Arguments to Action callBackMethods
Posted: Fri Jul 15, 2016 11:54 am
In the wiki (http://wiki.indigodomo.com/doku.php?id= ... actionsxml), it doesn't specifically document the arguments to action callBackMethods, but the example only shows two:
However, I've seen an additional argument in a number of plugins, including the "Example Device - Factory" one:
If three is correct, the Wiki should be updated and the method signature explicitly documented.
- Code: Select all
def writeToLog(self, action):
if theType:
indigo.server.log(theMessage)
- Code: Select all
# Custom Plugin Action callbacks (defined in Actions.xml)
def setBacklightBrightness(self, pluginAction, dev):
newBrightness = int(pluginAction.props.get(u"brightness", 100))
except ValueError:
# The int() cast above might fail if the user didn't enter a number:
indigo.server.log(u"set backlight brightness action to device \"%s\" -- invalid brightness value" % (dev.name,), isError=True)
return
