Aquastat with an I/O Link or other insteon device?
Fri Jan 09, 2015 11:18 am
Jpaction offline
Is it possible to use an Aquastat with an I/O Link or other insteon device? I want to install a re-circulator system for DHW but I want 3 different zones/3 control valves with 1 pump and 3 motion detectors.
I want the aquastats, 1 on each zone to sense the water temp in its loop. If there is motion in that zone and the water temp is below x then open the zone valve and turn on the pump.
