Aeotec Micro Dimmer G2 used in a 3 way switch?
Sun Sep 27, 2015 4:05 pm
Minot offline
I have a current 3 way switch configuration with 2 switches and a light and want to add in an Aeotec G2 micro dimmer. I have white wires (neutral ) at each switch box. Does anyone know if it's possible to wire in a G2 into the 3 way configuration at one end? If yes, can you help me with a wiring diagram? I recently tried adding it in recently to no success. The G2 will only control the light if the other end is switched "on".
