Rapid flashing light on Leak Sensor
Fri Mar 16, 2018 9:47 am
greenhornet offline
I have an Insteon Leak sensor that has started flashing a green light. I replaced the battery about a week ago. There is no leak and the floor is dry and without humidity. I do not see any leaks being detected in the logs. As far as Indigo is concerned, the device is operating normally. When I push the button on the sensor, it triggers a leak alert (as it should). I have tried removing and replacing the battery, but it returns to the rapid flashing light within a minute or so.
Anybody know what the flashing light means? Unfortunately the PDF manual for the leak sensor doesn't cover this type of flashing.
