Arguments to Action callBackMethods
Fri Jul 15, 2016 11:54 am
In the wiki (http://wiki.indigodomo.com/doku.php?id= ... actionsxml), it doesn't specifically document the arguments to action callBackMethods, but the example only shows two:
def writeToLog(self, action):
    if theType:
        indigo.server.log(theMessage)
However, I've seen an additional argument in a number of plugins, including the "Example Device - Factory" one:
   # Custom Plugin Action callbacks (defined in Actions.xml)
   def setBacklightBrightness(self, pluginAction, dev):
         newBrightness = int(pluginAction.props.get(u"brightness", 100))
      except ValueError:
         # The int() cast above might fail if the user didn't enter a number:
         indigo.server.log(u"set backlight brightness action to device \"%s\" -- invalid brightness value" % (dev.name,), isError=True)
         return
If three is correct, the Wiki should be updated and the method signature explicitly documented.
Fri Jul 15, 2016 12:22 pm
Re: Arguments to Action callBackMethods
I believe they are both correct. It can take two or three. Some actions specify a device, others do not. If your action does then include the 3rd parameter. We will get the documentation updated.
