Install python packages for Indigo 2022.1
Thu May 12, 2022 12:51 pm
kmarkley offline
One of my plugins uses a large 3rd party library that in turn has a number of prerequisites, making it inappropriate to include directly in the plugin.
What is the best way to make this available in the python 2 environment installed with Indigo 2022.1? I previously installed it with pip, but the plugin is unable to import it. The shared methods folder also doesn't seem quite right because of the prerequisites list.
(Yes, I will also need to get it working in python 3 eventually, but right now I'm just trying fix the breaking error so my automation works.)
Thanks.
Thu May 12, 2022 1:42 pm
Re: Install python packages for Indigo 2022.1
You have to reinstall using pip2 - we're using a different Python 2 install (not the one from Apple) so you'll need to reinstall all the libs that you've installed in the past.
Thu May 12, 2022 1:51 pm
kmarkley offline
Do I need to specify somehow which python pip2 will install to? I don't see anything about that in the pip documentation.
I assume that since pip installed the package on the default Apple python last time that it would just do the same if I ran it again.
Thu May 12, 2022 2:23 pm
This documentation page explains it, but if you still have questions after you read it feel free to ask (and we can update the docs to clarify).
Thu May 12, 2022 3:06 pm
kmarkley offline
That's what I needed. Thanks.
