Writing asyncio compatible plugins
Sat Jun 25, 2022 1:54 pm
Here's an overview of how I'm doing plugins using asyncio libraries. I don't guarantee that these techniques will work in all cases, but so far they're working for me.
The simple case is a library that requires you to call asyncio co-routines from synchronous code, but where you don't mind blocking on the async function call, just like you do for a sync call. In that case, you can just do this anytime you need to call one of those routines:
asyncio.run(lib.function(args))
A slightly more complicated case is when you need to do a login, or some error checking, etc, in the async call. From the latest MyQ plugin (edited):
        if action.deviceAction == indigo.kDeviceAction.Unlock:
            self.logger.debug(f"actionControlDevice: Unlock {dev.name}")
            asyncio.run(self.pymyq_open(dev.address))
    async def pymyq_open(self, myqid):
        async with ClientSession() as web_session:
                api = await login(self.pluginPrefs['myqLogin'], self.pluginPrefs['myqPassword'], web_session)
            except MyQError as err:
                self.logger.warning(f"Error logging into MyQ server: {err}")
                return
            device = api.devices[myqid]
                wait_task = await device.open(wait_for_state=False)
                self.logger.error(f"Error trying to open '{device.name}': {err}")
                return
In both of these cases, the code is blocking until the async function(s) are complete.
More complicated scenarios in following posts...
Sat Jun 25, 2022 1:55 pm
Re: Writing asyncio compatible plugins
Many plugins that communicate with cloud services or hardware devices receive data asynchronously. Before asyncio, that meant either polling the device constantly, or using a background thread to maintain a websocket or similar communication channel. In general, doing the same thing with asyncio is actually easier, except for the effort of integrating it into the synchronous plugin architecture. Here's how I'm doing it (this is from the new Harmony Hub plugin).
First, the asyncio event loop needs to be set up in it's own Thread. Initially I was doing this using runConcurrentThread() but that didn't work out. The problem was that thread doesn't get started until after the plugin devices are started, and if you need asyncio to start up the devices, well, you see the problem. So:
    def __init__(self, pluginId, pluginDisplayName, pluginVersion, pluginPrefs):
        indigo.PluginBase.__init__(self, pluginId, pluginDisplayName, pluginVersion, pluginPrefs)
        self._event_loop = None
        self._async_thread = None
    def startup(self):
        self._event_loop = asyncio.new_event_loop()
        asyncio.set_event_loop(self._event_loop)
        self._async_thread = threading.Thread(target=self._run_async_thread)
        self._async_thread.start()
    def _run_async_thread(self):
        self.logger.debug("_run_async_thread starting")
        self._event_loop.create_task(self._async_start())
        self._event_loop.run_until_complete(self._async_stop())
        self._event_loop.close()
    async def _async_start(self):
        self.logger.debug("_async_start")
        # add things you need to do at the start of the plugin here
    async def _async_stop(self):
        while True:
            await asyncio.sleep(1.0)
            if self.stopThread:
                break
At this point, there's a running asyncio event loop just waiting for things to do. Add code to _async_start() as needed. You see that the event loop will continue to run until _async_stop() exits, which is done when self.stopThread is set. Cleanup code can be added before the break. Just make sure it'll never block.
Additional tasks can be added to the event loop as needed, for example:
    def deviceStartComm(self, device):
        if device.deviceTypeId == "harmonyHub":
            self._event_loop.create_task(self._async_start_device(device))
    async def _async_start_device(self, device):
        client = HarmonyAPI(ip_address=device.address, protocol=self.protocol)
            connected = await client.connect()
        except ConnectionRefusedError as e:
            self.logger.debug(f"{device.name}: connect exception: {e}.")
            return
As written, this does NOT do any cleanup on existing asyncio Tasks. I do some of that other places, like:
    def deviceStopComm(self, device):
            self._event_loop.create_task(self._async_stop_device(device.address))
    async def _async_stop_device(self, ip_address):
        hub_client = self._async_running_clients[ip_address]
            await asyncio.wait_for(hub_client.close(), timeout=5)
        except aioharmony.exceptions.TimeOut:
            self.logger.debug(f"{hub_client.name} HUB: Timeout trying to close connection.")
Reserved #2
Reserved #3
