[ANSWERED]: Checking mobile balance with python
Tue Jan 06, 2015 6:40 am
lochnesz offline
I have a issue with a script that is supposed to check the balance for my mobile pre-paid SIM card. The command is ATD*111# and it works okay with "screen".
When I use it in a script, I get this error:
Error XML Parse Error: not well-formed (invalid token)
Error On character 256 of line number 1.
Here is the script:
#!/usr/bin/env python
import serial
import time
indigo.server.log ("Starting...") #indigo log message
ser = serial.Serial('/dev/tty.GI505 Modem', 115200, timeout=2) #serial port is /dev/tty.GI505 Modem, baudrate 115200
ser.write('ATD*111# \r')
time.sleep(.5)
res = ser.read(size=100) #read result from modem
time.sleep(1)
ser.close()
indigo.server.log ("Modem result codes: " + "\r" + res) #indigo log message
However, the strange thing is that it works when I add another 0 in the AT command. The modem doesn't give the correct output since the AT command is incorrect, but the script works.
import serial
import time
ser.write('ATD*1110# \r')
time.sleep(.5)
time.sleep(1)
ser.close()
The modem then reports:
ATD*1110#
+CUSD: 2,"Unexpected Data Value",15
Which is expected since there is a zero that shouldn't be there.
Any ideas why the script doesn't work with ATD*111# but it works with ATD*1110# ? Did I miss something?
Tue Jan 06, 2015 7:00 am
lochnesz offline
Re: Checking mobile balance with python
Okay, a brief update. If I change the read size to 43 it works, but I don't get all the output that I need. 44+ doesn't work.
So changing either the AT command or read size makes the script go through...strange?
Tue Jan 06, 2015 8:25 am
Do you get the original "XML Parse Error" when trying to compile the script? I just copy/pasted your original (first) script and it compiled fine. The XML Parse error may not be related to this problem. It is strange that changing the arguments to those calls would change the behavior in that regards.
Tue Jan 06, 2015 8:32 am
lochnesz offline
Compiling is fine, running the script result in the errors.
Yes, really strange how those changes makes the script run successfully or not.
I just upgraded to latest Indigo release, still the same. :(
Tue Jan 06, 2015 8:35 am
lochnesz offline
Hm...if I remove the last line
the script runs without errors but I can't see the result.
Tue Jan 06, 2015 8:37 am
Comment out the indigo.server.log() call. I'll bet the serial data being returned isn't getting encoded correctly for logging, and the XML error is actually coming from the script API call to do the log.
Tue Jan 06, 2015 8:38 am
lochnesz offline
Yes that works. Any idea how I can see the result? I am new to python.
Tue Jan 06, 2015 8:41 am
lochnesz offline
This is the actual output when I use "screen":
atd*111#
+CUSD: 0,"SMS:a 05GB till 133 s� kan du surfa 0,5GB i 30 dagar f�r endast 30 kr.
SALDO: 29,71 kr
Prisplan: Standard",1
OK
May be something with the character set?
Tue Jan 06, 2015 8:59 am
Yeah, I'm not sure what encoding it is using. You can convert it to a string of hex data via:
import binascii
reshexstr = binascii.hexlify(res)
Or to try to strip the funny characters use:
resstripped = res.decode('ascii', 'replace')
Tue Jan 06, 2015 9:05 am
lochnesz offline
Re: [ANSWERED]: Checking mobile balance with python
It worked, thanks! Used resstripped = res.decode('ascii', 'replace') and the message is now in the log:
Modem result codes:
ATD*111#
SALDO: 29,71 kr
OK
I am really only interested in the amount after the text SALDO. Is there a way to strip to only the 8 bytes after the word SALDO, and maybe also get that into a Indigo variable?
Tue Jan 06, 2015 9:37 am
Something like:
balance = modemOutput.split('SALDO: ')[1][0:8]
indigo.variable.updateValue(12345678, value=balance)
Replace 12345678 with your variable Id and modemOutput with whatever you called your output from the modem.
Only partially tested - hope it helps :)
Tue Jan 06, 2015 10:10 am
lochnesz offline
It helped a a lot, thanks! One last very basic question I guess, but I get the error message that my Indigo "global name" variable is not defined. How do I do that? The variable exists in Indigo, but I need it defined in the python script?
Tue Jan 06, 2015 10:22 am
Not quite enough info to fully understand the error but as a starter for 10 - Are you referencing the variable value correctly (which I assume you have already setup)?
It is referenced like this (or similar):
indigo.variables[12345678].value
If this doesn't solve the issue, post your script and the full error message :)
Tue Jan 06, 2015 10:28 am
lochnesz offline
Oh no, I just forgot the quotation marks as I used the variable name, not the ID.
It works now!
Many thanks! :D
Tue Jan 06, 2015 10:41 am
lochnesz offline
Here is the final result. :D
The variables "mob_balance_value" and "mob_balance_updated" needs to be created in Indigo and will be updated by the script.
#check mobile balance from indigo v. 1.0
#uses pyserial
import serial
import time
indigo.server.log ("Starting script requesting mobile balance...") #indigo log message
ser = serial.Serial('/dev/tty.GI505 Modem', 115200, timeout=2) #serial port is /dev/tty.GI505 Modem, baudrate 115200, timeout 2
ser.write('ATD*111#\r') #request balance from telco (syntax for swedish operator comviq)
time.sleep(.5)
res = ser.read(size=256) #read result from modem
time.sleep(1)
ser.close()
resstripped = res.decode('ascii', 'replace') # convert/strip unknown characters to ascii
indigo.server.log ("Modem result output: " + "\r" + resstripped) #indigo log message
balance = resstripped.split('SALDO: ')[1][0:8] # cutting out the actual balance value
indigo.server.log ("Balance: " + balance) #indigo log message
localtime = time.asctime( time.localtime(time.time()) )
indigo.variable.updateValue("mob_balance_value", value=balance)
indigo.variable.updateValue("mob_balance_updated", value=localtime)
indigo.server.log ("Mobile balance script completed on: " + localtime) #indigo log message
