Noob Plugin Design Question
Sun Nov 05, 2017 7:29 pm
ColoradoSolar offline
I am new to Indigo. I have been reading the documentation and looking at the examples and I have a plugin design question. I want to write a plugin for an energy monitor that has multiple channels and I am trying to figure out the best way. I was thinking I could use a device factory and create a sensor device per channel. How/where would I have the settings that are common to all the devices (like the IP address of the server, update interval, etc...)
Eric
Sun Nov 05, 2017 8:29 pm
Re: Noob Plugin Design Question
Either have a master device that has the common settings, or have those settings as part of the plugin config. If it's possible to have more than one of these devices then go with the master device route.
Sun Nov 05, 2017 8:46 pm
I would go with the plugin preferences route for anything that is common to all devices. I think this is the behavior that most Indigo users expect.
Mon Nov 06, 2017 4:07 pm
For Z-Wave devices Indigo stores most of the information on the first device in the group and doesn't create any type of "master device." That said if there are a lot of properties and UI associated with the master/root device it might make sense to create a device instance (in the group) for that information. Putting it at the plugin config level is an option as well, but if the plugin has the ability to support multiple physical devices (each with their own group of Indigo devices) then it should probably be at the device level instead.
