Python script help for basic maths
Sun Jul 29, 2018 12:02 pm
petematheson offline
Hi All,
Not great with Python scripting and need a hand with some basic maths to calculate my E7 electric cost.
I have the following variables:
E7DayRate
E7NightRate
E7Standing
SmappeeTodayCost
SmappeeTodayDaykWh
SmappeeTodayMorningkWh
SmappeeTodayNightkWh
I'm looking for a script that will do the following:
((SmappeeTodayDaykWh - SmappeeTodayNightkWh) * E7DayRate) + ((SmappeeTodayNightkWh - SmappeeTodayMorningkWh) * E7NightRate) + E7Standing = SmappeeTodayCost
Sun Jul 29, 2018 1:23 pm
Re: Python script help for basic maths
Those are Indigo variables?
E7Standing    = indigo.variables["E7Standing"].value
E7DayRate    = indigo.variables["E7DayRate"].value
E7NightRate    = indigo.variables["E7NightRate"].value
SmappeeTodayDaykWh    = indigo.variables["SmappeeTodayDaykWh"].value
SmappeeTodayNightkWh    = indigo.variables["SmappeeTodayNightkWh"].value
SmappeeTodayMorningkWh    = indigo.variables["SmappeeTodayMorningkWh"].value
SmappeeTodayCost= ((SmappeeTodayDaykWh - SmappeeTodayNightkWh) * E7DayRate) + ((SmappeeTodayNightkWh - SmappeeTodayMorningkWh) * E7NightRate) + E7Standing
indigo.variable.updateValue("SmappeeTodayCost", str(SmappeeTodayCost))
Or something like that.
But, in general, it's better to use the variable ID instead of the name.
Sun Jul 29, 2018 2:33 pm
Ah thanks for this!
Tried running that and got an error:
Script Error embedded script: unsupported operand type(s) for -: 'unicode' and 'unicode'
embedded script, line 10, at top level
TypeError: unsupported operand type(s) for -: 'unicode' and 'unicode'
Sun Jul 29, 2018 2:44 pm
Oh, right.
E7Standing    = int(indigo.variables["E7Standing"].value)
E7DayRate    = int(indigo.variables["E7DayRate"].value)
E7NightRate    = int(indigo.variables["E7NightRate"].value(
SmappeeTodayDaykWh  = int(indigo.variables["SmappeeTodayDaykWh"].value)
SmappeeTodayNightkWh    = int(indigo.variables["SmappeeTodayNightkWh"].value)
SmappeeTodayMorningkWh    = int(indigo.variables["SmappeeTodayMorningkWh"].value)
Or I think maybe you can use .intValue instead of .value and then you don't need the cast. I don't write much code that deals with Indigo Variables.
Sun Jul 29, 2018 2:50 pm
It seems to be the maths causing the issue.
Night = 4
Today = 10
If I have
SmappeeTodayCost = SmappeeTodayNightkWh+SmappeeTodayDaykWh
Then i get 410 as the value for Cost (but doesn't do addition)
If I have
SmappeeTodayCost= SmappeeTodayDaykWh-SmappeeTodayNightkWh
It throws that error.
Sun Jul 29, 2018 3:24 pm
I just copied your formula verbatim. I don't know what the variables mean so I couldn't check the math.
Sun Jul 29, 2018 3:26 pm
CliveS offline
That is because 4 and 10 are strings, you need to use int to change them to numbers. And I get confused with Python as well !
Example
>>> x = '100'
>>> y = '-90'
>>> print x + y
100-90
>>> print int(x) + int(y)
10
CliveS
Sun Jul 29, 2018 3:35 pm
Definitely on the right track :)
SmappeeTodayCost= int(SmappeeTodayDaykWh) + int(SmappeeTodayNightkWh)
Gives me
Script Error embedded script: invalid literal for int() with base 10: '11.07'
ValueError: invalid literal for int() with base 10: '11.07'
If I change my SmappeeTodayDaykWh to 2 digitals (11 rather than 11.07) then the calculation works.
Sun Jul 29, 2018 3:38 pm
change all the those int() casts to float().
Sun Jul 29, 2018 3:52 pm
ooooh close!
SmappeeTodayCost= float(SmappeeTodayDaykWh)-float(SmappeeTodayNightkWh)
Works
SmappeeTodayCost= (float(SmappeeTodayDaykWh)-float(SmappeeTodayNightkWh))*float(E7DayRate)
Errors with
Embedded script executor host started
Error XML Parse Error: not well-formed (invalid token)
Error On character 219 of line number 1.
Error On character 325 of line number 1.
Error On character 350 of line number 1.
Error because embedded scripts execute sequentially they must complete their execution within 10 seconds.
Error modify the script to exit quickly or convert it to an external file (not embedded).
Stopping embedded script executor host (pid 3467)
Stopped "embedded script executor host"
Sun Jul 29, 2018 4:00 pm
Add my bad, I had the Rate variables as a currency (£0.1378) etc...
Calculations now work but I'm just going to check the maths.
SmappeeTodayCost= (((float(SmappeeTodayDaykWh) - float(SmappeeTodayNightkWh)) * float(E7DayRate))) + (((float(SmappeeTodayNightkWh) - float(SmappeeTodayMorningkWh)) * float(E7NightRate)))
Sun Jul 29, 2018 4:05 pm
Convert them to floats when you get the values from the indigo variables, like I did in my second example. Makes the calculation much easier to read.
Sun Jul 29, 2018 4:09 pm
Gotcha:
E7Standing = float(indigo.variables["E7Standing"].value)
E7DayRate = float(indigo.variables["E7DayRate"].value)
E7NightRate = float(indigo.variables["E7NightRate"].value)
SmappeeTodayDaykWh = float(indigo.variables["SmappeeTodayDaykWh"].value)
SmappeeTodayNightkWh = float(indigo.variables["SmappeeTodayNightkWh"].value)
SmappeeTodayMorningkWh = float(indigo.variables["SmappeeTodayMorningkWh"].value)
SmappeeTodayCost= (((SmappeeTodayDaykWh -SmappeeTodayNightkWh) * E7DayRate)) + (((SmappeeTodayNightkWh - SmappeeTodayMorningkWh) * E7NightRate)) + E7Standing
Sun Jul 29, 2018 4:22 pm
Math seems to check out!
Thanks all.
Made a minor adjustment to round the final number.
Using this I can now track my daily energy usage and display it on my wall mounted iPad :)
SmappeeTodayCost= ((SmappeeTodayDaykWh -SmappeeTodayNightkWh + SmappeeTodayMorningkWh) * E7DayRate) + ((SmappeeTodayNightkWh - SmappeeTodayMorningkWh) * E7NightRate) + E7Standing
SmappeeTodayCost= '%.2f' % round(SmappeeTodayCost, 2)
Sun Jul 29, 2018 11:39 pm
could be shortened:
SmappeeTodayCostText= '%.2f' % SmappeeTodayCost
indigo.variable.updateValue("SmappeeTodayCost",SmappeeTodayCostText)
the %.2f makes a string with 2 digits after the "."
- the round is not needed
- the str() is not needed
just to help a little on the learning curve..
although the round() does a real rounding .005 --> 0.01 -- .00499 goes to 0.00
while %.2 just cuts the 3 digit off
if you want to very precise
