Passing object vs passing variables
Thu Dec 22, 2016 9:58 am
bkmar1192 offline
Amateur programmer question.
My plugin is pretty CPU intensive and I am trying to find ways to improve performance.
In my plugin I call several subroutines for each device. Each of those subroutines gets state and attribute settings from the device.
Is it more efficient to pass the device object to the subroutine or get my variables in the main loop and pass a series of 5 or 6 strings.
Thanks for the help.
Thu Dec 22, 2016 10:43 am
Re: Passing object vs passing variables
Passing the device object to the subroutines is probably cleaner, but I doubt there's a significant CPU penalty either way.
Thu Dec 22, 2016 1:00 pm
Agreed – passing either the entire device instance or the variables will be about the same. One thing you don't want is to do multiple device look-ups. These are all examples of a device lookup which will cause an Indigo Server call:
dev = indigo.devices[123]
dev = indigo.devices["some dev name"]
brightness = indigo.devices[123].brightness
foo = indigo.devices[123].pluginProps["foo"]
In cases like that it is best to get the device once, then use that instance for access to all attributes of the device.
Thu Dec 22, 2016 3:12 pm
Just keep in mind that the copy of the device instance you get is static. It won't update if the device changes. You'll need to get it again to get updated values.
Fri Dec 23, 2016 11:22 am
Or refresh it:
dev.refreshFromServer()
Fri Dec 23, 2016 2:20 pm
jay (support) wrote:
Or refresh it:
Is this significantly more efficient than just getting a new copy?
