- Somfy controller & Fibaro FGS221
- photo3.JPG (156.15 KiB) Viewed 4658 times
The back side of the Somfy controller with the wires hooked up to the Fibaro.
- Wires connected to the three switches on the Somfy controller
- photo2.JPG (137.86 KiB) Viewed 4658 times
Soldering of the wires to the print of the Somfy controller. The buttons on the Somfy remain fully functional.
- Wires hooked up to Fibaro FGS221
- photo1.JPG (138.04 KiB) Viewed 4658 times
The green wires are currently not used. Just put them there for future use, or if I come along a triple relay switch.
Mass from the UP and DOWN switches are joined into IN on the Fibaro FGS221, the corresponding connecting wires to O1 and O2.
Hooking up to Indigo was easy. The auto off delay for both relays I set to 5 which is about half a second. If you need more info let me know!
Oh, and of course, be careful and take good precautions. I will place the Fibaro in a special plastic casing and mount the Somfy controller on top. The setup on these photos was for my proof of concept.
