Device valuesDict Passed on Callback Method [SOLVED]
Thu Jan 25, 2018 8:29 am
I have a device config with two menu controls that use callbacks. While developing, I added a line to log the valuesDict that's passed to the callbacks to inspect the contents. When the device is first created, the valuesDict passed to both callbacks only contains 1 of about 20 props. I expect that this is due to the fact that valuesDict is still being created at the time the callback is called. However, when I populate the first menu item 'thing' within the device config dialog, I get a TypeError:
Error in plugin execution UiAction:
  File "plugin.py", line 2591, in deviceStateGenerator
TypeError: string indices must be integers
On this line:
id = valuesDict['thing']
I have confirmed that valuesDict['thing'] at that stage contains the expected value (an Indigo ID number for a device or variable). If I trap the TypeError and simply ignore it, the rest of the flow works as expected.
            <Field id="thing" type="menu" defaultValue="None">
                <Label>Source:</Label>
                <List class="self" filter="" method="listGenerator" dynamicReload="true"/>
                <CallbackMethod>deviceStateGenerator</CallbackMethod>
            </Field>
            <Field id="thingState" type="menu" defaultValue="None">
                <Label>Text to chart:</Label>
                <List class="self" filter="" method="deviceStateGenerator" dynamicReload="true"/>
            </Field>
    def deviceStateGenerator(self, filter="", valuesDict=None, typeId="", targetId=0):
        indigo.server.log(u"deviceStateGenerator: {0}".format(valuesDict))
            return self.Fogbert.generatorStateOrValue(id)
        except KeyError:
            return [("Select a Source Above", "Select a Source Above")]
        except TypeError:
            pass
The valuesDict key appears to exist and have a valid value, so why the TypeError? Clearly, there's something I'm not seeing.
Thu Jan 25, 2018 10:01 am
Re: Device valuesDict Passed on Callback Method
Odd. In the failure case what is the log result of your indigo.server.log line?
The error is hinting that valuesDict isn't a dict but is a string. Try adding this to see if that is the case:
indigo.server.log(u"valuesDict type: %s" % type(valuesDict))
Thu Jan 25, 2018 10:05 am
I think the problem is the signature for your callback method isn't correct. You are using the callback for constructing a menu, whereas that refresh callback should look like this:
def deviceStateGenerator(self, valuesDict, typeId="", devId=0):
Thu Jan 25, 2018 12:04 pm
Thanks Matt. indigo.server.log(u"deviceStateGenerator: {0}".format(type(valuesDict))) gives me:
deviceStateGenerator: <type 'unicode'>
When I use that signature, I get an error that I'm not receiving enough arguments.
Error in plugin execution GetUiDynamicList:
TypeError: deviceStateGenerator() takes at most 4 arguments (5 given)
But I think you might be on to something. I'm calling deviceStateGenerator() both as a control callback and as a source for a dynamic list. I need to do some more testing, but I suspect that the two signatures are different. I'll report back when I have a chance to test that.
Thu Jan 25, 2018 12:18 pm
I use these 2 and they always work
    def filterxxx(self, filter="", valuesDict=None, typeId="", devId=""):
    def CALLBACKxxx(self, valuesDict=None, typeId="", devId=0):
filter does not offer values dict, I have left it in .
Thu Jan 25, 2018 12:19 pm
Winner, winner, chicken dinner.
First trip through:
filter:
valuesDict: UiValuesDict : (dict)
typeId: DEVICE TYPE
targetId: DEVICE ID
That's the result of building the dynamic lists.
After the first control is populated:
filter: UiValuesDict : (dict)
valuesDict: DEVICE TYPE
typeId: DEVICE ID
targetId: 0
That's the result of the control callback.
As Jeff Spicoli said, "My brother has an awesome set of tools. We can fix this." Thanks for putting me back on the path Matt.
Thu Jan 25, 2018 12:21 pm
Thanks Karl.
Thu Jan 25, 2018 5:50 pm
Re: Device valuesDict Passed on Callback Method [SOLVED]
That was exactly the issue. I was using the same plugin method to both generate a dynamic list *and* as a callback to force another dynamic control to refresh. I created a new method called _dummyCallback() for use by the control's <CallbackMethod> which solved my problem.
    def _dummyCallback(self, valuesDict=None, typeId="", targetId=0):
        pass
For the future:
As Karl states above, the signature for a dynamic control (where dynamicReload=True) is:
    def METHOD_NAME(self, filter="", valuesDict=None, typeId="", targetId=0):
Whereas the signature for a control's <CallbackMethod> is:
    def METHOD_NAME(self, valuesDict=None, typeId="", targetId=0):
Most importantly, they shouldn't be used interchangeably. :D
Thu Jan 25, 2018 6:21 pm
Colorado4Wheeler offline
I always use a stock callback for form fields needing to do something or force a list refresh called 'formFieldChanged', then I spur off of that into specific actions when I need them:
   # A form field changed, update defaults
   def formFieldChanged (self, valuesDict, typeId, devId):
         if typeId == "Server":
            return self.serverFormFieldChanged (valuesDict, typeId, devId)
      except Exception as e:
         self.logger.error (ext.getException(e))
I do this in all of my plugins and it makes it easy for me to always remember that my dynamic stuff happens there in every plugin. I actually do a similar thing for dynamically reloading lists and menus although I've really done a lot in that area so it would be too complicated to explain here but the idea is that every single plugin calls the same 'getCustomList' method and I make extensive use of the filters to tell the plugin exactly what list I want back and from where, this way I don't have to create as much code.
Thu Jan 25, 2018 7:28 pm
[snip]
Yeah, I'm moving that direction too. In fact, Adam has given me some great examples for me to steal and I think I'll snoop around your plugins too.
Nice avatar by the way. :D
Thu Jan 25, 2018 7:34 pm
LOL, thank Jay, he inspired my avatar :lol:
If you dive into mine let me know and I’ll answer as much as I can. I’ve made mine quite modular, passing all Indigo functions to a processor library that decides what goes where and when.
Thu Jan 25, 2018 7:42 pm
Thanks for the offer.
I love the idea of standardizing as much as possible across plugins.
