state key sensorValue not defined error
Sat Apr 08, 2017 11:53 am
Trying to use the standard Indigo "sensor" type device. Device definition is:
   <Device type="sensor" id="oregonSensor">
        <Name>Oregon Scientific Sensor</Name>
        <ConfigUI>
         <Field id="SupportsOnState" type="checkbox" defaultValue="false" hidden="true" />
         <Field id="SupportsSensorValue" type="checkbox" defaultValue="true" hidden="true" />
         <Field id="SupportsStatusRequest" type="checkbox" defaultValue="false" hidden="true" />
         <Field id="AllowOnStateChange" type="checkbox" defaultValue="false" hidden="true" />
            <Field id="address" type="menu">
                <Label>Device:</Label>
                <List class="self" filter="OREGON" method="availableDeviceList"/>
            </Field>
            </Field>
        </ConfigUI>
    </Device>
The device is later updated with:
            device.updateStateImageOnServer(indigo.kStateImageSel.TemperatureSensor)
            device.name = address + " Thermometer"
            device.subModel = "Thermometer"
            device.replaceOnServer()
            newProps = device.pluginProps
            newProps["configDone"] = True
            newProps["valueType"] = "temperature"
            device.replacePluginPropsOnServer(newProps)
Devices created using the standard new device creation dialogs work fine. I have other devices that I'm creating programmatically to group with the "base" sensor. Code to do that is:
            newdev = indigo.device.create(indigo.kProtocol.Plugin,
                                            address=address,
                                            name=address + " Hygrometer",
                                            deviceTypeId="oregonSensor",
                                            groupWithDevice=device.id,
                                            props={'configDone': True, 'valueType': "hygrometry"},
                                            folder=device.folderId)
            newdev.updateStateImageOnServer(indigo.kStateImageSel.HumiditySensor)
            newdev.model = device.model
            newdev.subModel = "Hygrometer"       # Manually need to set the model and subModel names (for UI only)
            newdev.replaceOnServer()
Now, when I go to update the sensor value, the original sensor updates fine. But the second sensor fails to update with this error:
   Error                           device "OREGON-46081 Hygrometer" state key sensorValue not defined (ignoring update request)
So there's something wonky going on with the definition of the second device. It's using the same device definition, so those attributes should be there, shouldn't they? It's clearly not picking up any of them, because the device status UI is totally different. Second one shows the status request button, for example. First does not.
Sat Apr 08, 2017 12:23 pm
Re: state key sensorValue not defined error
Nevermind. :roll:
                                            address=address,
                                            name=address + " Wind Direction",
                                            props={ 'valueType': 'direction',
                                                    'configDone': True,
                                                    'AllowOnStateChange': False,
                                                    'SupportsOnState': False,
                                                    'SupportsSensorValue': True,
                                                    'SupportsStatusRequest': False
