DEVICE.XML checkbox
Fri Mar 03, 2017 4:07 pm
DEVICE.XML checkbox
DEVICE.XML
when I switch from a menu / list selection (0/1) to a checkbox(true/false) for an existing device the resulting valuesDict paramter is always integer 0
<Field id="memberOfFamily" type="menu"   defaultValue="0">
    <Label>Member of Family:</Label>
    <List>
        <Option value="0"   > no</Option>
        <Option value="1"   > yes</Option>
    </List>
</Field>
to
<Field id="memberOfFamily" type="checkbox"   defaultValue="false">
</Field>
I also tried default = "1" or "0" or "true" ..
In validateDeviceConfigUi():
I always get:
     memberOfFamily : 0 (integer)
with indigo.server.log(unicode(valuesDict))
any advice?
Fri Mar 03, 2017 5:26 pm
Re: DEVICE.XML checkbox
defaultValue is never used when there's an existing value in valuesDict - it's only used when there is no existing value. You'll need to convert the value yourself to the appropriate boolean value from the previous integer value, probably in deviceStartComm(). We don't attempt to do any conversion of existing data so when a value type changes it's up to you to "fix" it.
[MODERATOR NOTE] moved to the correct forum and fixed the XML formatting to improve readability.
