how to call a method in the plugin class
Thu Oct 05, 2017 6:26 pm
assume
pluginId = "aa.bb.zz"
pluginDisplayName = "aaa"
class Plugin(indigo.PluginBase)
  def test(text):
    indigo.server.log(text)
in a class outside class Plugin(indigo.PluginBase)
question: how do I call the method test, tried
class abc():
  test("0")
  aaa.test("1")
  indigo.aaa.test("2")
  indigo.aa.bb.zz.test("3")
  aa.bb.zz.test("4")
 ### this works:
  indigo.server.log("hello")
and many more none works
class abc() is in the same file as the plugin at the end .
in other words what is the name of the plugin class
any pointer from the real expert appreciated..
Thu Oct 05, 2017 7:02 pm
Re: how to call a method in the plugin class
got one step further the class name is "Plugin"
now it requires
error='unbound method test() must be called with Plugin " instance" as first argument
now what is the plugin "instance"... tried, Plugin, plugin.xxx, indigo.xxx etc..
Thu Oct 05, 2017 7:39 pm
RogueProeliator offline
I'm not positive what you are trying to accomplish, but if you are trying to call the function without an instance of the class (i.e. you won't have access to the instance members), you will want to decorate the function with @staticmethod... something like:
     @staticmethod
     def test(text):
Thu Oct 05, 2017 7:48 pm
thanks ,
here is want I want to dow.
set up a tcp/ip listener class/instance
then when it gets data call the plugin test method and handover the data to change dev.states ..
### in plugin class
        server = tcpipServer(("192.168.1.15",12345), ThreadedEchoRequestHandler)
        t = threading.Thread(target=server.serve_forever)
        t.start()
        indigo.server.log( 'Server loop running in thread:', t.getName() )
    def test2(self,textIn):
        indigo.server.log(" test2 called with:")
        indigo.server.log(textIn)
        indigo.server.log(" test2 end")
      #  and then dev.updatestatesonserv etc ..
class ThreadedEchoRequestHandler(SocketServer.BaseRequestHandler):
    def handle(self):
        # Echo back to the client
        data = self.request.recv(1024)
        cur_thread = threading.currentThread()
        response = '%s: %s' % (cur_thread.getName(), data)
        self.request.send("ok")
        indigo.server.log(response)
        try: Plugin.test2(>> what goes here  <<< ,response)
        except  Exception, e:
                indigo.server.log(u"in Line '%s' has error='%s'" % (sys.exc_traceback.tb_lineno, e))
        indigo.server.log("end")
        return
class tcpipServer(SocketServer.ThreadingMixIn, SocketServer.TCPServer):
    pass
so I would like to know: >> what goes here <<<
Thu Oct 05, 2017 8:52 pm
I guess this is the problem:
indigo creates the instance and it is known to INDIGO but not to the other class as IT does not instantiate the plugin class...
have tried to figure out inside the plugin " what is my instance" but that is just a pointer to a memory location I guess...
Thu Oct 05, 2017 9:04 pm
I think I see what you are trying to do there... I do something similar in Domotics Pad plugin (pared down for readability):
class Plugin(RPFramework.RPFrameworkPlugin.RPFrameworkPlugin):
   # This routine will send the Update Device Status request notification in order to ask
   # the device to update its status immediately (instead of waiting for its normal 15
   # minute update interval)
   def requestDeviceStatusNotification(self, deviceId):
class ThreadedTCPRequestHandler(SocketServer.BaseRequestHandler):
   def handle(self):
      indigoPlugin = indigo.activePlugin
      indigoPlugin.requestDeviceStatusNotification(int(deviceId))
If I've mucked something up in trying to be concise, feel free to download the Domotics Pad Mobile Client plugin and look at the full code.
Adam
Thu Oct 05, 2017 9:14 pm
No Adam, you got it right.
        plugin = indigo.activePlugin
        plugin.test('foo')
will pass the text 'foo' to the method test(self, text) within the main plugin class.
I just tested it. :)
Thu Oct 05, 2017 9:16 pm
ok that works. so help me understand:
indigo.activePlugin gets the instance for the call to test(response) (in my case.)
Thu Oct 05, 2017 9:32 pm
Yes, this was a suggestion that I got from Matt a while back for getting a reference to the current plugin (current being current within that process, I assume... probably a null reference outside of the plugin host).
Thu Oct 05, 2017 11:19 pm
this is cool ... actually already works.
Now some error management and logging and testing ..
that was FAST
thanks
Mon Oct 09, 2017 10:13 am
Think this is for Matt/ Jay/ RogueProeliator
I believe there is an opportunity to improve how indigo shuts down the plugins:
Asume:
A tcp/ip listener stack is running in its own class and calls the plugin methods ( indigo.activePlugin.someMethod() ) every time when receiving data i.e. to update dev/states etc ( that works nicely)
Then when indigo is starting the shutdown process for the plugin:
It looks to me that the access to the plugin methods are stopped a little bit too early: the tcp/ip listener stack is still receiving data and tries to call the plugin methods , but they are not reachable, the console then shows "HandlerError -- all command handlers are disabled for that plugin" -- many times
So it would be nice if the methods are still available until the main thread (runConcurrentThread ..) is finished.
When the plugin stops internally (just exit the "while True" loop in runConcurrentThread) and the tcp/ip stack does a socket.close() before ending "runConcurrentThread" everything shuts down nicely
It also shuts down nicely when there is no data coming into tcp/ip socket = the tcp/ip stack is NOT calling any indigo.activePlugin methods.
At least that is my simplistic view of the world.
Mon Oct 09, 2017 11:48 am
I think something slightly different is occurring. Can you copy/paste the Event Log showing the complete shutdown sequence in the case where the error occurs?
Mon Oct 09, 2017 2:31 pm
         if self.indigoInputPORT > 0 and self.IndigoOrSocket == "socket":
            self.currentlyBooting   = time.time() + 40
            self.startTcpipListening()
            self.currentlyBooting   = time.time() + 20
            if self.socketServer is not None: self.stackReady = True
            indigo.variables.subscribeToChanges()
        if self.quitNow =="":
            if self.logFileActive:
                indigo.server.log(" .. initalized, log info in : "+self.logFile)
                self.ML.myLog("all"," .. initalized, starting loop" )
                indigo.server.log(" .. initalized, starting loop ")
        ########   ------- here the loop starts    --------------
        #self.ML.myLog("special","memory used: "+str(resource.getrusage(resource.RUSAGE_SELF).ru_maxrss / (1024.*1024.))[:6]+"[MB] BeginningOfLoop   ")
        while self.quitNow == "":
                self.countLoop += 1
                self.sleep(5.)
                if self.countLoop > 5:
                    anyChange= self.periodCheck()
                if self.statusChanged ==1:  self.setGroupStatus()
                if self.statusChanged ==2:  self.setGroupStatus(init=True)
                if self.enableFING == "1":
                    if self.updateFING("loop ") == "break": break
                #if self.countLoop%700 ==0: # once an hour
                    #self.ML.myLog("special","memory used: "+str(resource.getrusage(resource.RUSAGE_SELF).ru_maxrss / (1024.*1024.))[:6]+"[MB] @LoopSnapshot  ")
        self.messageON = False
                self.socketServer.shutdown()
        except:  pass
            if self.quitNow != "":
                indigo.server.log( u" stopping plugin due to:  ::::: " + self.quitNow + " :::::")
                serverPlugin = indigo.server.getPlugin(self.pluginId)
                serverPlugin.restart(waitUntilDone=False)
        except: pass
        return
#### this starts the listener
    def startTcpipListening(self):
            TCPserverHandle=""
            self.ML.myLog("socket",u"starting tcpip socket listener, for RPI data, might take some time")
            tcpStart = time.time()
            lsofCMD ="/usr/sbin/lsof -i tcp:"+str(self.indigoInputPORT)
            for ii in range(40):  #  gives port busy for ~ 20 secs if restart, new start it is fine, error message continues even if it works -- indicator =ok: if lsof gives port number
                try:    self.socketServer = ThreadedTCPServer((self.myIpNumber,self.indigoInputPORT), ThreadedTCPRequestHandler)
                    self.ML.myLog("socket",u"in Line '%s' :'%s'" % (sys.exc_traceback.tb_lineno, e)+ " try:"+ str(ii)+"  time elapsed:"+ str(time.time()-tcpStart) )
                    ret = subprocess.Popen(lsofCMD, shell=True, stdout=subprocess.PIPE, stderr=subprocess.PIPE).communicate()
                    if len(ret[0]) >0: #  if lsof gives port number it works..
                        self.ML.myLog("socket",lsofCMD+"\n"+ ret[0].strip("\n"))
                        TCPserverHandle = threading.Thread(target=self.socketServer.serve_forever)
                        TCPserverHandle.daemon =True # don't hang on exit
                        TCPserverHandle.start()
                        break
                if ii <=1: tcpWaitTime = 5
                else:      tcpWaitTime = 1
                self.sleep(tcpWaitTime)
                self.ML.myLog("socket",'tcpip socket listener running; thread:#'+ TCPserverHandle.getName() )#  + " try:"+ str(ii)+"  time elapsed:"+ str(time.time()-tcpStart) )
            except: self.quitNow=" tcpip stack did not load, restart"
            return
    def handle(self):
            data0 =""
            tStart=time.time()
            if  not indigo.activePlugin.ipNumberOK(self.client_address[0]) :
                indigo.activePlugin.ML.myLog("socket","TCPIP socket data receiving from "+ unicode(self.client_address) +" not in accepted ip number list"  )
                indigo.activePlugin.handlesockErrorreporting(self.client_address[0],0,"unknown","errIP" )
                return
            while True:
                buffer = self.request.recv(1024)#  max observed is ~ 2200 bytes
                data0 += buffer
                if not buffer or len(buffer) ==0 or len(buffer) < 1024:
                    break
                if time.time() - tStart > 2: break
                if  len(data0) > 13000:       return
                ## look for length tag dataS =split data
                dataS = data0.split("x-6-a")
                if len(dataS) !=3: # tag not found
                    indigo.activePlugin.ML.myLog("socket","TCPIP socket  x-6-a  tag not found: "+data0[0:50] +"  ..  "+data0[-10:])
                    try: self.request.send("error-tag missing")
                    except: pass
                    indigo.activePlugin.handlesockReporting(self.client_address[0],expLength,name,"errTag" )
                    return
                expLength = int(dataS[0])
                name      = dataS[1]
                lenData   = len(dataS[2])
                if expLength != lenData: # expected # of bytes not received
                    indigo.activePlugin.ML.myLog("socket","TCPIP socket length of data wrong, exp:"+dataS[0]+";  actual:"+ str(lenData)+";  name:"+name+"; "+dataS[2][0:50] +"    ..    "+data0[-10:])
                    try: self.request.send("error-lenDatawrong-"+str(lenData) )
                    except: pass
                    indigo.activePlugin.handlesockReporting(self.client_address[0],expLength,name,"errLength" )
                    return
                dataJ = json.loads(dataS[2])  # dataJ = json object for data
                try:    self.request.send("ok-"+str(lenData) )
                except: pass
                indigo.activePlugin.ML.myLog("socket",u"TCPIP socket  in Line '%s' has error='%s'" % (sys.exc_traceback.tb_lineno, e))
                indigo.activePlugin.ML.myLog("socket","TCPIP socket  bad data received; len of data:"+str(len(data0))+"  "+ unicode(threading.currentThread())+"    time used:"+str(time.time()-tStart) )
                indigo.activePlugin.ML.myLog("socket",data0[0:50]+"   ..   "+data0[-10:] )
                try: self.request.send("error-unknown-"+str(lenData) )
                except: pass
                indigo.activePlugin.handlesockReporting(self.client_address[0],expLength,name,"errUnknown" )
                return
            if name.find(u"pi_IN_") != 0 :
                indigo.activePlugin.ML.myLog("socket","TCPIP socket  listener bad name "+name )
                indigo.activePlugin.handlesockReporting(self.client_address[0],expLength,name,"badName" )
                return
            indigo.activePlugin.addToDataQueue( name, dataJ,dataS[2] )
            indigo.activePlugin.handlesockReporting(self.client_address[0],expLength,name,"ok" )
            indigo.activePlugin.ML.myLog("socket",u"in Line '%s' has error='%s'" % (sys.exc_traceback.tb_lineno, e))
            indigo.activePlugin.ML.myLog("socket","TCPIP socket "+ data0[0:50] )
            indigo.activePlugin.handlesockReporting(self.client_address[0],name,"errJson" )
        return
class ThreadedTCPServer(SocketServer.ThreadingMixIn, SocketServer.TCPServer):
    pass
###################  TCPIP listen section  receive data from RPI via socket comm  end            #################
other error messages in indigo log file .. only in console and sometimes indigo plugin has a crash (will send in email)
THIS: self.messageON = False
suppresses any logging in the plugin
Mon Oct 09, 2017 4:01 pm
I want to see the Event Log window results (from Indigo) when the plugin is shutting down and showing errors.
Mon Oct 09, 2017 4:28 pm
when I switch login on: i.e. do not suppress login I get
some of these - between 0 and 3 in indigo log
17:15:37 -in Line '756' has error='UnexpectedNullError'
17:26:29 -in Line '9567' has error='UnexpectedNullError -- CClientMgr not created'
17:26:29 -in Line '756' has error='UnexpectedNullError'
17:26:29 -in Line '8062' has error='UnexpectedNullError -- CClientMgr not created'
using:
   self.toLog(u"in Line '%s' has error='%s'" % (sys.exc_traceback.tb_lineno, e))
and between 0 and 15 in console of these;" HandlerError -- all command handlers are disabled for that plugin"
where line 756 can be something like this:
indigo.variable.create(varName, self.iBeaconFolderNameVariables)
or anything with get or update indigo. xxx in the plugin itself.
ps
I have suppressed logging with:
if  unicode(e).find("UnexpectedNullError") ==-1: and  self.messageON:
     self.toLog(...)
