default values in devices.xml
Tue Jan 15, 2019 11:00 am
in devices.xml:
<Field id="pin_Coil1"
   type="menu" defaultValue="26" >
    <Label>GPIO pin for coil1-#6:</Label>
      <List class="self" filter="" method="filtergpioList" dynamicReload="false" />
</Field>
in plugin:
_GlobalConst_allGPIOlist = [
     ["1", "do not use"]
   , ["2",  "GPIO02 = pin  # 3 -- I2C"]
   , ["3",  "GPIO03 = pin  # 5 -- I2C"]
   , ["4",  "GPIO04 = pin  # 7 -- ONE WIRE"]
   , ["17", "GPIO17 = pin  # 11 -- DHT"]
   , ["27", "GPIO27 = pin  # 13"]
   , ["22", "GPIO22 = pin  # 15"]
   , ["10", "GPIO10 = pin  # 19 -- SPS MOSI"]
   , ["9",  "GPIO09 = pin  # 21 -- SPS MISO"]
   , ["11", "GPIO11 = pin  # 23 -- SPS SCLK"]
   , ["5",  "GPIO05 = pin  # 29"]
   , ["6",  "GPIO06 = pin  # 31"]
   , ["13", "GPIO13 = pin  # 33"]
   , ["19", "GPIO19 = pin  # 35"]
   , ["26", "GPIO26 = pin  # 37"]
   , ["14", "GPIO14 = pin  # 8  -- TX - REBOOT PIN OUT"]
   , ["15", "GPIO15 = pin  # 10 -- RX - REBOOT PIN IN"]
   , ["18", "GPIO18 = pin  # 12"]
   , ["23", "GPIO23 = pin  # 16"]
   , ["24", "GPIO24 = pin  # 18"]
   , ["25", "GPIO25 = pin  # 22"]
   , ["8",  "GPIO08 = pin  # 24 -- SPS CE0"]
   , ["7",  "GPIO07 = pin  # 26 -- SPS CE1"]
   , ["12", "GPIO12 = pin  # 32"]
   , ["16", "GPIO16 = pin  # 36"]
   , ["20", "GPIO20 = pin  # 38"]
   , ["21", "GPIO21 = pin  # 40"]]
   def filtergpioList(self, valuesDict=None, filter="", typeId="", devId="x"):
         list = copy.deepcopy(_GlobalConst_allGPIOlist)
         return list
the default value when editing the device should be "26", "GPIO26 = pin # 37" but it shows blank
Any idea what I am doing wrong?
It works fine with regular hard coded lists, textfields ...
Tue Jan 15, 2019 11:11 am
Re: default values in devices.xml
Your dynamic method needs to return a list (array) of tuples, not lists:
     ("1", "do not use")
   , ("2",  "GPIO02 = pin  # 3 -- I2C")
   , ("3",  "GPIO03 = pin  # 5 -- I2C")
   , ("4",  "GPIO04 = pin  # 7 -- ONE WIRE")
   , ("17", "GPIO17 = pin  # 11 -- DHT")
   , ("27", "GPIO27 = pin  # 13")
   , ("22", "GPIO22 = pin  # 15")
   , ("10", "GPIO10 = pin  # 19 -- SPS MOSI")
   , ("9",  "GPIO09 = pin  # 21 -- SPS MISO")
   , ("11", "GPIO11 = pin  # 23 -- SPS SCLK")
   , ("5",  "GPIO05 = pin  # 29")
   , ("6",  "GPIO06 = pin  # 31")
   , ("13", "GPIO13 = pin  # 33")
   , ("19", "GPIO19 = pin  # 35")
   , ("26", "GPIO26 = pin  # 37")
   , ("14", "GPIO14 = pin  # 8  -- TX - REBOOT PIN OUT")
   , ("15", "GPIO15 = pin  # 10 -- RX - REBOOT PIN IN")
   , ("18", "GPIO18 = pin  # 12")
   , ("23", "GPIO23 = pin  # 16")
   , ("24", "GPIO24 = pin  # 18")
   , ("25", "GPIO25 = pin  # 22")
   , ("8",  "GPIO08 = pin  # 24 -- SPS CE0")
   , ("7",  "GPIO07 = pin  # 26 -- SPS CE1")
   , ("12", "GPIO12 = pin  # 32")
   , ("16", "GPIO16 = pin  # 36")
   , ("20", "GPIO20 = pin  # 38")
   , ("21", "GPIO21 = pin  # 40")
Tue Jan 15, 2019 12:01 pm
tried that , no change
tried also
_GlobalConst_allGPIOlist = (
("1", "do not use")
all couple but that creates an error message it wants a list not a tuple.
ps when opening the list everything is there , just the DEFAULT is not populated.
Tue Jan 15, 2019 12:04 pm
Why not just put the list in the xml file. It doesn't appear that you're modifying it in any way.
Tue Jan 15, 2019 12:09 pm
Now that I think about it some more, I'm not sure the default value field works at all with a callback generated menu list. I think I implemented the getDeviceConfigUiValues() method to set the "default" value for devices.
Tue Jan 15, 2019 12:21 pm
I use that list in many places ( > 50)
instead of having long lists everywhere i just have one def.
Tue Jan 15, 2019 12:31 pm
[MODERATOR NOTE] Moved to correct forum.
I think this is correct.
Tue Jan 15, 2019 1:22 pm
RogueProeliator offline
Yeah, we have discussed this previously:
https://forums.indigodomo.com/viewtopic.php?f=108&t=12530&p=84214&hilit=defaultValue+dynamic+list#p84214
That should get you in the right direction...
Tue Jan 15, 2019 2:04 pm
Sh t.
Tooo much logic.
have > 90 devices and several reference to that list for each device and they are all different. Then it would be easier to just include the static list.
Ps that would add ~90*5*30 lines ~14000 lines to devices.xml
Tue Jan 15, 2019 2:09 pm
kw123 wrote:
Sh t.
Tooo much logic have > 90 devices and several reference to that list for each device and they are all different. Then it would be easier to just include the static list.
My logic only sets the default if nothing has already been selected.
    def getDeviceConfigUiValues(self, pluginProps, typeId, devId):
        valuesDict = indigo.Dict(pluginProps)
        errorsDict = indigo.Dict()
        if len(valuesDict) == 0:
            if typeId == "foo":
                valuesDict["bar"] = "123"
        return (valuesDict, errorsDict)
Tue Jan 15, 2019 2:51 pm
Yes, times 90 times 5 of your example
