method vs expanded list
Sat Jan 20, 2018 4:21 pm
An action xml currently has 0...29 of these:
            <Field id ="type27"  type="menu" defaultValue="">
                <List class="self" filter="" method="filterDisplayType"  dynamicReload="false"/>
                <Label>ITEM     27:  .......................... select output type:</Label>
            </Field>
with
    def filterDisplayType(self, filter="", valuesDict=None, typeId="", devId=""):
        list=[(u"0", u"not active")
             ,(u"text"          , u"text eg %%d:sensorVolt:input%%[mV]")
             ,(u"textWformat"   , u"text with format string eg %%v:123%%FORMAT%3.1f[mV]; only for numbers")
             ,(u"date"          , u"date  %Y-%m-%d full screen")
             ,(u"clock"         , u"clock %H:%H full screen")
             ,(u"dateString"    , u"date time, enter string format eg %HH:%M:%S")
             ,(u"line"          , u"line ")
             ,(u"point"         , u"point(s) ")
             ,(u"ellipse"       , u"ellipse define top left and bottom right points")
             ,(u"image"         , u"image file name ")
             ,(u"vBar"          , u"vertical bar ")
             ,(u"hBar"          , u"horizontal bar ")
             ,(u"vBarwBox"      , u"vertical bar  with box ")
             ,(u"hBarwBox"      , u"horizontal bar  with box")
             ,(u"rectangle"     , u"rectangle")
             ,(u"triangle"      , u"triangle")
             ,(u"hist"          , u"histogram ")
             ,(u"NOP"           , u"No operation, use to wait before next action")
             ,(u"exec"          , u"execute")]
        return list
the whole action xml is ~ 2500 lines long and it currently takes ~ 5 secs to load
Would it be faster if I replace the static method with an explicit list with the elements in "filterDisplayType" for all 29 fields?
I am trying to add 10 more and then the edit action times out.
Or I could go to "show one item only", but that would reduce the easiness of scrolling through all items, comparing values etc.
Sat Jan 20, 2018 7:36 pm
Colorado4Wheeler offline
Re: method vs expanded list
You don’t really do a lot of computing in the custom list function but if you have 29 call back functions I would think that’s a lot of overhead. I’ve run into that myself on custom lists. As a test you could create a new test device with that’s a copy of this one and make all those static and test and I’m betting it will be faster because sucking u an XML is a lot faster than calling functions.
Sat Jan 20, 2018 10:18 pm
took me an hour .. and the result is:
calling simple static method
== open: 5-6 secs, save ~ 17 secs
included as list in the xml file:
== open 9-11 secs, save ~ 17 secs
The total action files are 283 Kbyte- method / 326KByte-included list (it has several actions),
Reducing it to only this action gets it from 283 down to 186KB and removing all leading banks in a line down to 150kByte.
But that does not seem to have an impact.
running the whole thing on the local server does not change the open, but the save is down from 17 secs to 1 secs.
Is there any other way to accelerate it?
Sat Jan 20, 2018 11:55 pm
I would have expected better results. Do you have auto refresh lists or anything like that?
Sun Jan 21, 2018 8:41 am
All static lists no dynamic refresh
Sun Jan 21, 2018 12:34 pm
just some more info ..
cutting it down to 20 sections from 30
the edit open time goes from 5-6 secs to ~ 4 secs,
Sun Jan 21, 2018 11:05 pm
have it now defined in windows of 10 sections
with a
"windowStart" text field ==> set the offset of the sections
"SetWindowStartID" button ==> copy from sequential props to window props
"saveWindowelements" button ==> copy from window props to sequential props
eg
SetWindowStartID copies existing props from ABC88 to ABCxYAYx8
and saveWindowelements copies ABCxYAYx8 to ABC8
where ABC is the property to be set and xYAYx is used as a separator in the split function
Then in save action all the propxxWindow get deleted and the propxx get error checked and saved
That has it down to 2 secs .. a little complicated but it works.
If someone is interested I attached the code
    def setdisplayPropsWindowCALLBACKbutton(self, valuesDict=None, typeId="", devId=0):
        vd = valuesDict
        fromWindow = int(vd["fromWindow"])
        for xx in vd:
            if "xYAYx" in xx:
                yy = xx.split("xYAYx")
                if yy[1] == "99": continue
                fromProp =  yy[0]+unicode(int(yy[1])+fromWindow)
                if fromProp in vd:
                    vd[xx] = vd[fromProp]
        return vd
    def savedisplayPropsWindowCALLBACKbutton(self, valuesDict=None, typeId="", devId=0):
        vd = valuesDict
        for xx in vd:
            if "xYAYx" in xx:
                vd[ yy[0] + unicode(int(yy[1])+fromWindow) ] = vd[xx]
        return vd
and
            <Field   id="start" type="label"><Label> enter line items ----------------------------------- </Label> </Field>
            <Field id="fromWindow"  type="menu" default="0" >
                <List>
                     <Option value= "0"  >0  .. 9</Option>
                     <Option value= "10" >10 .. 19</Option>
                     <Option value= "20" >20 .. 29</Option>
                     <Option value= "30" >30 .. 39</Option>
                     <Option value= "40" >40 .. 49</Option>
                     <Option value= "50" >50 .. 59</Option>
                     <Option value= "60" >60 .. 69</Option>
                     <Option value= "70" >70 .. 79</Option>
               </List>
                <Label>define elements edit window:</Label>
            </Field>
            <Field  id="setdisplayPropsWindow" type="button"   >
                <Label> ....after selection click</Label><Title>set Window</Title> <CallbackMethod>setdisplayPropsWindowCALLBACKbutton</CallbackMethod>
            </Field>
## elements go here eg for section # 8 and element/props  "offONTime"
            <Field id="offONTimexYAYx8"  type="textfield" default="0,9999999,0" visibleBindingId="typexYAYx8"  visibleBindingValue="text,textWformat,dateString,NOP,date,clock,line,vBar,hBar,vBarwBox,hBarwBox,point,ellipse,image,hist,rectangle,triangle,dot">
                <Label>seconds off,on,off eg 5,3,2:</Label>
            </Field>
            <Field  id="savedisplayPropsWindow" type="button"   >
                <Label> ....after finishing edit elements click</Label><Title>save Window data</Title> <CallbackMethod>savedisplayPropsWindowCALLBACKbutton</CallbackMethod>
            </Field>
