White Level Limits
Thu Jun 08, 2017 11:56 am
White Level Limits
The Indigo 7 API documentation says:
whiteTemperature – the white temperature in Kelvin (1700-15000)
Is it possible to define the limits in a plugin device. I am defining a nanoleaf Aurora device that has limits of 1,200 to 6,500. I would like the temp slider in the Indigo UI to go from/to those values. :)
Sat Jun 10, 2017 6:02 pm
Re: White Level Limits
Hi Jon,
I've added to the request list to make the min and max temp values definable via a device property.
In the mean time I've modified Indigo's UI for that slider to go down to 1200 so the lower bounds will at least be settable from the UI.
Thu Nov 09, 2017 7:25 pm
Indigo 7.1.1 is now available for download and has two new device instance properties: WhiteTemperatureMin and WhiteTemperatureMax, which can be used to define the lower and upper bounds of the white temperature UI slider.
