Call REST API from JavaScript
Fri Feb 20, 2015 1:36 pm
davinci offline
    $.ajax({
  url: 'http://127.0.0.1:8176/devices/light%20upstairs',
  type: 'PUT',
  data: "isOn=0&_method=put",
  success: function(data) {
    alert('Load was performed.');
I'm getting this error:
WebServer 405 Method Not Allowed "http://127.0.0.1:8176/devices/light upstairs" from 127.0.0.1
Why doesn't this work?
Fri Feb 20, 2015 6:44 pm
Re: Call REST API from JavaScript
Do you have authentication turned on? If so, then you need to authenticate using digest authentication (not sure how you do that in JavaScript).
Sat Feb 21, 2015 1:06 am
davinci offline
I disabled it for testing but get the same error.
Sat Feb 21, 2015 5:43 am
davinci offline
TWO PROBLEMS
Problem with the 405 error is on PHP Server side.
I can't login automatically. If I enter it manually it works until cache is removed. Anyone has an idea?
    $.ajax({ url: 'http://127.0.0.1:8176/devices/Licht%20B%FCro',
    type: 'PUT', data: "isOn=1&_method=put", beforeSend: function(xhr) { xhr.setRequestHeader("Authorization", "Basic d2lraTpwZWRpYQ0K==") }
Mon Feb 23, 2015 11:57 am
davinci offline
So how can I login properly over a website?
Also why is my command rejected completely if I do it over my local PHP?
Mon Feb 23, 2015 8:37 pm
Indigo doesn't use PHP (it uses a python based Web server). The 405 is probably because you are doing HTTP Basic authentication instead of HTTP Digest. I'm not sure how to do that via JavaScript. You can disable Indigo's Digest authentication in favor of Basic authentication but it is less secure. Search in the forum for "HTTP Digest Basic authentication" and you should find the thread with the details. If you don't then I can find it.
Tue Feb 24, 2015 4:56 am
davinci offline
Finally it works!
I can use this to call REST API in a secure way. Maybe someone can benefit from this code as well:
<?php
$service_url = 'http://127.0.0.1:8176/devices/light';
$ch = curl_init($service_url);
curl_setopt($ch, CURLOPT_HTTPAUTH, CURLAUTH_DIGEST);
curl_setopt($ch, CURLOPT_USERPWD, 'user:pass');
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
curl_setopt($ch, CURLOPT_CUSTOMREQUEST, "PUT");
$data = array("toggle" => '1');
curl_setopt($ch, CURLOPT_POSTFIELDS,http_build_query($data));
$response = curl_exec($ch);
if ($response === false) {
    $info = curl_getinfo($ch);
    curl_close($ch);
    die('Error: ' . var_export($info));
curl_close($ch);
$decoded = json_decode($response);
if (isset($decoded->response->status) && $decoded->response->status == 'ERROR') {
    die('error occured: ' . $decoded->response->errormessage);
echo 'OK!';
var_export($decoded->response);
Tue Feb 24, 2015 7:13 am
davinci offline
Example use of curl and virtual HTTP execute call to execute action group “party scene”:
curl -X EXECUTE http://127.0.0.1:8176/actions/party%20scene
http://127.0.0.1:8176/actions/party%20s ... od=execute
translates to
<?php
$service_url = 'http://127.0.0.1:8176/actions/action';
curl_setopt($ch, CURLOPT_CUSTOMREQUEST, "EXECUTE");
$data = array("_method" => 'execute');
    curl_close($ch);
curl_close($ch);
    die('Error: ' . $decoded->response->errormessage);
echo 'response ok!';
However all of the sudden indigo refused the calls and I had to restart the server.
Tue Feb 24, 2015 8:05 am
RogueProeliator offline
No idea on that, but one thing it looks like you changed was an HTTP Method from PUT to EXECUTE... You should probably stick with a PUT (though I think a GET will work on the RESTful API) in case the non-standard method is confusing the server.
Adam
Sat Feb 28, 2015 8:44 am
OnnoH offline
I'm trying to accomplish kind of the same thing using Python.
import requests
import time
from requests.auth import HTTPDigestAuth
print "Switching ON to 50%"
site = "http://indigo.local:8176/devices/DiningRoom%20-%20OverheadLight"
cmd = "brightness=50"
response = requests.put(url=site, data=cmd, auth=HTTPDigestAuth('admin', 'admin'))
print response
time.sleep(5)
print "Switching OFF"
cmd = "isOn=0"
print response
Resulting in the following output
Switching ON to 50%
<Response [200]>
Switching OFF
<Response [200]>
but no light :(
Using curl
curl --digest -u admin:admin -X PUT -d brightness=50 http://indigo.local:8176/devices/DiningRoom%20-%20OverheadLight
I achieve the proper result.
What am I missing?
Sat Feb 28, 2015 1:13 pm
davinci offline
In your case you could try to use this:
import subprocess
resp= subprocess.Popen("/usr/bin/curl --digest -u admin:admin -X PUT -d brightness=50 http://indigo.local:8176/devices/DiningRoom%20-%20OverheadLight",shell=True,stdout=subprocess.PIPE,stderr=subprocess.PIPE).communicate()[0]
Sun Mar 01, 2015 9:18 am
OnnoH offline
Thanks, but spawning an OS task is a last resort IMHO. Although we're on a Mac, cross platform scripting is always something to consider.
Using a Google Chrome REST Client App didn't bring me much further, so I took your approach of using a curl library: pycurl and here's what I've come up with:
import pycurl
c = pycurl.Curl()
c.setopt(pycurl.URL, "http://indigo.local:8176/devices/DiningRoom%20-%20OverheadLight")
c.setopt(pycurl.HTTPAUTH, pycurl.HTTPAUTH_DIGEST)
c.setopt(pycurl.USERPWD, "admin:admin")
c.setopt(pycurl.CUSTOMREQUEST, "PUT")
c.setopt(pycurl.POSTFIELDS, "isOn=1")
c.perform()
c.close()
As I suspected the way the payload is sent across probably does the trick. A mix and match of PUT and POST. The Indigo REST API expects a PUT (POST gets a 405), but then POSTs form data. I guess the curl command is doing that by default.
Since I've been sniffing around an application with an AngularJS frontend and a RESTeasy Java backend using JSON, I would love Indigo to head in that direction. I thought I've read somewhere that Matt and Jay are considering refactoring their REST API (or having done so already with the TouchApp 2.0). Any light on this guys? :roll:
Sun Mar 01, 2015 10:06 am
OnnoH offline
Having said that, I did some further reading and reverted back to my original code with the requests lib. Changed
cmd="brightness=100"
to
cmd = { "brightness":100 }
and I'm in business. Did I mention I just love JSON? Well actually it's a Python dictionary but they look alike 8)
