Call Another Plugin Function
Wed Jan 10, 2018 12:24 pm
Colorado4Wheeler offline
I remember at one point I was playing with this and there was a built in method but I cannot remember what it is nor can I find the thread where I may have asked that question and gotten it answered - but it seems to me that there was an API change that allowed a plugin to publish a function that other plugins could call (outside of calling an action). I seem to remember toying with this and getting it working and then a shiny object caught my attention....
It was something along the lines of plugin A would create a function, say testFunction() that would return - I think - a dictionary and plugin B could call that function and get the dictionary back. I recall it had a lot of limitations but I'm only looking to get plugin B to grab some very specific info from plugin A. For some reason I want to think it was a static function name that it had to be, you can't cook up your own name but it had to be implemented via a built-in function.
Wed Jan 10, 2018 2:48 pm
Re: Call Another Plugin Function
You thinking of the Publish/Subscribe API?
Wed Jan 10, 2018 3:08 pm
Do you mean the broadcast/subscribe? No, that's something different. I know there was also an update to the base functionality in the new 2.0 API for Indigo 7 but I think that was a bit different too.
Wed Jan 10, 2018 4:00 pm
Check out the new API announcement post and search for the "Plugin action return values" section.
Wed Jan 10, 2018 4:18 pm
I did check that out before I posted but I thought there was another method that was open before those API changes, am I just dreaming?
Wed Jan 10, 2018 6:26 pm
Are you maybe thinking of plugin.executeAction()? I have this facility in the Matplotlib plugin as kind of a test case.
matplotlibPlugin = indigo.server.getPlugin("com.fogbert.indigoplugin.matplotlib")
payload = {'x_values': [1, 2, 3],
           'y_values': [2, 4, 7],
           'kwargs': {'linestyle': 'dashed',
                      'color': 'b',
                      'marker': 'd',
                      'markerfacecolor': 'r'},
           'path':'/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/images/controls/static/',
           'filename': 'chart_filename1.png'
    result = matplotlibPlugin.executeAction('refreshTheChartsAPI', deviceId=0, waitUntilDone=True, props=payload)
    if result is not None:
        indigo.server.log(result['message'])
except Exception as err:
    indigo.server.log(u"Exception occurred: {0}".format(err))
I designed the result as a dict. I think the code above can be run from anywhere Indigo can run the script.
Wed Jan 10, 2018 6:50 pm
No, it was something else. Maybe it was just the new function in the I7 API that I played with a year ago - seems like it was earlier than that but it could be I need to stop hitting the crack pipe :shock:
