Execute shell command as root (sudo)
Mon Mar 27, 2017 7:50 pm
kwijibo007 offline
Hi All,
I would like to write a plugin that presents an on/off device which enables/disables remote login (SSH) on the Mac running Indigo server.
The command(s) to do this in terminal are:
systemsetup -getremotelogin #Query state
systemsetup -setremotelogin off  #Enable SSH
systemsetup -f -setremotelogin off  #Disable SSH
The problem is that this needs to be ran as root (prefixing with sudo). Is there anyway to run a command as root inside a plugin or is it impossible?
Pete
P.S Congrats to me on my 100th post!! :D
Tue Mar 28, 2017 11:29 am
Re: Execute shell command as root (sudo)
I think if you wrap it in an AppleScript thusly it will work:
do shell script "YOUR COMAND HERE" with administrator privileges
I think that'll cause the authentication dialog to open. Not positive it'll work, but I'm pretty sure this is what PyCharm does when installing packages, etc.
Note, however, that the user will have to be sitting at the Mac to authenticate. AFAIK, there is no way to automatically run a sudo process.
Tue Mar 28, 2017 12:25 pm
roussell offline
You can also exclude the file in sudoers to allow running it without a password. I suggest rather than editing the sudoers file, create an override like so:
sudo visudo -f /etc/sudoers.d/myOverrides
A new file called 'myOverrides' will be created and open in visudo (like the vi editor, but performs checks to make sure you don't lock yourself out of sudo with a syntax error). To allow any user to run the application without a password enter the following in to the file:
ALL ALL=(ALL) NOPASSWD: /usr/sbin/systemsetup
Save the file and exit. Then if you run
sudo /usr/sbin/systemsetup
it won't ask for a password, but note that you still have to use the sudo command.
WARNING: This has obvious security concerns. You can minimize those somewhat making a copy of the systemsetup file somewhere else with an innocuous name:
sudo cp /usr/sbin/systemsetup /Users/indigo/birthdaylist
(assuming the username you run Indigo under is "indigo")
Then of course you'd change your myOverrides file to point to the copied version of the file. You can also restrict it to the username Indigo is running as:
indigo ALL=(ALL) NOPASSWD: /Users/indigo/birthdaylist
You can also specify arguments such as:
indigo ALL=(ALL) NOPASSWD: /Users/indigo/birthdaylist -setremotelogin on
indigo ALL=(ALL) NOPASSWD: /Users/indigo/birthdaylist -f -setremotelogin off
The above will allow that command with those arguments to run without a password for the user 'indigo', but other users/commands/arguments will require a password.
Terry
Tue Mar 28, 2017 12:54 pm
RogueProeliator offline
Wow, great tip, Terry! I haven't needed that but was unaware that was even a thing... will put that away in the brain so that when I need it I won't remember but might feel a tickle making me search for it. :-)
Tue Mar 28, 2017 1:45 pm
+1 - awesome tip.
Tue Mar 28, 2017 2:16 pm
roussell offline
Heh, thanks guys, hope it helps the OP. I suck at software development, but *nix is my jam... 8)
Terry
Tue Mar 28, 2017 3:48 pm
kwijibo007 offline
Fantastic stuff. Thanks Terry, exactly what I was looking for. :D
I have no excuses now... I'd better write the plugin.
Pete
Tue Apr 04, 2017 11:10 pm
kwijibo007 offline
I've posted the plugin here.
Thanks again Terry for your help.
Pete
Wed Apr 05, 2017 6:20 am
roussell offline
Pete
Anytime Pete, happy to be of service! Nice plugin BTW!
Terry
