[ANSWERED]: Ramp rate missing on Z-Wave LED bulb
Fri Jan 22, 2016 9:44 pm
JonathanKing offline
I bought a LinearLinc LED Bulb (LB60Z-1) and it works fine except I can't specify a ramp-rate the way I can for my Insteon and ZWave lamp modules. Am I missing something? Is this a bulb or Indigo limitation? What LED bulb should I buy to get a ramp rate. I don't like how the bulb immediately switches to the output requested, I'm a 2-second ramp kind of person I guess :)
-jonathan
Sat Jan 23, 2016 11:56 am
Re: Ramp rate missing on Z-Wave LED bulb.
I'm not sure what configuration parameters that bulb has, so check the user manual for the bulb to see what it lists. If it has any then you can set them in Indigo via the Z-Wave->Modify Configuration Parameter... menu item.
