How do I get the path to the Preferences folder?
Thu Jan 02, 2020 8:39 pm
ZachBenz offline
I'm looking to save a file (an access token cache) in a place that doesn't get overwritten when my plugin (RingForIndigo) is updated. Seems like the Preferences folder is the right place to do this (i.e. /Library/Application Support/Perceptive Automation/Indigo 7.x/Preferences).
To get this path, is it appropriate to simply append "/Preferences" to indigo.server.getInstallFolderPath()?
ZachBenz's Plugins: RingForIndigo
Thu Jan 02, 2020 9:47 pm
ZachBenz offline
Re: How do I get the path to the Preferences folder?
Slight edit: appropriate to simply append "Preferences/Plugins"?
Fri Jan 03, 2020 3:08 am
Your concept is sound, so assuming all the folder paths and the Indigo function is correct, then yes, that’s the way to do it (and is how I do it).
Fri Jan 03, 2020 8:32 am
ZachBenz offline
Fri Jan 03, 2020 2:50 pm
I agree with howartp. Another option would be to just encode the file into a string and store it in your plugin's pluginPrefs dict. Presuming it isn't huge that should work fine.
ZachBenz offline
Thanks, Matt.
