Remote Log File Viewer error on OS X 10.4
Thu Jan 22, 2009 11:25 pm
berkinet offline
I installed the "Remote Log File Viewer (http://www.perceptiveautomation.com/phpBB2/viewtopic.php?t=3987) and encountered the problem shown in the log entry below. At first I assumed this was a plugin problem, but the problem is reported from standard Indigo modules (cherrypy/) so now I'm not so sure. Anyway, in case this is a problem in v4, here it is.
Richard
Jan 22, 2009 9:14:06 PM
  WebServer          internal server error "http://192.168.4.94:8176/Eventlog/index" from 192.168.4.83
  WebServer
Request Headers:
  HOST: 192.168.4.94:8176
  ACCEPT: text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
  USER-AGENT: Mozilla/5.0 (Macintosh; U; PPC Mac OS X 10_4_11; en) AppleWebKit/525.27.1 (KHTML, like Gecko) Version/3.2.1 Safari/525.27.1
  CONNECTION: keep-alive
  Remote-Addr: 192.168.4.83
  ACCEPT-LANGUAGE: en
  ACCEPT-ENCODING: gzip, deflate
  File "/Library/Application Support/Perceptive Automation/Indigo 4/IndigoWebServer/cherrypy/_cprequest.py", line 606, in respond
    cherrypy.response.body = self.handler()
  File "/Library/Application Support/Perceptive Automation/Indigo 4/IndigoWebServer/cherrypy/_cpdispatch.py", line 24, in __call__
    return self.callable(*self.args, **self.kwargs)
  File "/Library/Application Support/Perceptive Automation/Indigo 4/IndigoWebServer/plugins/Eventlog/reqhandler.py", line 112, in index
    log_files.sort( reverse=True)
TypeError: sort() takes no keyword arguments
Thu Jan 22, 2009 11:38 pm
Re: web server issue
Hi Richard,
The problem appears to be that the Python sort() function prior to Python 2.4 doesn't have the reverse argument. OS X 10.5 runs Python 2.5.1, so it works there but if you are running 10.4, which uses Python 2.3.5, then you'll see the error.
This problem is specific to the Remote Log File Viewer plug-in, so you'll need to put in a request to Benjamin to modify it to not use that argument.
(FYI, I modified the title of your post to describe the problem a bit more accurately)
Fri Jan 23, 2009 12:58 am
berkinet offline
(No subject)
Matt:
That's it, I am on 10.4. Once again thanks for getting to the root of the problem so quickly.
Richard
Fri Jan 23, 2009 4:53 am
bschollnick2 offline
support wrote:
Hi Richard,
Darn it.... Good catch, I'll make a note of this, and work on a generic solution....
The sort can be disabled, but then it'll be displayed in a oldest to newest fashion.... Which runs counter to what your probably going to be doing with a log viewer....
I'll let you know the solution is...
Fri Jan 23, 2009 5:06 am
(No subject)
berkinet wrote:
Matt:
Richard
Right-o... After reviewing the python 2.35 documentation, I have a workaround that I would like to have you to test... Could you drop me a line at bschollnick AT gmail DOT com? I'll then send you a replacement file to use that should resolve your problem...
- Benjamin
Mon Feb 16, 2009 12:11 pm
New Version of Remote Log Viewer v1.31...
Folks,
The new version of the Indigo Remote Log Viewer is released. Version 1.31 is now available…
Please see the Remote Log Viewer page for more details…
Bug Fixes
* The RLV will now detect Indigo 2 & 3, and work seamlessly with Indigo v2, 3, and 4.
Eventlog_131.zip
http://www.schollnick.net/wordpress/
Mon Feb 16, 2009 2:12 pm
Re: New Version of Remote Log Viewer v1.31...
Terrific -- thanks for posting the update!
Mon Feb 16, 2009 3:05 pm
(No subject)
Benjamin,
If you don't mind, would you please add both of your great plugins to the file library? You don't have to upload the files if you don't want to, but just add an entry describing the general functionality. I really want people to be able to find this type of stuff more easily than searching the forums.
Tue Feb 17, 2009 11:24 am
(No subject)
Submitted...
Tue Feb 17, 2009 12:29 pm
(No subject)
I saw, thanks!!
