RGB values in slider and states
Thu Apr 13, 2017 3:57 pm
To Matt / Jay
When setting the RGB values the sliders show 0-255 while the status shows 0-100
I guess in the dimmer action the input from the action (e.g. redLevel) is 0-255 while the status update (update to indigo device states) is 0-100?
But for "whiteLevel" the range is 0-100 for both?
thanks
Screen Shot 2017-04-13 at 16.53.50.png (56.99 KiB) Viewed 1243 times
Thu Apr 13, 2017 4:22 pm
Re: RGB values in slider and states
Indigo internally stores and shows all RGBW and brightness states with a range from 0 to 100. The macOS color picker however uses a range of 0 to 255, so Indigo scales that to its range internal range.
Sun Apr 16, 2017 9:07 pm
got that one all worked out..
now in indigo touch it looks as if there is only brightness, no RGB settings. Is that correct -- next version or am I missing something ?
Also for the dimmer function the slider is either at 0 or at 100 % depending on the ON/Off state. I can move it to lets say 55% and the settings go through, but the slider then only reacts to the on/off state .. ==> chList.append({'key':"onOffState", 'value':True})
value between 0.. 100
got 240 NEO pixel light strip to work. They really light up the room .. looks a bit cheesy especially in pink color and wife does not like it .. need to hide the strip behind something
Sun Apr 16, 2017 9:28 pm
Right - we haven't released an Indigo Touch update since we released I7...
And setting RGB values may not be in the next IT release - not sure yet.
