revised basic_mini views
Tue Oct 21, 2008 3:31 pm
jashaffner offline
(No subject)
That works. Was hoping that the path could be relative to either the plugin or the calling template. Thanks.
I tried using /turnon (turnoff, etc) for the url but then it would redirect to basicpage instead of the plugin. Does it mean that I would have to duplicate the code perhaps from indigoreqhandler.py into functions in plugin's reqhandler.py?
Tue Oct 21, 2008 4:59 pm
seaofclouds offline
(No subject)
AWESOME!
I was about to take the plunge when I saw your posting here. So that I can continue to contribute, and easily, can you please keep your code on github? I can then pull any changes back in.
Cheers!
jashaffner wrote:
Lets say that I have two templates in my plugin. What path can I use in templateA to include templateB? I tried a couple different paths but to no luck.
Thanks.
ps: i am attempting to port seaofcloud's work into a plugin just to learn how to make use of plugin architecture thus the reason for my posts within this thread.
Tue Oct 21, 2008 5:22 pm
(No subject)
I may not be following you, but if turnon is the name of your plugin, then you'd implement your functionality inside the
def index(self):
handler. If you wanted multiple functions, then you'd implement them in separate handlers. So, for instance, you could name your plugin "coolplugin" and define two handlers, "turnon" and "turnoff", then call them with:
/coolplugin/turnon
and
/coolplugin/turnoff
Does that answer your question?
Tue Oct 21, 2008 6:17 pm
jashaffner offline
(No subject)
When using basicpage, it contains links starting with /turnon, /turnoff, /setbrightness and they would redirect you back to basicpage.
I see that /basicpage is hardcoded in IWS/templates/reload.html. I was hoping that I could pass the "return_to_this_page" parameter. The more I think about it, the more it makes sense to try and make plugin as independent from the core as possible. In that case, I went ahead and duplicate some of the code before cleaning it up a bit.
seaofclouds, the plugin is yours to wrap it up and "certify" once someone tells me how to attach a zip file here. :)
cheers,
j
Tue Oct 21, 2008 6:27 pm
seaofclouds offline
(No subject)
not sure about uploading here, but you can always upload your zip file to a free service like: http://dropsend.com then share the link here, or through github where the code will likely stay hosted and maintained.
This rocks, by the way. can't wait to lighten up the README and how-to. Thanks again for all your hard work. :)
Tue Oct 21, 2008 6:28 pm
(No subject)
Yeah, in this case, where you want to have a URL that can turn devices on/off and then reload your page, duplicating the functionality is the best approach.
I'm glad to see someone using the plug-in architecture!
Regards,
Matt
Tue Oct 21, 2008 7:12 pm
jashaffner offline
(No subject)
http://myaccount.dropsend.com/file/ea679bd4cc67ac79
seaofclouds, you may want to add back action groups and variables sections and remove unnecessary files from css and/or images if any. Thank you!
Tue Oct 21, 2008 7:18 pm
jashaffner offline
(No subject)
Thank you for making it possible!
Thu Oct 23, 2008 12:09 pm
seaofclouds offline
use these mini_views as a desktop app
i just updated these mini_views and readme with instructions for creating a desktop app, using fluid:
have a look at:
http://github.com/seaofclouds/indigo-web/tree/master
SIDENOTE: i've got the beginnings of the plugin on github, and a good start at making these contributions more visible and accessible in plugin form. thanks!
http://github.com/seaofclouds/indigo-mini-view-plugin/
Thu Oct 23, 2008 1:13 pm
(No subject)
Excellent! Once you get them done, please add them to the User Contribution Library so they'll be easy to find! Thanks!
Thu Oct 23, 2008 1:16 pm
seaofclouds offline
(No subject)
@jashaffner, thanks for uploading. i definitely want to add action groups in, but have absolutely no idea how to do that. i can add an include, and style it, but when it comes to adding variables and such to the .py file, i'm completely lost. got a pointer? can i copy that code from elsewhere?
Thu Oct 23, 2008 3:58 pm
seaofclouds offline
converted to a plugin, thanks jashaffner!
you can get these mini views in plugin form from the file lib, and at:
currently, only on/off and brightness are supported in plugin form. i'm not as much of a python programmer as i am a designer, and i'm not sure how to get actions to display. please contribute, if you can.
Thu Oct 23, 2008 4:15 pm
(No subject)
Great, thanks. I added a note to your post in the file library about requiring 3.0.6. While the plug-in architecture has been around since 3.0, we had to make some non-backwards compatible changes in 3.0.6 when we moved to the next version of cherrypy, so any plugins will now require 3.0.6. (Fortunately I was the only one that had built any so it wasn't a huge deal to upgrade).
Thanks again!
Mon Oct 27, 2008 12:45 pm
jashaffner offline
(No subject)
Sorry for late reply. I either did not get notifications or totally missed the notifications.
If you have not added back the actions/variables sections, I can go in and add them back. I was in a hurry the other night and did not want you to wait too long for me.
Mon Oct 27, 2008 6:06 pm
thepainter offline
(No subject)
Just want to say 'Thanks' it looks GREAT and works really well with my 'Touch'. Thanks again for all the hard work to everyone involved.
