iTunes Fade
Thu Feb 10, 2011 12:07 pm
Korey offline
iTunes Fade
I use this script when putting the house to sleep at night, if music is playing it will gradually fade out over time, then stop iTunes and reset the volume to your regular level.
Stole most of it from Doug's AppleScripts: http://dougscripts.com/itunes/
property tick : 1 -- change volume level by this many each loop
property thismany : 30 -- seconds to wait before making next change to volume
tell application "iTunes"
    repeat
        set snd to sound volume
        if snd is less than or equal to tick then
            set sound volume to 0
            exit repeat
        end if
        set sound volume to (snd - tick)
        delay thismany
    end repeat
    stop
end tell
    stop
    set sound volume to 40
end tell
Korey
Thu Feb 10, 2011 2:39 pm
Re: iTunes Fade
You'll want to make sure you run it as an external script - if it's embedded it'll hang up the server until it's finished running. Cool script, thanks!
Fri Feb 11, 2011 10:38 am
Korey offline
Re: iTunes Fade
Never thought of that! and of course trying to compile it in script editor give me errors.. :?:
Any applescript experts have any suggestions why I am getting this error in script editor and not when its compiled in Indigo as an embedded script?
Screen shot 2011-02-11 at 10.32.49 AM.png (70.9 KiB) Viewed 3149 times
Korey
Fri Feb 11, 2011 11:02 am
Re: iTunes Fade
From what I can see, it looks like your copy/paste didn't quite work - this line seems to be missing:
Fri Feb 11, 2011 12:34 pm
Korey offline
Re: iTunes Fade
Boy do I feel dumb, :oops: Thanks Jay!
Korey
