7:58:59 LeesasOffice daemon.info hostapd: ath1: STA 5c:ad:cf:1a:39:2e IEEE 802.11: disassociated
Wed Jul 20 06:33:51.669 Roam: <airportd[90]> ROAMING PROFILES updated to DISABLED for 2.4GHz on en0
Wed Jul 20 06:33:51.669 Roam: <airportd[90]> ROAMING PROFILES updated to DISABLED for 5GHz on en0
Wed Jul 20 06:33:54.917 Roam: <airportd[90]> ROAMING PROFILES updated to MULTI-AP for 2.4GHz on en0
Wed Jul 20 06:33:54.917 Roam: <airportd[90]> ROAMING PROFILES updated to MULTI-AP for 5GHz on en0
Wed Jul 20 06:34:02.449 Roam: <airportd[90]> ROAMING PROFILES already set to MULTI-AP for 2.4GHz on en0
Wed Jul 20 06:34:02.449 Roam: <airportd[90]> ROAMING PROFILES already set to MULTI-AP for 5GHz on en0
Wed Jul 20 06:34:02.449 AutoJoin: <airportd[90]> BEST CONNECTED ROAM triggered
Wed Jul 20 06:34:02.450 Driver Event: <airportd[90]> _bsd_80211_event_callback: APPLE80211_M_ROAM_START (en0)
Wed Jul 20 06:34:02.450 Info: <airportd[90]> Roaming started on interface en0
Wed Jul 20 06:34:05.374 <kernel> en0: roam event, sending supplicant link down message.
Wed Jul 20 06:34:05.442 Driver Event: <airportd[90]> _bsd_80211_event_callback: APPLE80211_M_ROAM_END (en0)
Wed Jul 20 06:34:05.442 Info: <airportd[90]> Roaming ended on interface en0
Wed Jul 20 06:34:05.542 P2P: <airportd[90]> _p2pSupEventCallback: Primary interface roamed from channel 52 (flags=0x510) to channel 36 (flags=0x410)
Wed Jul 20 09:35:54.603 Driver Event: <airportd[90]> _bsd_80211_event_callback: APPLE80211_M_ROAM_START (en0)
Wed Jul 20 09:35:54.603 Info: <airportd[90]> Roaming started on interface en0
Wed Jul 20 09:35:57.915 <kernel> en0: roam event, sending supplicant link down message.
Wed Jul 20 09:35:57.985 Driver Event: <airportd[90]> _bsd_80211_event_callback: APPLE80211_M_ROAM_END (en0)
Wed Jul 20 09:35:57.985 Info: <airportd[90]> Roaming ended on interface en0
Wed Jul 20 09:35:58.132 P2P: <airportd[90]> _p2pSupEventCallback: Primary interface roamed from channel 36 (flags=0x410) to channel 100 (flags=0x510)
Wed Jul 20 09:37:22.990 Roam: <airportd[90]> ROAMING PROFILES already set to MULTI-AP for 2.4GHz on en0
Wed Jul 20 09:37:22.990 Roam: <airportd[90]> ROAMING PROFILES already set to MULTI-AP for 5GHz on en0
Wed Jul 20 09:37:24.078 Roam: <airportd[90]> ROAMING PROFILES already set to MULTI-AP for 2.4GHz on en0
Wed Jul 20 09:37:24.078 Roam: <airportd[90]> ROAMING PROFILES already set to MULTI-AP for 5GHz on en0
Wed Jul 20 09:37:46.310 Roam: <airportd[90]> ROAMING PROFILES already set to MULTI-AP for 2.4GHz on en0
Wed Jul 20 09:37:46.310 Roam: <airportd[90]> ROAMING PROFILES already set to MULTI-AP for 5GHz on en0
Wed Jul 20 09:37:46.310 AutoJoin: <airportd[90]> BEST CONNECTED ROAM triggered
Wed Jul 20 09:37:46.311 Driver Event: <airportd[90]> _bsd_80211_event_callback: APPLE80211_M_ROAM_START (en0)
Wed Jul 20 09:37:46.311 Info: <airportd[90]> Roaming started on interface en0
Wed Jul 20 09:37:49.157 <kernel> en0: roam event, sending supplicant link down message.
Wed Jul 20 09:37:49.176 Driver Event: <airportd[90]> _bsd_80211_event_callback: APPLE80211_M_ROAM_END (en0)
Wed Jul 20 09:37:49.176 Info: <airportd[90]> Roaming ended on interface en0
Wed Jul 20 09:38:38.480 Driver Event: <airportd[90]> _bsd_80211_event_callback: APPLE80211_M_ROAM_START (en0)
Wed Jul 20 09:38:38.480 Info: <airportd[90]> Roaming started on interface en0
Wed Jul 20 09:38:41.387 <kernel> en0: roam event, sending supplicant link down message.
Wed Jul 20 09:38:41.454 Driver Event: <airportd[90]> _bsd_80211_event_callback: APPLE80211_M_ROAM_END (en0)
Wed Jul 20 09:38:41.454 Info: <airportd[90]> Roaming ended on interface en0
Wed Jul 20 09:38:41.537 P2P: <airportd[90]> _p2pSupEventCallback: Primary interface roamed from channel 116 (flags=0x510) to channel 52 (flags=0x510)
evansgo wrote:My three AC-Pro's have arrived
So I first discovered them on the network, then they updated themselves, all fine. Now I also set up the default network and it seems happy enough, but when I try to set up a second Wireless Network I am not seeing anything different to the first, no mention of Zero Handoff capability? I am using the release version of Unify on a Mac if that makes a difference.
Can anyone tell me how I set these up to enable the Zero handoff?
