Hello everyone,
I'm trying to write a plugin for the British Gas Hive Thermostat (ZigBee device) using their 'unofficial' API.
When it comes to heating (on a manual mode) you just set it to a temperature and Hive then turns-on the gas boiler until the thermostat (placed in a room in the home) reaches that temperature.
I have tried to look and learn from the NEST plugin but there are so many options that are not needed for a simple heat service like Hive, can they be disabled somehow?
I've read through the forums and managed to 'remove' the by setting the 'SupportsHvacFanMode' to False, but for example there is no 'Cool' option in Hive as it is used just for heating. So in essence it is either 'Off' or 'Heat On' - unless I got something wrong...
Also when I use the arrows the increment is by 1.0 degree, Hive uses 0.5 by default (20, 20.5, 21, 21.5, etc) so is there a way to increment by 0.5 instead of 1.0?
Thank you!
