Problem with indigohost -x
Sat Aug 24, 2019 2:14 am
forestfield offline
I have a couple of python scripts that I have developed over the past years. I normally test any changes with
indigohost -x script.py
I've not needed to test anything since installing 7.3, but now I get
$ indigohost -x heating.py
2019-08-24 09:11:06.962 IndigoPluginHost[3062:25578] connection to server was closed
There's nothing in the indigo error log
I've rebooted the mac but still get this.
Have I mis-remembered how to run this, or is there an issue?
-- Paul --
Sat Aug 24, 2019 3:54 am
forestfield offline
Re: Problem with indigohost -x
Problem solved... User error!
I'd aliased indigohost to '/Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.2/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost'.
Changed 7.2 to 7.3 in the alias and all is good :-)
Sat Aug 24, 2019 6:08 am
That'll do it. Glad you were able to figure it out.
Sat Aug 24, 2019 10:54 am
Try using this (new to v7.3) instead of your indigo-host alias (or make your alias point to this):
/usr/local/indigo/indigo-host
It'll automatically figure out the correct path based on the Indigo Server that is running so will work on future versions.
Sat Aug 24, 2019 12:05 pm
forestfield offline
I like!
