iHealth showing issues...?
Thu Nov 01, 2012 10:40 pm
MountainEars offline
I ran iHealth, a little confused with the output. I ran it because I'm having issues with one device, wanted to see what it said. In looking at the report though it seems to imply I have a ton of issues?
I have a bunch of dual band devices and have since removed my AP's as I didn't think they were needed and everything is working great (except that one device). What should I look at, is there a way I can see more detail from a troubleshooting perspective?
I'm going to run it again overnight and see if it looks similar.
Here's what it looks like:
Per-device statistics: name success min avg max stdev avg
Back Flood 0 2.500 2.500 2.500 0.000 **************************************************
Barn Inside 0 2.500 2.500 2.500 0.000 **************************************************
Barn Outlet 1 0.175 2.268 2.500 0.697 *********************************************
Barn Outside Flood 1 0.924 2.342 2.500 0.473 **********************************************
Barn Paddocks 0 2.500 2.500 2.500 0.000 **************************************************
Front Door - Main Entry 2 0.165 2.033 2.500 0.934 ****************************************
Front Door - Mud Room 2 0.166 2.034 2.500 0.932 ****************************************
Front Gate Lights 1 0.200 2.270 2.500 0.690 *********************************************
Front Gate Outlet 2 0.168 2.034 2.500 0.932 ****************************************
Garage 2 0.249 2.051 2.500 0.898 *****************************************
I/O Link Front Gate 3 0.171 1.804 2.500 1.063 ************************************
Kitchen Bar Lights 1 0.145 2.264 2.500 0.707 *********************************************
Kitchen Buffet InCab Lights 3 0.170 1.802 2.500 1.066 ************************************
Kitchen Buffet UnderCab 3 0.167 1.801 2.500 1.067 ************************************
Kitchen Eyeball Lights 1 0.167 2.267 2.500 0.700 *********************************************
Kitchen KPL Main Entry Side 2 0.170 2.035 2.500 0.930 ****************************************
Kitchen KPL Master Bedroom Side 0 2.500 2.500 2.500 0.000 **************************************************
Kitchen KPL Mud Room Side 0 2.500 2.500 2.500 0.000 **************************************************
Kitchen LED UnderCab 1 0.181 2.268 2.500 0.696 *********************************************
Kitchen LineLinc Space 01 0 2.500 2.500 2.500 0.000 **************************************************
Kitchen Pub Table 0 2.500 2.500 2.500 0.000 **************************************************
Kitchen Range InCab Lights 1 0.166 2.267 2.500 0.700 *********************************************
Kitchen Sink InCab Lights 0 2.500 2.500 2.500 0.000 **************************************************
Kitchen Sink Lights 2 0.165 2.034 2.500 0.933 ****************************************
OutletLinc L/R Northeast Wall 1 0.169 2.267 2.500 0.699 *********************************************
OutletLinc L/R Southeast Wall 0 2.500 2.500 2.500 0.000 **************************************************
RemoteLinc2 0 2.500 2.500 2.500 0.000 **************************************************
Sheep Light 0 2.500 2.500 2.500 0.000 **************************************************
Shelter Inside 0 2.500 2.500 2.500 0.000 **************************************************
Shelter Outside 0 2.500 2.500 2.500 0.000 **************************************************
Shop Flood Light 0 2.500 2.500 2.500 0.000 **************************************************
Whole-house statistics:
Success rate: 29 / 310 9.4%
Good, bad, total devices: 0, 31, 31 (good means >=95% reachable)
Average RTT: 2.285
Fri Nov 02, 2012 6:50 am
Re: iHealth showing issues...?
Did you choose to disable the INSTEON interface in Indigo first? Both Indigo and iHealth cannot have an open connection to the PowerLinc at the same time.
Fri Nov 02, 2012 8:38 am
I did not, missed that! I also didn't remove some of the devices like remotelinc. Will do that now and see what happens.
Fri Nov 02, 2012 8:42 am
Starting it now, initially not looking much better (it's still running). I'm seeing a lot of PowerLinc errors in the log: Unexpected command 02 62 (flushing)
then a few unknown command bytes received 50 1B and 60 iC
Expected?
Wondering if there is something else I should be disabling.
I have a PowerLinc 2413U btw.
Fri Nov 02, 2012 8:44 am
If you are seeing errors in the Event Log, then Indigo is still communicating with the PowerLinc. You shouldn't see anything in the Event Log.
Fri Nov 02, 2012 8:56 am
I chose to disable it from the menu, and it seemed to do it, but sometime during the test run I saw a message pop-up that it had established communications. Can something trigger it back? Should I just shut down Indigo while it runs?
Fri Nov 02, 2012 9:03 am
A script or action you have might be reconnecting it. Just shutdown the Indigo Server and try it.
Fri Nov 02, 2012 9:24 am
OK, that worked, this looks better
Success rate: 210 / 210 100.0%
Good, bad, total devices: 21, 0, 21 (good means >=95% reachable)
Average RTT: 0.196
I ran it again with just the device I'm having issues with, this is the result:
Success rate: 10 / 10 100.0%
Good, bad, total devices: 1, 0, 1 (good means >=95% reachable)
Average RTT: 0.564
Looks like there is some long response times on that circuit. I guess I'll need to trace out that circuit and see if there is something plugged in on that circuit causing a problem. I think it is a pretty clean circuit, but I can make it cleaner first and see what happens.
Fri Nov 02, 2012 10:52 pm
I've been wanting to clean up that electrical circuit, had stuff on it that I did not want on it (or was totally sure where it went). This should be a straight dedicated run to the garage, so I now have it on a dedicated circuit. I re-ran the test, have a little bit better result.
Garage 10 0.167 0.265 0.810 0.198 *****
Average RTT: 0.265
I'll watch things and see if this device performs better now. If not, then I know there are only three things plugged into the garage, much easier to isolate any interference....
Fri Nov 02, 2012 10:59 pm
Posting this mostly so I have a record of it :-)
Reran the test with a couple of other devices in it for comparison. The Garage is a Switchlinc, added in a few KPL's that I have, most are dual band units.
Front Door - Main Entry 10 0.173 0.234 0.575 0.116 ****
Front Door - Mud Room 10 0.172 0.195 0.278 0.036 ***
Garage 10 0.169 0.246 0.432 0.099 ****
Kitchen KPL Master Side 10 0.165 0.240 0.717 0.164 ****
Kitchen KPL Mud Room Side 10 0.139 0.186 0.334 0.050 ***
Success rate: 50 / 50 100.0%
Good, bad, total devices: 5, 0, 5 (good means >=95% reachable)
Average RTT: 0.220
