Restore Previous Dimmer Setting for Plugin Dimmer [solved]
Wed Feb 07, 2018 5:28 pm
I'm working on a plugin-supported dimmer device (it's part of a group device if that makes a difference.) The dimmer is working without error, so I think it's properly instantiated. It responds to TurnOn, TurnOff, DimBy, Toggle, SetBrightness, and RequestStatus. Turn on dimmer device, brightness=100. Set brightness to some other level, say brightness=50. The Indigo UI responds properly and the UI value is correct. Turn the device off. Turn the device on again and it goes back to brightness=100. What I would like is for brightness to be the last brightness level.
Is there a way to do this natively or to send a desired brightness level to the device when TurnOn is called?
Wed Feb 07, 2018 5:36 pm
Colorado4Wheeler offline
Re: Restore Previous Dimmer Setting for Plugin Dimmer
if you just do setBrightness it should just turn it on to that brightness if it's off, you shouldn't need to do an On and Brightness together.
Wed Feb 07, 2018 7:24 pm
I should be more clear. When you push the Turn On button in the Indigo UI, it always goes to 100.
Screen Shot 2018-02-07 at 7.21.29 PM.png (29.82 KiB) Viewed 733 times
Wed Feb 07, 2018 9:22 pm
Re: Restore Previous Dimmer Setting for Plugin Dimmer [solve
LMGTFY
dev = indigo.devices[123]
dev.onBrightensToLast = True
dev.replaceOnServer()
Helps to search for the right thing.
