which state is shown in column State
Fri Nov 24, 2017 10:28 am
really need help here, have been looking at the code for 2 days and I can not figure out what I am doing wrong.
I want to change which device state is shown in column State in the main window.
1. in devices.xml
changed UiDisplayStateId
    <Device type="custom" id="beacon">
      <Name>beacon</Name>
        <UiDisplayStateId>displayStatus</UiDisplayStateId>
        <ConfigUI>
to to show displayStatus in the state column
and added the proper state
      <States>
            <State id="displayStatus">
                <ValueType>String</ValueType>
                <TriggerLabel>displayStatus</TriggerLabel>
                <ControlPageLabel>displayStatus</ControlPageLabel>
            </State>
</States>
2. added in plugin
 def deviceStartComm(self):
    dev.stateListOrDisplayStateIdChanged()
to force indigo to update state and display refs.
The device states changes as designed, but indigo still shows the old state (Status) in the state column..
Have done edit / save device, restarted indigo, removed/ added device.... still showing the old state.
I am trying to replicate something I am doing in other plugins and it works fine there ,but not in this plugin..
Any idea where I could look? Any method I should / must not call .. ?
ps posting the code here would not make sense .. it is 13 k lines long
Fri Nov 24, 2017 9:59 pm
Re: which state is shown in column State
The only difference I could find is that in the plugins where it works all the UiDisplayStateId defs are the same. In the one that does not work there are 2 defs:
3 of:
and about 20 of :
<UiDisplayStateId>status</UiDisplayStateId>
it always takes only: status
Fri Nov 24, 2017 10:42 pm
also tried:
    def getDeviceDisplayStateId(self,dev):
        if u"displayStatus" in dev.states: return  dev.states[u"displayStatus"]
        else:                              return  dev.states[u"status"]
and
        if u"displayStatus" in dev.states: return  u"displayStatus"
        else:                              return  u"status"
no change still only shows the "status" state
Fri Nov 24, 2017 10:47 pm
:oops: :oops: :oops: :oops: :oops: :oops:
I had 2 of these in the code:
def getDeviceDisplayStateId(self, dev):
the last one overwrote the first one.. -- added that a year ago
indigo is always right ...
CASE CLOSED .. after 3 days of debugging
Sat Nov 25, 2017 3:26 pm
Hi Karl – I'm glad you tracked down the problem and have it working now. :)
Sat Nov 25, 2017 9:28 pm
after 2 + days I was doubting myself ..
