Devices.xml ConfigUI - how to get Option value name?
Sun Jul 02, 2017 2:29 pm
zurich offline
Greetings,
in Devices.xml ConfigUI I have this code below.
<Field type="menu" id="city" defaultValue="">
            <Label>Weather for city:</Label>
            <List>
               <Option value=“47.3769, 8.5417”>Zurich</Option>
            </List>
         </Field>
To use the Option value “47.3769, 8.5417” in my plugin I get it with:
city = dev.pluginProps["city"]
How can I get the name of the city "Zurich"?
kind regards,
Z
Sun Jul 02, 2017 2:59 pm
Re: Devices.xml ConfigUI - how to get Option value name?
The easiest way is to construct the list dynamically rather than hard coding it in the Devices.xml file. Then you can just look up the label from the source used to generate the List values. For instance, you could define the following dictionary in the plugin.py file (but outside the Plugin subclass):
# Add this to the top with other imports
from operator import itemgetter
# Add this somewhere before you define your Plugin subclass at the top of the file.
CITY_MAP = {
    “47.3769, 8.5417”: "Zurich",
    # add one line per city
Then define the following method in your Plugin subclass that will use that to generate the list:
def get_city_list(self):
    # Dictionaries are unordered, so convert the dict to a list of tuples and sort it based on the city name label
    return sorted(CITY_MAP.items(), key=itemgetter(1))
Finally, in your Devices.xml:
    <List class="self" filter="" method="get_city_list"/>
</Field>
Untested, but that's close. Later, when you need to figure out the label:
# Somewhere in your code
# if the value city_coords is equal to "47.3769, 8.5417"
city_label = CITY_MAP[city_coords]
Mon Jul 03, 2017 12:49 am
autolog offline
Another simple option (excuse the pun) is to duplicate the city name in the value e.g.
            <List>
               <Option value=“Zurich,47.3769,8.5417”>Zurich</Option>
            </List>
         </Field>
Then when you process the returned value you can split it on a comma e.g.
city, latitude, longitude = returnedValue.split(',')
You could of course use a different separator character such as '$' if the comma becomes an issue. :)
Mon Jul 03, 2017 1:07 pm
zurich offline
Greetings Jay,
Your suggestion works well. I did run into one small problem when creating the CITY_MAP, the comma in between the lat. and long. gave this error:
UI dynamic list function returned illegal ID string (ignoring): 47.3769, 8.5417
I just removed the comma in the CITY_MAP then added it later when needed.
Kind regards,
Z
Mon Jul 03, 2017 1:56 pm
Glad it's working.
