[FIXED]: Execute Trigger Documentation Grammar Correction
Tue Jan 06, 2015 5:34 am
autolog offline
Excuse my pedantry but I spotted a grammar error (in the Execute Trigger documentation) and thought I should report it. :)
The paragraph:
Tell the IndigoServer to execute the actions associated with the trigger. If you're plugin implements events, this is the method you'd call when the conditions for your specific event are met. If you're calling it this way, make sure you include the ignoreConditions=False parameter (or don't include the parameter since False is the default) so that any conditions associated with the trigger (by the user in the UI) are evaluated.
You're (short for you are) should be your (as in belongs to you) :wink:
Tue Jan 06, 2015 8:21 am
Re: Execute Trigger Documentation Grammar Correction
Hi Jon,
Thanks – I've correct it. Please continue to report any corrections. :-)
