Updating existing devices with a new custom state
Fri Jan 03, 2020 1:35 pm
ZachBenz offline
In my plugin, I would like to modify a device in Devices.xml to add a new custom state. When I do this, existing instances of the device already defined in Indigo don't have this custom state, causing errors when I try to update the new state.
I've tried to overcome this by updating the device in deviceStartComm, only to discover that the "states" attribute for a device is read-only - e.g. if I try something like:
      if ("lastMotionEventId" not in indigoDevice.states):
         replacementStates = indigo.Dict()
         replacementStates = indigoDevice.states   # Make a copy to edit
         replacementStates["lastMotionEventId"] = "FOOBAR"
         indigoDevice.states = replacementStates
         indigoDevice.replaceOnServer()
         self.debugLog("Added new custom state lastMotionEventId to existing device %s" % indigoDevice.name)
The following error is produced:
   Ring Error                      exception in deviceStartComm(Front Door): the attribute "states" is read-only on this instance
What is the correct way to migrate existing devices to support the newly added state? Do I need to programmatically create a whole new device object to replace the existing one?
Fri Jan 03, 2020 1:44 pm
Re: Updating existing devices with a new custom state
https://wiki.indigodomo.com/doku.php?id ... vice_class
replaceOnServer()
stateListOrDisplayStateChanged()
Fri Jan 03, 2020 1:54 pm
ZachBenz offline
Got it, thanks for the pointer!
