PyCharm Debugging Help
Mon Jul 11, 2022 8:46 pm
indy offline
Hello
I'm trying to work on an existing plugin (https://github.com/kmarkley/Indigo-Timed-Devices) to see if I can get it to work with Indigo 2022.1.
I have used Anaconda to setup virtual environments for Python development in the past so I have created a new environment. I've attached the configuration of the environment as well as the packages installed in it
conda_config.txt
Anaconda environment info and package info
(2.55 KiB) Downloaded 60 times
I am using the latest pro version of PyCharm
PyCharm Version
I've followed the wiki article: https://wiki.indigodomo.com/doku.php?id ... nvironment and successfuly set up PyCharm debugging environment. I can start the debugger in PyCharm and have it listen on localhost port 5678
PyCharm Debugger
In Indigo, when I go and reload the plugin via Plugin > Timed Devices > Reload in debugger, it appears that Indigo is not able to connect to PyCharm debugger.
Indigo Plugin Reload
Would appreciate any pointers on how to get this work.
Tue Jul 12, 2022 5:22 am
Re: PyCharm Debugging Help
Are you able to import pydevd from within the Indigo Scripting Shell?
Python 3.10.2 (v3.10.2:a58ebcc701, Jan 13 2022, 14:50:16) [Clang 13.0.0 (clang-1300.0.29.30)]
Connected to Indigo Server v2022.1.2, api v3.1 (localhost:1176)
>>> import pydevd
Within the plugin you're working on, be sure that you've set the Server API to 3.0 -- I'm nearly certain that `pydevd` is included in the Indigo Plugin Host 3 (IPH3) only.
   <key>ServerApiVersion</key>
   <string>3.0</string>
Tue Jul 12, 2022 8:33 am
1) Indigo will not run in a virtual environment because it doesn't run in a standard python environment (rather, it runs in an IndigoPluginHost3 process). Setting one up in PyCharm does nothing since no python code is actually run by PyCharm.
2) You do not need to install pydevd - Indigo will get it directly from the PyCharm bundle. PyCharm must be installed in the /Applications directory for Indigo to find the pydevd module. JetBrains makes a custom version of pydevd, and they must be exactly the same module for it to work reliably (thus we just point to the exact same .egg that PyCharm uses).
Tue Jul 12, 2022 12:08 pm
indy offline
Thanks Jay and DaveL17.
Very helpful to understand about Anaconda and Indigo.
I'm still learning how it all hangs together.
To close the loop...
pydev could be imported in the console. I didn't have to make any changes.
pydev in console
ServerAPIVersion was 2.0. Changed that to 3.0.
This fixed the pydev import error. DaveL17, you were right about this.
I then went into the code for the plugin and updated modules etc. to make them compatible with Python 3.0. Turned out to be a pretty simple task as there were a couple of small changes needed.
The Timed-Devices plugin now works on Indigo 2022.1. Currently the changes exist in my fork of the original plugin code (https://github.com/indynz/Indigo-Timed-Devices)
I have sent a pull request to the author (https://github.com/kmarkley/Indigo-Timed-Devices)
Tue Jul 12, 2022 1:40 pm
Glad you were able to figure it out.
It's a bit of a steep hill to climb (depending on your Python coding chops). It took me a while to internalize it, but that's probably more to do with my newness with PyCharm (at the time) than anything else.
One important note with PyCharm debugging and Indigo: With each new major version of Indigo, you'll need to point PyCharm to the new plugin location.
Tue Jul 12, 2022 1:55 pm
I suspect you could get really clever with symlinks to avoid this, but I don't find it an undue burden since its a pretty simple change in the run configuration.
Though, on second thought, maybe not... :D
Tue Jul 12, 2022 3:28 pm
I agree it's not a big deal.
Getting clever would be a lot more work! :D
