Architecture Question
Sat Oct 21, 2017 9:30 pm
dgarozzo offline
I'm making great progress on my Automatic ODB-II plugin for Indigo, but I have an architecture question that I need help with.
I think things are probably pretty straightforward if I only had one Automatic ODB device - but I have two.
I currently have my plugin set up in Indigo such that I have created a single Automatic ODB device. That single device is responsible for receiving all updates from all Automatic ODB devices. I can create Triggger events that cam e e specific to one Vehicle, but I think I would prefer to create two (three) separate "devices" within Indigo.
The problem is, I should only have one web socket listener, and as it receives messages, it should signal the appropriate vehicle-based device, where Triggers can fire based on events received for a specific vehicle.
How do I set things up such that I would create one main "Automatic ODB" device, and then two separate Vehicle-Specific Automatic ODB device?
Sun Oct 22, 2017 4:44 am
Re: Architecture Question
Have two device types defined in Devices.xml. Have one listener in your code that is responsible for communication. When new data comes in, evaluate the data and direct it to the appropriate device and then update the status of the device within Indigo. Something like this?
def listener(self):
    while True:
        # listen for data
        if new_data:
            self.got_new_data(data)
def got_new_data(self, data):
    # evaluate the data
    if data is main_device:
        self.do_main_stuff(data)
    elif data is vehicle_device:
        self.do_vehicle_stuff(data)
def do_main_stuff(self, data):
    # parse data to main device
def do_vehicle_stuff(self, data):
    # parse data to vehicle device
So you'd need only two defined device types: a main device type and a vehicle device type. The user could create additional instances of the vehicle device type to taste.
Sun Oct 22, 2017 11:43 am
Another approach, assuming you'll always just have a single socket listener, would be to put the socket-level config in the plugin's config dialog. Then create a single device type that represents each Vehicle in that device you configure the ID (or whatever is used to distinguish them).
