Find device by address
Tue Mar 21, 2017 11:05 pm
drbrain offline
I'm working on a plugin to support Hunter Douglas PowerView shades.
I would like to automatically create the shade devices after you add a hub device.
The PowerView hub keeps consistent IDs for the shades which I can store in the address field.
Do I have to iterate through
indigo.devices
by hand to find a device that was already created to avoid
exception in deviceStartComm(Hub): NameNotUniqueError
If I have to iterate is there a way to restrict my search to only devices for my plugin type?
Wed Mar 22, 2017 1:47 am
I'm not at my desk right now and can't find exact syntax, but you can say the following, once you get right syntax:
if not in indigo.devices(self)
This will iterate all devices by your plugin, or self.shadeDevType will iterate all shadeDevType devices (whatever typeID you've given them).
Wed Mar 22, 2017 9:00 am
Re: Find device by address
First, I encourage you to not take the automatic creation approach. The standard device creation flow in Indigo is for the user to create each device themselves. There are a few cases where we automatically create devices, but that's generally sub-devices (devices that have a very tight binding between them, like multifunction sensors). There are a few plugins that auto-create devices when enabled (or when a hub-like instance is added) and it always seems to cause users some confusion. Another problem is that it often becomes necessary for your user to recreate or resync one of your devices and if there is no option for editing/creating a single device that becomes more tricky. Remember that links between triggers, conditions, actions, and control pages are via the device ID so just creating a new version of a device will break all of those ties.
Second, any device that your plugin creates will have deviceStartComm() called for it. A good design pattern is to keep a list of those "active" devices in your plugin so that you don't have to ask the server every time you want one. The will, of course, get stale over time, so if you use state information you'll want to refresh the instance.
Finally, if you need to iterate over your own devices check out the Iterating Object Lists section of the docs.
Wed Mar 22, 2017 12:38 pm
Hehe, if I'd had time this morning I was going to say that about auto-creation!
Somebody, probably you, said the same to me about my Evohome plugin. :-)
