Jandy Aqualink Pool / Spa Control - AppleScripts updated
Sat Dec 31, 2011 10:16 am
hamw offline
Re: Jandy Aqualink Pool / Spa Control - AppleScripts updated
I restart the macmini every morning at about 2:30. The plugin has been working well all day yesterday. When I tried it this AM, got the same broken socket error as described above. I checked the connection for the Autelis web page which was good. Went back to the reboot log and saw:
 Plugin "Action Collection" connected
  Plugin "Autelis Jandy" connected
  Plugin "Airfoil" connected
  Plugin "Growl" connected
  Plugin "iTunes" connected
  Plugin "Smartphone Radar" connected
  SQLite client connected
  SQLite                          client connected to Indigo Server
  Reflector                       starting reflector connection to https://XXXXXX.goprism.com
  SQLite                          client connected to sqlite_db
  SQLite                          logging all device state changes
  SQLite                          logging all variable value changes
  Plugin "Growl 1.0.4" started
  Plugin "Smartphone Radar 0.9.1" started
  Plugin "Airfoil 1.0.2" started
  Plugin "Autelis Jandy 1.0.1" started
  Plugin "Action Collection 1.0.2" started
  Smartphone Radar                Watching for smartphone 'Phone Ham' at address 00:26:08:XXXXXX.
  Smartphone Radar                Watching for smartphone 'Phone Marion' at address 00:26:4a:XXXXXX.
  Autelis Jandy                   Saved Plugin Configuration
  Autelis Jandy Error             Socket: 10.0.1.40:6000 failed to connect. Please check the plugin configuration.
  Plugin "iTunes 1.0.12" started
31Dec, 2011 2:24:15 AM
  Emails on POP server mail.comcast.net will be scanned every 10 minutes
Tried reloading the plugin again and got another "failed to connect" message. Restarted the Airport Express, reloaded the plugin and all was good.
As a test I rebooted the macmini just now and got the same error:
 Bonjour registered "Indigo - XXXXX"
  Indigo Cocoa client connected
  Reflector                       starting reflector connection to https://XXXXX.goprism.com
  Smartphone Radar                Watching for smartphone 'Phone Marion' at address 00:26:4a:XXXXX.
31Dec, 2011 11:18:29 AM
This time, however, simply reloading the plugin worked and I didn't have to restart the Airport Express. The difference may be that I had not tried executing a command yet, and so it had not thrown the broken pipe-socket error.
Have tried to adapt the plugin reload script for the Autelis and set it up to fire shortly after reboot, but this piece of code did not work:
plugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.AutelisJandy")
if plugin.isEnabled():
   plugin.restart()
Is the filename incorrect?
I'm sure I can work around this - but wanted you to be aware how the plugin was behaving.
Sat Dec 31, 2011 1:23 pm
nlagaros offline
OK - think I understand why the failed reconnect is occurring. My guess is that the socket connection between the Indigo plugin and the Autelis device is being kept open when your machine reboots in the morning. Do you shutdown Indigo cleanly as part of this process? If not, then the socket will stay open. The Autelis device allows only one TCP connection.
If you keep getting these socket errors - where the plugin stops working, would you mind putting the plugin in debug mode so we can capture the event and understand what is causing it to fail.
As far as restarting the plugin, you have the name almost correct. You want this: com.ssi.indigoplugin.AutelisJandy
Sat Dec 31, 2011 2:56 pm
hamw offline
Came home and the plugin was not connected. Turned on logging and tried to restart without success. Stopped IndigoServer and restarted. I put in some gaps and annotated a couple of important places.
Initial try and it did not hook up.
2011-12-31 15:29:51   Application   Reloading plugin "Autelis Jandy 1.0.1"
2011-12-31 15:29:51   Application   Stopping plugin "Autelis Jandy 1.0.1" (pid 794)
2011-12-31 15:29:52   Application   Plugin "Autelis Jandy" disconnected
2011-12-31 15:29:52   Application   Starting plugin "Autelis Jandy 1.0.1" (pid 989)
2011-12-31 15:29:52   Application   Plugin "Autelis Jandy" connected
2011-12-31 15:29:53   Application   Plugin "Autelis Jandy 1.0.1" started
2011-12-31 15:29:53   Autelis Jandy   Saved Plugin Configuration
2011-12-31 15:29:53   Autelis Jandy Error   Socket: 10.0.1.40:6000 failed to connect. Please check the plugin configuration.
Tried again and it hooked up.
2011-12-31 15:30:03   Application   Disabling plugin "Autelis Jandy 1.0.1"
2011-12-31 15:30:03   Application   Stopping plugin "Autelis Jandy 1.0.1" (pid 989)
2011-12-31 15:30:03   Received INSTEON   "Thermostat Fam Room" on (button 3)
2011-12-31 15:30:03   Application   Plugin "Autelis Jandy" disconnected
2011-12-31 15:30:11   Application   Enabling plugin "Autelis Jandy 1.0.1"
2011-12-31 15:30:11   Application   Starting plugin "Autelis Jandy 1.0.1" (pid 993)
2011-12-31 15:30:11   Application   Plugin "Autelis Jandy" connected
2011-12-31 15:30:12   Application   Plugin "Autelis Jandy 1.0.1" started
2011-12-31 15:30:12   Autelis Jandy   Saved Plugin Configuration
2011-12-31 15:30:12   Autelis Jandy   Socket: 10.0.1.40:6000 connected succesfully
Stop Indigo server and restart Indigo
2011-12-31 15:30:48   Application   Quiting Indigo Server - received slow quit signal
2011-12-31 15:30:48   Application   Quiting Indigo Server - stopping plugins
2011-12-31 15:30:48   Application   Stopping plugin "Smartphone Radar" (pid 232)
2011-12-31 15:30:48   Application   Stopping plugin "Action Collection" (pid 226)
2011-12-31 15:30:48   Application   Stopping plugin "Airfoil" (pid 227)
2011-12-31 15:30:48   Application   Stopping plugin "Growl" (pid 229)
2011-12-31 15:30:48   Application   Stopping plugin "iTunes" (pid 230)
2011-12-31 15:30:48   Application   Stopping plugin "Autelis Jandy" (pid 993)
2011-12-31 15:30:48   Autelis Jandy   Socket: 10.0.1.40:6000 closed succesfully
2011-12-31 15:30:49   Application   Plugin "iTunes" disconnected
2011-12-31 15:30:49   Application   Plugin "Autelis Jandy" disconnected
2011-12-31 15:30:49   Application   Plugin "Airfoil" disconnected
2011-12-31 15:30:49   Application   Plugin "Growl" disconnected
2011-12-31 15:30:49   Application   Plugin "Action Collection" disconnected
2011-12-31 15:30:49   Application   Plugin "Smartphone Radar" disconnected
2011-12-31 15:30:49   Application   Stopping embedded script executor host (pid 282)
2011-12-31 15:30:50   Application   Quiting Indigo Server - saving database
2011-12-31 15:30:51   Application   Quiting Indigo Server - saving preferences
2011-12-31 15:30:52   Application   Closed connection to PowerLinc 2413U
2011-12-31 15:30:52   Application   Quiting Indigo Server - disconnecting clients
2011-12-31 15:30:53   Application   Indigo Cocoa client disconnected
2011-12-31 15:30:54   Application   SQLite client disconnected
2011-12-31 15:30:55   Application   WebServer client disconnected
2011-12-31 15:30:55   Reflector   shutdown reflector connection
2011-12-31 15:30:57   Application   Quiting Indigo Server - unloading launchd plist
2011-12-31 15:30:57   Application   Stopped child process 245
2011-12-31 15:30:57   Application   Stopped child process 246
2011-12-31 15:30:57   Application   Quiting Indigo Server - complete
2011-12-31 15:30:58   Application   Starting Indigo Server version 5.0.2
2011-12-31 15:30:58   Application   Loading attachments
2011-12-31 15:30:58   Application   "audioAppControl.scpt" script loaded
2011-12-31 15:30:58   Application   "device target attachment.scpt" script loaded
2011-12-31 15:30:58   Application   "group target attachment.scpt" script loaded
2011-12-31 15:30:58   Application   "growl attachment.scpt" script loaded
2011-12-31 15:30:58   Application   "IRed The Remote Path.scpt" script loaded
2011-12-31 15:30:58   Application   "iTunes attachment.scpt" script loaded
2011-12-31 15:30:58   Application   "scenes attachment.scpt" script loaded
2011-12-31 15:30:58   Application   "ThermostatProcessor.scpt" script loaded
2011-12-31 15:30:58   Application   "time stamp attachment.scpt" script loaded
2011-12-31 15:30:59   Application   Loading plugin "Action Collection 1.0.2"
2011-12-31 15:30:59   Application   Starting plugin "Action Collection 1.0.2" (pid 1003)
2011-12-31 15:30:59   Application   Loading plugin "Airfoil 1.0.2"
2011-12-31 15:30:59   Application   Starting plugin "Airfoil 1.0.2" (pid 1004)
2011-12-31 15:30:59   Application   Loading plugin "Autelis Jandy 1.0.1"
2011-12-31 15:30:59   Application   Starting plugin "Autelis Jandy 1.0.1" (pid 1005)
2011-12-31 15:30:59   Application   Loading plugin "Growl 1.0.4"
2011-12-31 15:30:59   Application   Starting plugin "Growl 1.0.4" (pid 1006)
2011-12-31 15:30:59   Application   Loading plugin "iTunes 1.0.12"
2011-12-31 15:30:59   Application   Starting plugin "iTunes 1.0.12" (pid 1007)
2011-12-31 15:30:59   Application   Loading plugin "Smartphone Radar 0.9.1"
2011-12-31 15:31:00   Application   Starting plugin "Smartphone Radar 0.9.1" (pid 1008)
2011-12-31 15:31:00   Application   Found disabled plugin "DIRECTV DVR Control 1.0.0"
2011-12-31 15:31:00   Application   Found disabled plugin "EasyDAQ Relay Card 1.0.11"
2011-12-31 15:31:00   Application   Found disabled plugin "Find My IDevices 1.20"
2011-12-31 15:31:00   Application   Found disabled plugin "iCal Alarm Processor 1.0.1"
2011-12-31 15:31:00   Application   Found disabled plugin "NOAA Weather 1.0.0"
2011-12-31 15:31:00   Application   Found disabled plugin "WeatherSnoop 1.0.1"
2011-12-31 15:31:00   Application   Bonjour registered "Indigo - xxxxx"
2011-12-31 15:31:00   Application   Plugin "Action Collection" connected
2011-12-31 15:31:00   Application   Plugin "Airfoil" connected
2011-12-31 15:31:00   Application   Plugin "Autelis Jandy" connected
2011-12-31 15:31:00   Application   Plugin "Growl" connected
2011-12-31 15:31:00   Application   Plugin "Smartphone Radar" connected
2011-12-31 15:31:00   Application   Plugin "iTunes" connected
2011-12-31 15:31:01   Application   Plugin "Autelis Jandy 1.0.1" started
2011-12-31 15:31:01   Autelis Jandy Debug   Getting Plugin Configuration Settings
2011-12-31 15:31:01   Autelis Jandy Debug       Connection Type: Socket
2011-12-31 15:31:01   Autelis Jandy Debug       Socket IP:        10.0.1.40
2011-12-31 15:31:01   Autelis Jandy Debug       Socket Port:      6000
2011-12-31 15:31:01   Autelis Jandy Debug       Aux Devices:      03
2011-12-31 15:31:01   Autelis Jandy Debug       Aux 01:           Aux 1
2011-12-31 15:31:01   Autelis Jandy Debug       Aux 02:           Aux 2
2011-12-31 15:31:01   Autelis Jandy Debug       Aux 03:           Light
2011-12-31 15:31:01   Autelis Jandy   Saved Plugin Configuration
2011-12-31 15:31:01   Autelis Jandy Debug   Opening connection....
2011-12-31 15:31:01   Autelis Jandy   Socket: 10.0.1.40:6000 connected succesfully
In the line above AutelisJandy connects successfully.
2011-12-31 15:31:01   Autelis Jandy Debug   TX: #AUX1?
2011-12-31 15:31:02   Application   Plugin "Smartphone Radar 0.9.1" started
2011-12-31 15:31:02   Smartphone Radar   Watching for smartphone 'Phone Ham' at address .
2011-12-31 15:31:02   Autelis Jandy Debug   TX: #AUX2?
2011-12-31 15:31:02   Smartphone Radar   Watching for smartphone 'Phone Marion' at address
2011-12-31 15:31:02   Application   Plugin "Growl 1.0.4" started
2011-12-31 15:31:02   Autelis Jandy Debug   TX: #AIRTMP?
2011-12-31 15:31:02   Reflector   starting reflector connection to https://xxxxxx.goprism.com
2011-12-31 15:31:02   Autelis Jandy Debug   TX: #POOLHT?
2011-12-31 15:31:02   Autelis Jandy Debug   TX: #POOLHT2?
2011-12-31 15:31:02   Application   SQLite client connected
2011-12-31 15:31:03   Autelis Jandy Debug   TX: #POOLSP?
2011-12-31 15:31:03   Autelis Jandy Debug   TX: #POOLSP2?
2011-12-31 15:31:03   Application   Plugin "Action Collection 1.0.2" started
2011-12-31 15:31:03   Autelis Jandy Debug   TX: #POOLTMP?
2011-12-31 15:31:03   SQLite   client connected to Indigo Server
2011-12-31 15:31:03   Autelis Jandy Debug   TX: #PUMP?
2011-12-31 15:31:03   SQLite   client connected to sqlite_db
2011-12-31 15:31:03   SQLite   logging all device state changes
2011-12-31 15:31:03   SQLite   logging all variable value changes
2011-12-31 15:31:04   Application   Plugin "Airfoil 1.0.2" started
2011-12-31 15:31:04   Autelis Jandy Debug   TX: #PUMPLO?
2011-12-31 15:31:04   Autelis Jandy Debug   TX: #SPA?
2011-12-31 15:31:04   Autelis Jandy Debug   TX: #SPAHT?
2011-12-31 15:31:04   Autelis Jandy Debug   TX: #SPASP?
2011-12-31 15:31:04   Application   Plugin "iTunes 1.0.12" started
2011-12-31 15:31:05   Autelis Jandy Debug   TX: #SPATMP?
2011-12-31 15:31:05   Autelis Jandy Debug   TX: #SOLHT?
2011-12-31 15:31:05   Autelis Jandy Debug   TX: #SOLTMP?
2011-12-31 15:31:05   Autelis Jandy Debug   TX: #OPMODE?
2011-12-31 15:31:06   Autelis Jandy Debug   TX: #WFALL?
2011-12-31 15:31:06   Autelis Jandy Debug   TX: #CLEANR?
2011-12-31 15:31:06   Autelis Jandy Debug   TX: #VBAT?
2011-12-31 15:31:06   Autelis Jandy Debug   TX: #OPTIONS?
2011-12-31 15:31:07   Autelis Jandy Debug   TX: #MODEL?
2011-12-31 15:31:07   Autelis Jandy Debug   TX: #UNITS?
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 AUX1=0
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: AUX1, Value: off
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 AUX2=0
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: AUX2, Value: off
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 AIRTMP=55 F
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: AIRTMP, Value: 55 F
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 POOLHT=0
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: POOLHT, Value: off
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 POOLHT2=0
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: POOLHT2, Value: off
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 POOLSP=87 F
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: POOLSP, Value: 87 F
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 POOLSP2=60 F
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: POOLSP2, Value: 60 F
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 POOLTMP=49 F
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: POOLTMP, Value: 49 F
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 PUMP=1
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: PUMP, Value: on
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 PUMPLO=0
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: PUMPLO, Value: off
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 SPA=0
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: SPA, Value: off
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 SPAHT=0
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: SPAHT, Value: off
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 SPASP=102 F
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: SPASP, Value: 102 F
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 SPATMP=0 F
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: SPATMP, Value: 0 F
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 SOLHT=0
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 SOLTMP=0 F
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 OPMODE=AUTO
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: OPMODE, Value: AUTO
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 WFALL=0
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: WFALL, Value: off
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 CLEAN=0
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: CLEAN, Value: off
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 VBAT=900
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: VBAT, Value: 900
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 OPTIONS=1
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: OPTIONS, Value: 1
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 MODEL=6520
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: MODEL, Value: 6520
2011-12-31 15:31:07   Autelis Jandy Debug   RX: !00 UNITS=F
2011-12-31 15:31:07   Autelis Jandy Debug       Updating Device: Pool, State: UNITS, Value: F
2011-12-31 15:31:08   Application   Indigo Cocoa client connected
2011-12-31 15:31:11   Application   WebServer client connected
2011-12-31 15:31:11   WebServer   started on port xxxx -- digest authentication enabled
2011-12-31 15:31:11   WebServer   loaded plugin "Find My iDevices"
2011-12-31 15:31:11   WebServer   enabled browser access to plugin path "plugins/Find-My-iDevices/css"
2011-12-31 15:31:11   WebServer   enabled browser access to plugin path "plugins/Find-My-iDevices/images"
2011-12-31 15:31:11   WebServer   enabled browser access to plugin path "plugins/Find-My-iDevices/js"
2011-12-31 15:31:11   WebServer   enabled browser access to plugin path "plugins/Find-My-iDevices/static"
2011-12-31 15:31:12   Application   Emails on POP server mail.comcast.net will be scanned every 10 minutes
2011-12-31 15:31:12   Trigger   iTunes Sync Script
2011-12-31 15:31:12   Trigger   Airfoil PandoraBoy iTunes
2011-12-31 15:31:12   Trigger   Serial Bridge Quit and Restart
2011-12-31 15:31:12   Trigger   Hide TeamViewer and iTunes
2011-12-31 15:31:12   Trigger   iTunes Sync Script copy
2011-12-31 15:31:12   iTunes Sync   iTunes Sync Script Launched
2011-12-31 15:31:12   IndigoStatus Updater   PandoraBoyIsRunning Changed from "" to "false"
2011-12-31 15:31:12   IndigoStatus Updater   AirFoilIsRunning Changed from "" to "true"
2011-12-31 15:31:12   Application   Connected to PowerLinc 2413U interface on port usbserial-A600exMb
2011-12-31 15:31:12   Application   PowerLinc address 18.D2.39, firmware version 9.2
2011-12-31 15:31:12   IndigoStatus Updater   AirFoilCurrentSource Changed from "" to "System Audio"
2011-12-31 15:31:12   IndigoStatus Updater   AirFoilSpeakerComputerConnected Changed from "" to "true"
2011-12-31 15:31:12   IndigoStatus Updater   AirFoilSpeakerClubhouseFeedConnected Changed from "" to "false"
2011-12-31 15:31:12   IndigoStatus Updater   AirFoilSpeakerDaddysiMaclocalConnected Changed from "" to "false"
2011-12-31 15:31:12   IndigoStatus Updater   iTunesIsRunning Changed from "" to "true"
2011-12-31 15:31:46   Autelis Jandy Debug   RX: !00 AIRTMP=56 F
2011-12-31 15:31:46   Autelis Jandy Debug       Updating Device: Pool, State: AIRTMP, Value: 56 F
2011-12-31 15:31:46   Received INSTEON   "Thermostat MBR" humidity changed to 44.0
2011-12-31 15:32:12   Schedule   Serial Bridge Quit and Restart (delayed action)
2011-12-31 15:32:12   Action Group   Serial Bridge Quit and Restart Action Group
2011-12-31 15:32:12   Schedule   Hide TeamViewer and iTunes (delayed action)
2011-12-31 15:32:24   Schedule   Serial Bridge Quit and Restart (delayed action)
2011-12-31 15:32:41   WebServer   Indigo Touch client connected from 10.0.1.50
2011-12-31 15:32:49   Autelis Jandy Debug   TX: #AUX3
2011-12-31 15:32:49   Autelis Jandy Debug   RX: !00 AUX3=1
2011-12-31 15:32:49   Autelis Jandy Debug       Updating Device: Pool, State: AUX3, Value: on
2011-12-31 15:32:51   Received INSTEON   "Thermostat Fam Study" humidity changed to 45.0
2011-12-31 15:32:52   Received INSTEON   "Thermostat MBR" humidity changed to 45.0
2011-12-31 15:32:59   Autelis Jandy Debug   TX: CLEANR
2011-12-31 15:33:00   Autelis Jandy Debug   RX: !00 CLEAN=1
2011-12-31 15:33:00   Autelis Jandy Debug       Updating Device: Pool, State: CLEAN, Value: on
2011-12-31 15:33:08   Autelis Jandy Debug   TX: CLEANR
2011-12-31 15:33:09   Autelis Jandy Debug   RX: !00 CLEAN=0
2011-12-31 15:33:09   Autelis Jandy Debug       Updating Device: Pool, State: CLEAN, Value: off
2011-12-31 15:33:31   Autelis Jandy Debug   RX: !00 AIRTMP=55 F
2011-12-31 15:33:31   Autelis Jandy Debug       Updating Device: Pool, State: AIRTMP, Value: 55 F
Restarted Mac Mini by going to file:restart. Should be a clean stop and restart of Indigo
2011-12-31 15:33:48   Application   Indigo Cocoa client disconnected
2011-12-31 15:33:51   Application   Quiting Indigo Server - received quit event
2011-12-31 15:33:51   Application   Quiting Indigo Server - stopping plugins
2011-12-31 15:33:51   Application   Stopping plugin "Smartphone Radar" (pid 1008)
2011-12-31 15:33:51   Application   Stopping plugin "Action Collection" (pid 1003)
2011-12-31 15:33:51   Application   Stopping plugin "Airfoil" (pid 1004)
2011-12-31 15:33:51   Application   Stopping plugin "Growl" (pid 1006)
2011-12-31 15:33:51   Application   Stopping plugin "iTunes" (pid 1007)
2011-12-31 15:33:51   Application   Stopping plugin "Autelis Jandy" (pid 1005)
2011-12-31 15:33:51   Autelis Jandy Debug   Method: stopConcurrentThread
2011-12-31 15:33:51   Autelis Jandy   Socket: 10.0.1.40:6000 closed succesfully
In the line above, AutelisJandy successfully closes the socket.
2011-12-31 15:33:51   Autelis Jandy Debug   Method: shutdown
2011-12-31 15:33:52   Application   Plugin "Action Collection" disconnected
2011-12-31 15:33:52   Application   Plugin "Growl" disconnected
2011-12-31 15:33:52   Application   Plugin "Airfoil" disconnected
2011-12-31 15:33:52   Application   Plugin "Autelis Jandy" disconnected
2011-12-31 15:33:53   Application   Plugin "Smartphone Radar" disconnected
2011-12-31 15:33:56   Application   Plugin "iTunes" disconnected
2011-12-31 15:33:56   Application   Quiting Indigo Server - saving database
2011-12-31 15:33:57   Application   Quiting Indigo Server - saving preferences
2011-12-31 15:33:59   Application   Closed connection to PowerLinc 2413U
2011-12-31 15:33:59   Application   Quiting Indigo Server - disconnecting clients
2011-12-31 15:33:59   Application   SQLite client disconnected
2011-12-31 15:34:00   Application   WebServer client disconnected
2011-12-31 15:34:00   Reflector   shutdown reflector connection
2011-12-31 15:34:03   Application   Quiting Indigo Server - unloading launchd plist
2011-12-31 15:34:03   Application   Stopped child process 1016
2011-12-31 15:34:03   Application   Stopped child process 1017
2011-12-31 15:34:03   Application   Stopped child process 1018
2011-12-31 15:34:03   Application   Quiting Indigo Server - complete
Starting now.
2011-12-31 15:35:34   Application   Starting Indigo Server version 5.0.2
2011-12-31 15:35:34   Application   Loading attachments
2011-12-31 15:35:34   Application   "audioAppControl.scpt" script loaded
2011-12-31 15:35:34   Application   "device target attachment.scpt" script loaded
2011-12-31 15:35:34   Application   "group target attachment.scpt" script loaded
2011-12-31 15:35:34   Application   "growl attachment.scpt" script loaded
2011-12-31 15:35:34   Application   "IRed The Remote Path.scpt" script loaded
2011-12-31 15:35:34   Application   "iTunes attachment.scpt" script loaded
2011-12-31 15:35:34   Application   "scenes attachment.scpt" script loaded
2011-12-31 15:35:34   Application   "ThermostatProcessor.scpt" script loaded
2011-12-31 15:35:34   Application   "time stamp attachment.scpt" script loaded
2011-12-31 15:35:41   Application   Loading plugin "Action Collection 1.0.2"
2011-12-31 15:35:41   Application   Starting plugin "Action Collection 1.0.2" (pid 227)
2011-12-31 15:35:41   Application   Loading plugin "Airfoil 1.0.2"
2011-12-31 15:35:41   Application   Starting plugin "Airfoil 1.0.2" (pid 228)
2011-12-31 15:35:41   Application   Loading plugin "Autelis Jandy 1.0.1"
2011-12-31 15:35:41   Application   Starting plugin "Autelis Jandy 1.0.1" (pid 229)
2011-12-31 15:35:42   Application   Loading plugin "Growl 1.0.4"
2011-12-31 15:35:42   Application   Starting plugin "Growl 1.0.4" (pid 230)
2011-12-31 15:35:42   Application   Loading plugin "iTunes 1.0.12"
2011-12-31 15:35:42   Application   Starting plugin "iTunes 1.0.12" (pid 231)
2011-12-31 15:35:42   Application   Loading plugin "Smartphone Radar 0.9.1"
2011-12-31 15:35:42   Application   Starting plugin "Smartphone Radar 0.9.1" (pid 232)
2011-12-31 15:35:42   Application   Found disabled plugin "DIRECTV DVR Control 1.0.0"
2011-12-31 15:35:42   Application   Found disabled plugin "EasyDAQ Relay Card 1.0.11"
2011-12-31 15:35:42   Application   Found disabled plugin "Find My IDevices 1.20"
2011-12-31 15:35:42   Application   Found disabled plugin "iCal Alarm Processor 1.0.1"
2011-12-31 15:35:42   Application   Found disabled plugin "NOAA Weather 1.0.0"
2011-12-31 15:35:42   Application   Found disabled plugin "WeatherSnoop 1.0.1"
2011-12-31 15:35:42   Application   Bonjour registered "Indigo - xxxxx"
2011-12-31 15:35:42   Application   Indigo Cocoa client connected
2011-12-31 15:35:43   Application   Plugin "Autelis Jandy" connected
2011-12-31 15:35:43   Application   Plugin "Action Collection" connected
2011-12-31 15:35:43   Application   Plugin "Airfoil" connected
2011-12-31 15:35:43   Application   Plugin "Growl" connected
2011-12-31 15:35:43   Application   Plugin "iTunes" connected
2011-12-31 15:35:43   Application   Plugin "Smartphone Radar" connected
2011-12-31 15:35:44   Application   SQLite client connected
2011-12-31 15:35:44   SQLite   client connected to Indigo Server
2011-12-31 15:35:44   SQLite   client connected to sqlite_db
2011-12-31 15:35:44   SQLite   logging all device state changes
2011-12-31 15:35:44   SQLite   logging all variable value changes
2011-12-31 15:35:45   Reflector   starting reflector connection to https://xxxxx.goprism.com
2011-12-31 15:35:46   Application   Plugin "Growl 1.0.4" started
2011-12-31 15:35:46   Application   Plugin "Action Collection 1.0.2" started
2011-12-31 15:35:46   Application   Plugin "Smartphone Radar 0.9.1" started
2011-12-31 15:35:46   Smartphone Radar   Watching for smartphone 'Phone Ham' at address .
2011-12-31 15:35:46   Smartphone Radar   Watching for smartphone 'Phone Marion' at address .
2011-12-31 15:35:46   Application   Plugin "Autelis Jandy 1.0.1" started
2011-12-31 15:35:46   Application   Plugin "Airfoil 1.0.2" started
2011-12-31 15:35:46   Autelis Jandy Debug   Getting Plugin Configuration Settings
2011-12-31 15:35:46   Autelis Jandy Debug       Connection Type: Socket
2011-12-31 15:35:46   Autelis Jandy Debug       Socket IP:        10.0.1.40
2011-12-31 15:35:46   Autelis Jandy Debug       Socket Port:      6000
2011-12-31 15:35:46   Autelis Jandy Debug       Aux Devices:      03
2011-12-31 15:35:46   Autelis Jandy Debug       Aux 01:           Aux 1
2011-12-31 15:35:46   Autelis Jandy Debug       Aux 02:           Aux 2
2011-12-31 15:35:46   Autelis Jandy Debug       Aux 03:           Light
2011-12-31 15:35:46   Autelis Jandy   Saved Plugin Configuration
2011-12-31 15:35:46   Autelis Jandy Debug   Opening connection....
2011-12-31 15:35:46   Application   Plugin "iTunes 1.0.12" started
2011-12-31 15:35:47   Autelis Jandy Error   Socket: 10.0.1.40:6000 failed to connect. Please check the plugin configuration.
Note in the line above that AutelisJandy failed to connect despite clean close and open of Indigo.
2011-12-31 15:35:50   Application   Emails on POP server mail.comcast.net will be scanned every 10 minutes
2011-12-31 15:35:50   Trigger   iTunes Sync Script
2011-12-31 15:35:50   Trigger   Airfoil PandoraBoy iTunes
2011-12-31 15:35:50   Trigger   Serial Bridge Quit and Restart
2011-12-31 15:35:50   Trigger   Hide TeamViewer and iTunes
2011-12-31 15:35:50   Trigger   iTunes Sync Script copy
2011-12-31 15:35:51   iTunes Sync   iTunes Sync Script Launched
2011-12-31 15:35:51   Application   Connected to PowerLinc 2413U interface on port usbserial-A600exMb
2011-12-31 15:35:51   Application   PowerLinc address 18.D2.39, firmware version 9.2
2011-12-31 15:35:51   Application   WebServer client connected
2011-12-31 15:35:51   WebServer   started on port xxxx -- digest authentication enabled
2011-12-31 15:35:51   WebServer   loaded plugin "Find My iDevices"
2011-12-31 15:35:51   WebServer   enabled browser access to plugin path "plugins/Find-My-iDevices/css"
2011-12-31 15:35:51   WebServer   enabled browser access to plugin path "plugins/Find-My-iDevices/images"
2011-12-31 15:35:51   WebServer   enabled browser access to plugin path "plugins/Find-My-iDevices/js"
2011-12-31 15:35:51   WebServer   enabled browser access to plugin path "plugins/Find-My-iDevices/static"
2011-12-31 15:35:52   IndigoStatus Updater   PandoraBoyIsRunning Changed from "" to "false"
2011-12-31 15:35:52   IndigoStatus Updater   AirFoilIsRunning Changed from "" to "true"
2011-12-31 15:35:52   IndigoStatus Updater   AirFoilCurrentSource Changed from "" to "System Audio"
2011-12-31 15:35:52   IndigoStatus Updater   AirFoilSpeakerComputerConnected Changed from "" to "true"
2011-12-31 15:35:52   IndigoStatus Updater   AirFoilSpeakerDaddysiMaclocalConnected Changed from "" to "false"
2011-12-31 15:35:52   IndigoStatus Updater   AirFoilSpeakerClubhouseFeedConnected Changed from "" to "false"
2011-12-31 15:35:52   IndigoStatus Updater   iTunesIsRunning Changed from "" to "true"
2011-12-31 15:36:05   Received INSTEON   "Thermostat Fam Study" humidity changed to 44.0
2011-12-31 15:36:09   Received INSTEON   "Thermostat MBR" humidity changed to 45.0
Reloaded AutelisJandy Plugin, which worked this time. No other interventions.
2011-12-31 15:36:34   Application   Reloading plugin "Autelis Jandy 1.0.1"
2011-12-31 15:36:34   Application   Stopping plugin "Autelis Jandy 1.0.1" (pid 229)
2011-12-31 15:36:34   Autelis Jandy Debug   Method: stopConcurrentThread
2011-12-31 15:36:35   Autelis Jandy Debug   Method: stopConcurrentThread
2011-12-31 15:36:35   Autelis Jandy Debug   Method: shutdown
2011-12-31 15:36:36   Application   Plugin "Autelis Jandy" disconnected
2011-12-31 15:36:36   Application   Starting plugin "Autelis Jandy 1.0.1" (pid 264)
2011-12-31 15:36:36   Application   Plugin "Autelis Jandy" connected
2011-12-31 15:36:36   Application   Plugin "Autelis Jandy 1.0.1" started
2011-12-31 15:36:36   Autelis Jandy Debug   Getting Plugin Configuration Settings
2011-12-31 15:36:36   Autelis Jandy Debug       Connection Type: Socket
2011-12-31 15:36:36   Autelis Jandy Debug       Socket IP:        10.0.1.40
2011-12-31 15:36:36   Autelis Jandy Debug       Socket Port:      6000
2011-12-31 15:36:36   Autelis Jandy Debug       Aux Devices:      03
2011-12-31 15:36:36   Autelis Jandy Debug       Aux 01:           Aux 1
2011-12-31 15:36:36   Autelis Jandy Debug       Aux 02:           Aux 2
2011-12-31 15:36:36   Autelis Jandy Debug       Aux 03:           Light
2011-12-31 15:36:36   Autelis Jandy   Saved Plugin Configuration
2011-12-31 15:36:36   Autelis Jandy Debug   Opening connection....
2011-12-31 15:36:36   Autelis Jandy   Socket: 10.0.1.40:6000 connected succesfully
2011-12-31 15:36:36   Autelis Jandy Debug   TX: #AUX1?
2011-12-31 15:36:36   Autelis Jandy Debug   TX: #AUX2?
2011-12-31 15:36:37   Autelis Jandy Debug   TX: #AIRTMP?
2011-12-31 15:36:37   Autelis Jandy Debug   TX: #POOLHT?
2011-12-31 15:36:37   Autelis Jandy Debug   TX: #POOLHT2?
2011-12-31 15:36:37   Received INSTEON   "Thermostat GameRm" temperature changed to 59.0
2011-12-31 15:36:37   Autelis Jandy Debug   TX: #POOLSP?
2011-12-31 15:36:38   Autelis Jandy Debug   TX: #POOLSP2?
2011-12-31 15:36:38   Autelis Jandy Debug   TX: #POOLTMP?
2011-12-31 15:36:38   Received INSTEON   "Thermostat GameRm" temperature changed to 59.0
2011-12-31 15:36:38   Autelis Jandy Debug   TX: #PUMP?
2011-12-31 15:36:38   Autelis Jandy Debug   TX: #PUMPLO?
2011-12-31 15:36:39   Autelis Jandy Debug   TX: #SPA?
2011-12-31 15:36:39   Autelis Jandy Debug   TX: #SPAHT?
2011-12-31 15:36:39   Autelis Jandy Debug   TX: #SPASP?
2011-12-31 15:36:39   Autelis Jandy Debug   TX: #SPATMP?
2011-12-31 15:36:40   Autelis Jandy Debug   TX: #SOLHT?
2011-12-31 15:36:40   Autelis Jandy Debug   TX: #SOLTMP?
2011-12-31 15:36:40   Autelis Jandy Debug   TX: #OPMODE?
2011-12-31 15:36:40   Autelis Jandy Debug   TX: #WFALL?
2011-12-31 15:36:41   Autelis Jandy Debug   TX: #CLEANR?
2011-12-31 15:36:41   Autelis Jandy Debug   TX: #VBAT?
2011-12-31 15:36:41   Autelis Jandy Debug   TX: #OPTIONS?
2011-12-31 15:36:41   Autelis Jandy Debug   TX: #MODEL?
2011-12-31 15:36:42   Autelis Jandy Debug   TX: #UNITS?
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 AUX1=0
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: AUX1, Value: off
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 AUX2=0
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: AUX2, Value: off
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 AIRTMP=55 F
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: AIRTMP, Value: 55 F
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 POOLHT=0
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: POOLHT, Value: off
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 POOLHT2=0
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: POOLHT2, Value: off
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 POOLSP=87 F
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: POOLSP, Value: 87 F
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 POOLSP2=60 F
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: POOLSP2, Value: 60 F
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 POOLTMP=49 F
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: POOLTMP, Value: 49 F
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 PUMP=1
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: PUMP, Value: on
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 PUMPLO=0
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: PUMPLO, Value: off
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 SPA=0
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: SPA, Value: off
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 SPAHT=0
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: SPAHT, Value: off
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 SPASP=102 F
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: SPASP, Value: 102 F
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 SPATMP=0 F
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: SPATMP, Value: 0 F
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 SOLHT=0
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 SOLTMP=0 F
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 OPMODE=AUTO
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: OPMODE, Value: AUTO
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 WFALL=0
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: WFALL, Value: off
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 CLEAN=0
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: CLEAN, Value: off
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 VBAT=900
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: VBAT, Value: 900
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 OPTIONS=1
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: OPTIONS, Value: 1
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 MODEL=6520
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: MODEL, Value: 6520
2011-12-31 15:36:42   Autelis Jandy Debug   RX: !00 UNITS=F
2011-12-31 15:36:42   Autelis Jandy Debug       Updating Device: Pool, State: UNITS, Value: F
Looks like even though Indigo got a slow stop from the Restart and closed the socket, the plugin was unable to open the socket on restart of Indigo. After a slight delay the plugin was successfully reloaded manually
Sun Jan 01, 2012 12:28 am
hamw offline
One other thing that might be good is if the Autelis' time can be enabled in the plugin. That way if the time was current it would confirm on the control page that the connection is up.
****Edit**** While it is possible that my WiFi connection is dropping on occasion which is adding to the problem, I stacked several heavy gauge pans and a thick wood panel in front of the router. That dropped the dB from about 74 signal 79 noise to 78 signal 83 noise without dropping the connection. Nonetheless something still may be happening. I've posted a note to the Autelis forum for their input under the "Disconnected?" thread. http://www.autelis.com/forum/viewtopic.php?f=4&t=47&sid=75ce2ef8aa5699c230489a906ddf2201
Do you think there might be a way to have Indigo monitor the connection status? Maybe compare the time string from the Autelis with the time string from Indigo, and if too different, suggesting it's offline, force reboot/reload? I found and adapted a script to reboot the AP and can also reload the plugin.
tell application "AirPort Utility" to activate
delay 2
tell application "System Events"
   tell application process "AirPort Utility"
      tell window 1
         select row 2 of table 1 of scroll area 1  --my AirPort Express is the second listed in the Airport Utility window
         click button "Manual Setup"
         delay 20
      end tell
      tell menu bar 1
         click menu bar item "Base Station"
         tell menu bar item "Base Station"
            tell menu 1
               click menu item "Restart…"
            end tell
         end tell
      end tell
      delay 1 --imperative
      delay 30
   end tell
end tell
tell application "AirPort Utility" to quit
plugin = indigo.server.getPlugin("com.ssi.indigoplugin.AutelisJandy")
   plugin.restart()
Sun Jan 01, 2012 10:19 am
hamw offline
Here's another surprising thing: although the plugin is currently throwing these errors, it executed each of the commands and *appears* to be functioning normally.
1Jan, 2012 11:16:53 AM
  Autelis Jandy Error             Error in plugin execution ExecuteAction:
  File "plugin.py", line 57, in actionAux
  File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/AutelisJandy.indigoPlugin/Contents/Server Plugin/Autelis.py", line 148, in actionGeneric
  File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/AutelisJandy.indigoPlugin/Contents/Server Plugin/Autelis.py", line 105, in sendMessage
<class 'socket.error'>: (32, 'Broken pipe')
  Received INSTEON                "Thermostat MBR" temperature changed to 66.0
  Error                           script error: Can’t make characters 12 thru -1 of "" into type string. (-1700)
  File "plugin.py", line 66, in actionSetpoints
  File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/AutelisJandy.indigoPlugin/Contents/Server Plugin/Autelis.py", line 194, in actionGeneric
  Received INSTEON                "Thermostat Main Bedrooms" temperature changed to 65.0
Sun Jan 01, 2012 10:56 pm
hamw offline
In trying to monitor if the plugin is actually working, I set up a schedule to turn Aux5 on and off at three minute intervals. I would like to log the event and so was going to create a trigger to log the state change of Aux5. I might be going about this the wrong way, but although the plugin loaded correctly it doesn't look like the states are exposed for triggers.
AutelisJandy not in trigger list.jpg (148.46 KiB) Viewed 5129 times
Sun Jan 01, 2012 11:11 pm
asw24b offline
Don't you just want to use a "Device state changed" trigger, selecting the device instance of the plugin for your pool ?
Mike
Mon Jan 02, 2012 9:07 am
hamw offline
That looks like the way to do it. No more late night posts!! Thanks!
Mon Jan 02, 2012 10:01 am
hamw offline
OK I think there may be something here. I have a "Recent Activity" script for the log set up (viewtopic.php?f=4&t=6057)that I've used to trigger a restart of the plugin whenever this condition "value of variable "RecentActivity1" contains ("line 57, in actionAux" as string) is found. Looking at the log, the plugin runs about 15-20 minutes before it starts to generate errors. After about 5-10 minutes of these errors the trigger will catch the error and force a restart of the plugin, more or less successfully. The plugin runs again for 15-20 min and then starts to throw errors.
Serendipitously I have iStat Menus installed. I saw that the CPU usage began to climb, and it seems to be due to the Indigo Plugin Host Process. See the attached images and an excerpt from the log file. You can see in the log at the bottom of the first image that the trigger has fired and the plugin's reload is initiated. The second image shows resolution of the high CPU usage. (Also, what editor would I use to save the python reload script as an external script?)
Hope this is helpful.
Automatic ReStart
  Action Group                    Pool Autelis Plugin Reload
  Stopping plugin "Autelis Jandy 1.0.1" (pid 1095)
  Error                           because embedded scripts execute sequentially they must complete their execution within 10 seconds.
  Script Error                    embedded script: ServerCommunicationError -- timeout waiting for server response
  Error                           modify the script to exit quickly or convert it to an external file (not embedded).
     embedded script, line 3, at top level
StandardError: ServerCommunicationError -- timeout waiting for server response
  Stopping embedded script executor host (pid 1062)
  Error                           process (pid 1095) failed to quit after polite request -- forcing it to quit now
  Starting plugin "Autelis Jandy 1.0.1" (pid 1160)
  Received INSTEON                "Thermostat Fam Study" humidity changed to 37.0
2Jan, 2012 5:47:59 AM
  Received INSTEON                "Thermostat Main Bedrooms" humidity changed to 36.0
  Schedule                        pool on/off
  Received INSTEON                "Thermostat Main Bedrooms" mode changed to all off; fan auto on
  Received INSTEON                "Thermostat Main Bedrooms" mode changed to auto on; fan auto on
  Schedule                        pool on/off (delayed action)
2Jan, 2012 5:49:14 AM
  Received INSTEON                "Thermostat Main Bedrooms" humidity changed to 37.0
2Jan, 2012 5:49:41 AM
  Received INSTEON                "Thermostat Fam Room" humidity changed to 33.0
2Jan, 2012 5:50:20 AM
2Jan, 2012 5:50:47 AM
  Received INSTEON                "Thermostat Fam Room" humidity changed to 34.0
  Received INSTEON                "Thermostat GameRm" humidity changed to 39.0
2Jan, 2012 5:51:26 AM
2Jan, 2012 5:51:56 AM
  Received INSTEON                "Thermostat MBR" on (button 2)
2Jan, 2012 5:52:39 AM
  Received INSTEON                "Thermostat MBR" temperature changed to 63.0
2Jan, 2012 5:53:45 AM
  Received INSTEON                "Thermostat MBR" temperature changed to 64.0
2Jan, 2012 5:54:00 AM
2Jan, 2012 5:54:23 AM
  Received INSTEON                "Thermostat GameRm" humidity changed to 40.0
  Received INSTEON                "Thermostat MBR" humidity changed to 42.0
2Jan, 2012 5:55:12 AM
2Jan, 2012 5:55:57 AM
2Jan, 2012 5:56:33 AM
2Jan, 2012 5:57:00 AM
  Received INSTEON                "Thermostat MBR" humidity changed to 43.0
2Jan, 2012 5:57:30 AM
2Jan, 2012 5:57:55 AM
2Jan, 2012 5:59:01 AM
2Jan, 2012 5:59:49 AM
  Schedule                        Crawl Space Fans
  Schedule                        Weather Variables Multi Yahoo WundrGr 6Day Parse Update
  Action Group                    Weather WunderGround 6Day Forecast
  Sent X10                        "Water 4 CrawlSp Fan Fam Rm" on
  Sent X10                        "Water 5 CrawlSp Fan Main House" on
  Sent X10                        "Water 6 CrawlSp Fan Game Room" on
  Schedule                        Weather Variables Multi Yahoo WundrGr 6Day Parse Update (delayed action)
  Wunderground                    Script Launched
  Wunderground                    DEBUG: Start PWS loop- Station # is: 1, Error count is: 0
2Jan, 2012 6:00:21 AM
  Received INSTEON                "Thermostat Fam Study" humidity changed to 36.0
 changed to 39.0
  Trigger                         Pool Autelis Automatic ReStart
  Received INSTEON                "Thermostat Fam Study" temperature changed to 64.0
  Embedded script executor host started
  Stopping plugin "Autelis Jandy 1.0.1" (pid 1160)
  Stopping embedded script executor host (pid 1260)
  Error                           process (pid 1160) failed to quit after polite request -- forcing it to quit now
  Starting plugin "Autelis Jandy 1.0.1" (pid 1262)
2Jan, 2012 6:21:00 AM
  Received INSTEON                "Thermostat Fam Study" temperature changed to 65.0
2Jan, 2012 6:21:30 AM
2Jan, 2012 6:22:36 AM
2Jan, 2012 6:24:00 AM
2Jan, 2012 6:24:25 AM
2Jan, 2012 6:24:57 AM
  Received INSTEON                "Thermostat Main Bedrooms" temperature changed to 64.0
2Jan, 2012 6:26:45 AM
2Jan, 2012 6:27:25 AM
2Jan, 2012 6:28:31 AM
2Jan, 2012 6:28:55 AM
  Received INSTEON                "Thermostat GameRm" temperature changed to 60.0
2Jan, 2012 6:29:18 AM
2Jan, 2012 6:29:37 AM
  Received INSTEON                "Thermostat MBR" humidity changed to 41.0
2Jan, 2012 6:30:00 AM
2Jan, 2012 6:30:24 AM
2Jan, 2012 6:31:06 AM
2Jan, 2012 6:31:49 AM
2Jan, 2012 6:32:34 AM
2Jan, 2012 6:32:56 AM
2Jan, 2012 6:33:30 AM
2Jan, 2012 6:34:20 AM
2Jan, 2012 6:34:44 AM
2Jan, 2012 6:35:18 AM
2Jan, 2012 6:35:50 AM
2Jan, 2012 6:36:24 AM
g. (-1700)
  Stopping plugin "Autelis Jandy 1.0.1" (pid 1262)
  Stopping embedded script executor host (pid 1314)
  Error                           process (pid 1262) failed to quit after polite request -- forcing it to quit now
  Starting plugin "Autelis Jandy 1.0.1" (pid 1316)
2Jan, 2012 6:39:00 AM
2Jan, 2012 6:39:30 AM
2Jan, 2012 6:40:01 AM
  Sent INSTEON                    "Foyer LampLinc 3 " status request (received: 0)
  Sent INSTEON                    "Backyard OverHead Lt Fam Rm Steps" status request (received: 0)
2Jan, 2012 6:40:49 AM
2Jan, 2012 6:41:55 AM
2Jan, 2012 6:42:30 AM
2Jan, 2012 6:43:01 AM
  Received INSTEON                "Thermostat MBR" off (button 2)
2Jan, 2012 6:43:40 AM
  Received INSTEON                "Thermostat MBR" temperature changed to 65.0
2Jan, 2012 6:44:07 AM
2Jan, 2012 6:45:00 AM
2Jan, 2012 6:45:30 AM
2Jan, 2012 6:46:20 AM
2Jan, 2012 6:46:55 AM
  Received INSTEON                "Thermostat MBR" humidity changed to 39.0
2Jan, 2012 6:48:00 AM
2Jan, 2012 6:48:30 AM
2Jan, 2012 6:49:09 AM
  Received INSTEON                "Thermostat Fam Room" on (button 2)
2Jan, 2012 6:51:00 AM
2Jan, 2012 6:51:30 AM
2Jan, 2012 6:51:58 AM
  Received INSTEON                "Thermostat Main Bedrooms" humidity changed to 35.0
2Jan, 2012 6:52:17 AM
  Received INSTEON                "Thermostat MBR" humidity changed to 38.0
2Jan, 2012 6:52:59 AM
2Jan, 2012 6:53:25 AM
2Jan, 2012 6:54:00 AM
2Jan, 2012 6:54:30 AM
2Jan, 2012 6:57:00 AM
  Received INSTEON                "Thermostat Fam Room" mode changed to all off; fan auto on
  Received INSTEON                "Thermostat Fam Room" mode changed to auto on; fan auto on
2Jan, 2012 6:57:29 AM
2Jan, 2012 6:59:56 AM
  Received INSTEON                "Thermostat MBR" humidity changed to 37.0
2Jan, 2012 7:00:30 AM
2Jan, 2012 7:01:02 AM
2Jan, 2012 7:01:42 AM
2Jan, 2012 7:02:08 AM
2Jan, 2012 7:02:25 AM
  Received INSTEON                "Thermostat Fam Room" off (button 2)
2Jan, 2012 7:02:51 AM
  Received INSTEON                "Thermostat Fam Room" temperature changed to 65.0
2Jan, 2012 7:03:30 AM
Screen shot 2012-01-02 at 10.43.52 AM.jpg (255.01 KiB) Viewed 5115 times
Screen shot 2012-01-02 at 10.44.51 AM.jpg (248.77 KiB) Viewed 5115 times
Thu Jan 05, 2012 10:43 am
asw24b offline
Starting now.
You have their outdoor box, right ?
I just got mine last night, and the wireless router that they ship with it appears to be a real piece of junk.... It looks like it is doing a whole bunch of things incorrectly at the protocol level....
It is from these guys:
http://www.tenda.cn/tendacn/DownLoads/
There appears to be a FW update, but they warn that the wrong one will brick the router, and it's not clear which is the right one...
(Among other things, I ran the wireless group at Apple.... I know how to debug these things....)
I swapped their junky router out and put in an AirPort Express; I have had no issues (yet) with the plug in losing the connection....
Mike
Sat Jan 07, 2012 1:16 pm
hamw offline
Thanks for posting that suggestion, Mike. I had not used their router at all but did use an APExpressN from the get-go with the frustrating results as above. Don't know why my system behaved differently from yours. I contacted the Autelis guys about the disconnects. They modified the firmware, which I installed last night, and the plugin has been working perfectly since. The Autelis must not have been handling the connection well for some reason. Once it has a little more time on the clock and continues working, I'll ask what they thought the problem was and how it was fixed. BTW, is the Autelis-supplied router useable at all with an Airport system, or is it better to just put it in the box and return it?
Overall this is a great device and a super plugin. The Autelis guys have been very responsive. If someone hasn't already installed the Jandy RS485->serial interface, I'd recommend considering this unit because of the nice web interface and the One Touch keypad emulation, which makes programming the system possible from anywhere on the network. Thanks nlagaros!
Sat Jan 07, 2012 1:24 pm
asw24b offline
I haven't played with it enough yet.... probably a project for a rainy weekend...
Would you mind sending me a copy of the FW to try ?
Thanks !
Mike
Sun Jan 08, 2012 5:28 pm
asw24b offline
Random question....
The start routine of the plugin uses valuesDict to get to the plugin prefs:
def startup(self):
self.debugLog(u"Method: startup")
if valuesDict[u"showDebugInfo"] == True:
Is this always guaranteed to work ? I couldn't find this in the plugin documentation...
Thanks !
Mike
Sun Jan 08, 2012 5:55 pm
I suspect that is code that got copy/pasted from a different method which had valuesDict as an argument.
There is the plugin preferences dict stored in self.pluginPrefs (where self is the plugin instance) but there is no special global valuesDict object. So I believe that code would throw an exception, unless it defines a global valuesDict somewhere I suppose.
Sun Jan 08, 2012 6:12 pm
asw24b offline
That's why I am confused.... no exception, and no global define...
Oh.... maybe since it is in a try block, the exception won't get logged ?
Mike
