has deviceStartComm completed?
Sat Aug 07, 2021 11:59 am
berkinet offline
Hopefully a simple question. Is there a way to know when deviceStartComm() completes? In other words, when all existing devices have been passed to the method.
Sat Aug 07, 2021 1:25 pm
Re: has deviceStartComm completed?
Implement this:
    def _postStartup(self):
        super(Plugin, self)._postStartup()
        # your code here
Your code will run after all the devices have been started (which is what the superclass call does).
The next thing that happens after that is the call to runConcurrentThread(), so you might put stuff there as well.
Sat Aug 07, 2021 2:03 pm
berkinet offline
        # your code here
... ...The next thing that happens after that is the call to runConcurrentThread(), so you might put stuff there as well.
Thanks, That's perfect. I am not implementing runConcurrentThread in this plugin, thus the need for exactly what you suggested.
Sat Aug 07, 2021 2:56 pm
Which is exactly why I needed it as well. Also, putting stuff in runConcurrentThread() has it's own problems if the thread crashes and get restarted,
