variable and execAndGo Web Server Plugins available
Tue Oct 07, 2008 2:56 pm
These have been up there for a while, but I've updated them to work with 3.0.6 (you have to be running 3.0.6):
variable - a plug-in that enables you to edit variables from a control page
execAndGo - a plug-in that will allow you to execute an action group then redirect back to a control page you specify
Have fun!
jay
Tue Oct 07, 2008 3:35 pm
Matt offline
(No subject)
I am surprised I have missed these in the past. I know i have had need from something like this in a few situations.
Can you post links to them?
Tue Oct 07, 2008 4:03 pm
(No subject)
They're in the file library. Everything in this forum (User Contributions) should be available there. OK, maybe not everything, if someone is hosting the download to their solution on their own site... :)
jay
Mon Mar 30, 2009 5:56 pm
(No subject)
These plugins are both still available since they are great examples of documented sample plug-ins, but note that Indigo 4.0 beta 6 and higher has this functionality rolled into the application.
Specifically, instead of using the execAndGo plugin, you can now specify both a client side action (ex: browse to another Control Page or URL) and a server side action (ex: execute an action group, toggle a device, etc.) directly in the Control Page editor UI.
Variable values can be edited from a Web browser via the main Variables table page. If you need to edit a variable value from a control page, then you can show the same browser page for the edit that automatically returns to the Control Page upon completion. It works the same as the Variable plug-in, but the URL you use is different. Instead of the Variable plug-in URL defined like this:
/variable/setVariable?name=SOME_VARIABLE_NAME&page=RETURN_PAGE_NAME
You can show the native edit variable page like this:
/editvarpage?name=SOME_VARIABLE_NAME&redirectPage=RETURN_PAGE_NAME
