Registering device events in a plugin
Mon Jun 22, 2020 8:36 am
jheddings offline
I have been looking into alternatives for the polling loops I end up using in most of my plugins... One thing that could help would be registering for device state changes internally, rather than a visible Trigger in Indigo. Effectively, it would be a simple callback registered for a device that allows another plugin to see state changes.
I've been using the EventHook example in several other Python projects, which is very effective for this kind of thing. I'm sure there are other ways to handle this in Indigo, just throwing it out as an example of what I'm looking for.
So a simple use could be:
# plugin.py
    def deviceStartComm(self, device):
        device.onStateChange += self.deviceStateChanged
    def deviceStateChanged(device, stateName):
        self.logger.debug('State Change: %s[%s] => %s', device.name, stateName, device.states[stateName])
Any thoughts on such a thing?
Mon Jun 22, 2020 9:45 am
Re: Registering device events in a plugin
If you do this in your startup():
        indigo.devices.subscribeToChanges()
Then you can do something like:
    def deviceUpdated(self, oldDevice, newDevice):
        indigo.PluginBase.deviceUpdated(self, oldDevice, newDevice)
        for masqDeviceId, masqDevice in sorted(self.masqueradeList.iteritems()):
            baseDevice = int(masqDevice.pluginProps["baseDevice"])
            if oldDevice.id == baseDevice:
                self.updateDevice(masqDevice, oldDevice, newDevice)
Or am I misunderstanding that you're wanting to do?
Mon Jun 22, 2020 10:12 am
Yep, I think you want subscribeToChanges() so that your deviceUpdated method gets called for every device that has a change. You can then decide if the change is one you're interested in or not.
Mon Jun 22, 2020 10:40 am
jheddings offline
Good pointer... That is along the lines of what I was trying to do. Now I need to think about how it fits in my plugin architecture :)
Mon Jun 22, 2020 10:42 am
I'm confused about something - from your original code post, it looks like you're trying to catch changes to states for the plugin's own devices. Since the ONLY thing that can change the states of a plugin device is the plugin itself, why do you need this in the first place? Do you have deferred processing you need to do after devices have changed?
Mon Jun 22, 2020 11:51 am
jheddings offline
Yeah, that was a simple example just to demonstrate a trivial case, but doesn't model what my plugin is doing...
A better example would be:
<!-- Devices.xml -->
    <Name>Master Controller</Name>
    <ConfigUI>
      <Field type="list" id="devices">
        <Label>Remote Devices:</Label>
        <List class="indigo.devices" filter="indigo.dimmer"/>
      </Field>
    </ConfigUI>
# plugin.py
        for remoteDevice in device.pluginProps['devices']:
            # set up event hook for device state changes
            remoteDevice.onStateChange += self.deviceStateChanged
    # custom event hook for device state changes
I'm still playing around with subscribeToChanges() to see if I can make it work for this case. In my case, each custom device is watching for only the external devices it cares about, not so much the devices created by the Plugin.
Mon Jun 22, 2020 1:18 pm
That's exactly what the Virtual Devices interface does for it's devices (and many of the other plugins that do that kind of thing). The plugin maintains a list of devices for which changes are important (built and maintained during deviceStartComm and deviceStopComm). It subscribes to changes, then in the deviceUpdated method looks at the device to see if it's one it cares about. If so, it does whatever work is necessary. If not, it just passes.
Mon Jun 22, 2020 11:58 pm
jheddings offline
Thanks for the help, gents. I've added basic support for device changes to my plugin framework and will use that going forward. I'd still like to improve it a bit for capturing specific events, but that may come at a later time :)
In case you are curious, here is the base I usually use for building plugins:
https://github.com/jheddings/indigo-iplug
