Accessing the Event Log
Fri Feb 02, 2018 2:43 pm
vtmikel offline
Who knows where the right place to post this question is...
Has anyone wanted to get access to the full Event Log message stream on the local network? I'm considering a dedicated dashboard, combining some of the stuff that I've done in Grafana (https://www.dropbox.com/s/9nho6p1ijqv1hww/Dashboard%20Picture.png?dl=0), with a Control Page (floor plan view), and the Event Log. Might use a Raspberry Pi for the dashboard, so using the Indigo client wouldn't be an option.
I realized as I was thinking about this that I don't think there is a easy way to get the event log from the existing Indigo extension mechanisms. Perhaps a Indigo Web plugin? How hard would that be? Otherwise perhaps I'll make the event log txt file available on a separate web server.
Mike
Fri Feb 02, 2018 4:53 pm
Re: Accessing the Event Log
Use the following command in your plugin:
indigo.server.subscribeToLogBroadcasts()
After which the server will start calling this method for every line that goes into the Event Log (just implement it in your plugin):
   def eventLogLineReceived(self, entry):
      ts = entry["TimeStamp"]      # datetime
      typeval = entry["TypeVal"]   # integer
      typestr = entry["TypeStr"]   # string
      message = entry["Message"]   # string
      iserror = (typeval == 1)   # bool
I can't tell you exactly what entry["TypeVal"] means off the top of my head, but entry["TypeStr"] is the first thing you see in the event log window, and entry["Message"] is the thing that follows that (after the tab). the other things are self-explanatory. Once I figure it out I'll add the details to the Server Commands section of the developer docs.
