ESPHome
Wed Nov 09, 2022 10:20 am
mundmc offline
ESPHome
I'm just curious; I know ESPHome was clearly made for Home Assistant (which I do not yet use), but for anybody familiar with Home Assistant, how complicated would it be to implement and Indigo Plug-in that somehow meaningfully used information published from an ESPc chip running ESPHome? I know this is pretty niche, and further evidence of what I'll do to avoid learning how to write plug-ins :)
Wed Nov 09, 2022 8:19 pm
GlennNZ offline
ESPHome
Hi
That looks interesting - and a already done solution for my analogue data monitoring using rPi. Have setup a few ESP32 for WLED as a side project and was impressed with how robust/little and cheap they were.
ESPHome
You can interface with it using MQTT
https://esphome.io/components/mqtt.html
Probably the best, easiest option as a plugin would be a big deal and maybe stepping on some toes….
(although should say haven’t tried!)
Fri Nov 11, 2022 1:33 pm
MarcoGT offline
Re: ESPHome
I will be an alpha tester if a plug-in will pop up:)
Tue Dec 06, 2022 10:53 am
mundmc offline
Re: ESPHome
Thanks for the response, Glenn; it looks like the EspHome firmware can be custom-built and flashed from a docker container. I suppose MQTT Shims is the best logical integration next.
