Unable to submit a plugin to the plugin store
Fri Jul 22, 2022 5:02 pm
papamac offline
I have a new plugin called VirtualGarageDoor with a new release located at https://www.github.com/papamac/VirtualGarageDoor. I attempted to use the your account website to add it. I entered
papamac for the GitHub user, and
VirtualGarageDoor for the GitHub Repo
I got the following message:
"That plugin's identifier doesn't start with your developer ID: only the owner of the plugin can add it to the store. If the plugin is owned by you, contact support for assistance."
I checked the info.plist and the plugin identifier is "net.papamac.indigoplugin.virtualgaragedoor" because my URL is papamac.net. Does your error check logic only recognize "com.papamac..."? If this is not the issue, please help.
papamac
Fri Jul 22, 2022 6:12 pm
Re: Unable to submit a plugin to the plugin store
You set your developer ID as papamac, but your plugin is using net.papamac. Change your developer ID on the Plugin Contribution page to net.papamac and it should work.
Fri Jul 22, 2022 6:37 pm
papamac offline
Thanks Jay :)
Fri Jul 22, 2022 8:14 pm
papamac offline
Sorry, Jay. I'm still not there yet. The web page requires a release title (mine is blank), but it is only editable if I am not submitting through GitHub. Do IO need to create another release in GitHub?
Sat Jul 23, 2022 8:57 am
papamac offline
I looked at GitHub and I did have a release name. Your web page put my GitHub release name in the what's new field and left the release name blank. Both fields are required to submit the plugin. How do I get past this?
Sat Jul 23, 2022 9:01 am
ryanbuckner offline
FWIW I've found that when it comes to posting things in the plugin store Jay and Matt are very responsive over email. : developer-relations@indigodomo.com
Mon Jul 25, 2022 8:44 am
I don't understand what you're saying. I looked at your releases on Github and they are missing the zipped up plugin. Not a deal breaker since that will also work also, but it not a great user experience since they have to look in the source folder to get the plugin once it's downloaded rather than just clicking on the plugin itself.
I don't see anything in the plugin store database for you either. Can you take some screenshots of what you are seeing? Nobody else has had any issues AFAIK, but you may be the first new developer in a while so I suppose it's possible something has broken.
Mon Jul 25, 2022 8:53 am
Just saw your emails, will get back to you on that today.
